Haulotte Telescopic Booms HT43 RTJ PRO HT132 RTJ PRO Operators Manual 4001324130 03.2025 EN
Brand: Haulotte
Type of Machine: Telescopic Booms
Model: Haulotte HT43 RTJ PRO, HT132 RTJ PRO Telescopic Booms
Part Number: 4001324130
Publication Date: 03.2025
Number of Pages: 150 Pages
Foreword
1 Foreword
2 User Responsibility
2.1 Owner's Responsibility
2.2 Employer's Responsibility
2.3 Trainer's Responsibility
2.4 Operator's Responsibility
3 Safety
3.1 Safety Instructions
3.1.1 Incorrect Use
3.1.2 Falling Hazards
3.1.3 Overturning / Tip-Over Hazards
3.1.4 Risk Of Electric Shock (Electrocution)
3.1.5 Explosion / Fire Hazards
3.1.6 Crushing / Collision Hazards
3.1.7 Risk Of Involuntary Movements
4 Safety Inquiries
5 Incident Notification
6 Compliance
6.1 Product Modification
6.1.1 Implementing Manufacturer Safety Campaigns
6.2 Product Specifications
6.3 Change Of Ownership Notification
6.4 Declaration Of Conformity
6.4.1 Declaration Of Conformity - All Machines
6.4.2 Declaration Of Conformity - Thermal Platforms
Familiarization
1 General Safety
1.1 Intended Use
1.2 Decal Content
1.3 Level Of Severity
1.4 Symbols Legend And Definitions
1.5 Symbols And Colors
2 Models Description
3 Primary Machine Components
3.1 Layout
3.2 Ground Control Box
3.2.1 Layout
3.2.2 Display Panel (Led's 1 - 10)
3.3 Platform Control Box
3.3.1 Layout
3.3.2 Display Panel (Led's 101 - 117)
3.4 Dpf (Diesel Particle Filter) (If Equipped - Deutz 2,2 Tdc Engine Only)
3.4.1 Automatic Regeneration
3.4.2 Manual Regeneration
3.4.3 To Stop Manual Regeneration
3.5 Axle Extension Control Box
3.5.1 Layout
4 Performance Specifications
4.1 Technical Characteristics
4.2 Engine Specifications
4.2.1 Deutz Engines
4.2.2 Perkins Engines
4.3 Working Area / Range Of Motion
5 Decals And Markings Locations
Pre-Operation Inspection
1 Recommendations
2 Working Area Assessment
3 Inspection And Functional Test
3.1 Daily Inspection
4 Safety Functional Checks
4.1 E-Stop Button Check
4.2 Activation Of Controls
4.3 Fault Detector
4.3.1 Indicators/Led's Test
4.3.2 Buzzers Test
4.4 Automatic Engine Cut-Out
4.5 Overload Sensing System
4.6 Oscillating Axles
4.7 Slope Warning Device
4.8 Travel Speed Limitation
4.9 Movement Speed
4.10 On-Board Electronics
4.11 Radius Limitation
4.12 Axle Extension
4.13 Braking Test
4.14 Overload Test
Operation Instructions
1 Operation
1.1 Introduction
1.2 Major Description
1.3 Operation From The Ground Control Box (Auxiliary Station)
1.4 Operation From The Platform Control Box (Main Station)
2.1 To Start And Stop The Machine
2.2 Movement Control
2.3 Additional Controls From The Ground Control Box
3.1 To Start And Stop The Machine
3.2 Drive And Steer Control
3.3 Movement Control
3.4 Additional Controls
4 Axle Extension Control Box
4.1 Prepare The Machine
4.2 Axle Extension Operation
4.2.1 For Rear Axle Extension
4.2.2 For Front Axle Extension
4.3 Axle Retraction Operation
4.3.1 For Front Axle Retraction
4.3.2 For Rear Axle Retraction
5 Radius Limitation
5.1 Procedure
5.1.1 Front Stability
5.1.2 Rear Stability
6 Rescue And Emergency Procedures
6.1 In Case Of Power Loss
6.2 To Rescue Operator In Platform
6.3 Operation Of Overriding System From Ground Control Box
6.4 No Power Available
7 Transportation
7.1 Transport Configuration
7.2 Machine Stowage For Transport - Ht43rtj Pro - Ht132rtj Pro
7.3 Unloading
7.4 Towing
7.4.1 Disengaging The Drive Hubs
7.4.2 Re-Engaging The Drive Hubs
7.5 Storage
7.6 Lifting Operation
7.6.1 Necessary Equipment
7.6.2 Preliminary Procedures
7.6.3 Procedure For The Use Of Slings
8 Cold Weather Recommendations
8.1 Engine Oil
8.2 Hydraulic Oil
8.3 Preheating Operation
General Specifications
1 Machine Dimensions
2 Major Component Masses
3 Acoustics And Vibrations
4 Wheel/Tire Assembly
4.1 Technical Specifications
4.2 Inspection And Maintenance
5 Options
5.1 Compatibility
5.2 Platform
5.2.1 Swing Gate
5.2.1.1 Description
5.2.1.2 Safety Precautions
5.2.1.3 Pre-Operation Instructions
5.3 On-Board Generator
5.3.1 Description
5.3.2 Characteristics
5.3.3 Safety Precautions
5.3.4 Pre-Operation Inspection
5.3.5 Operation
5.4 Welder's Kit
5.4.1 Description
5.4.2 Characteristics
5.4.3 Safety Precautions
5.4.4 Pre-Operation Inspection
5.4.5 Operation
5.4.6 Assembly-Dis-Assembly
5.4.7 Specific Decals
5.5 Plumber's Kit
5.5.1 Description
5.5.2 Characteristics
5.5.3 Safety Precautions
5.5.4 Pre-Operation Inspection
5.5.5 Operation
5.5.6 Assembly-Dis-Assembly
5.5.7 Specific Decals, Optional
5.6 Activ' Shield Bar - Secondary Guarding System (If Fitted)
5.6.1 Description
5.6.2 Characteristics
5.6.3 Safety Precautions
5.6.4 Pre-Operation Inspection
5.6.5 Operation
5.6.6 Specific Decals
Maintenance
1 General
2 Maintenance Schedule
3 Inspection Program
3.1 General Program
3.2 Daily Inspection
3.3 Periodic Inspection
3.4 Reinforced Inspection
3.5 Major Inspection
4 Repairs And Adjustments
Other Information
1 Conditions Of Warranty
2 Subsidiary Contact Information
2.1 California Warning
Records
1 Intervention Register
Brand: Haulotte
Foreword
1 Foreword
3 Safety
3.1.1 Incorrect Use
4 Safety Inquiries
6 Compliance
Familiarization
1 General Safety
1.1 Intended Use
1.2 Decal Content
3.1 Layout
3.2.1 Layout
3.3.1 Layout
3.5.1 Layout
4.2.1 Deutz Engines
1 Recommendations
4.3 Fault Detector
4.3.2 Buzzers Test
4.9 Movement Speed
4.12 Axle Extension
4.13 Braking Test
4.14 Overload Test
1 Operation
1.1 Introduction
5 Radius Limitation
5.1 Procedure
7 Transportation
7.3 Unloading
7.4 Towing
7.5 Storage
8.1 Engine Oil
8.2 Hydraulic Oil
5 Options
5.1 Compatibility
5.2 Platform
5.2.1 Swing Gate
5.2.1.1 Description
5.3.1 Description
5.3.5 Operation
5.4 Welder's Kit
5.4.1 Description
5.4.5 Operation
5.5 Plumber's Kit
5.5.1 Description
5.5.5 Operation
5.6.1 Description
5.6.5 Operation
Maintenance
1 General
3.1 General Program
Other Information
Records
- Haulotte Articulated Boom Lift 4527A, HTA 16P Parts and Service Manual
- Haulotte Bil-Jax Articulated Boom Lift 5533A Parts and Service Manual
- Haulotte Scissor Lift Compact 8 Parts Manual
- Haulotte HA20PX HA26PX Self Propelled LIft Repair Manual
- Haulotte Articulated Boom Lift HA15IP-HA43JE Parts Manual_2420339510
- Haulotte Scissor Lift Compact 10, 2747E Parts Manual
- Haulotte 4527A HTA 16P Part Manual
- Haulotte Articulated Boom Lift HA16PX-HA18PX Parts Manual_2420344550
- Haulotte Scissor Lift Optimum 6, Optimum 8 Parts Manual
- Haulotte OPTIMUM 8 - 1931E_E04.20 Part Manual
- Haulotte Scissor Lift Optimum 1530E, 1930E Repair Manual_2420318690
- Haulotte Articulated Boom Lift HA20PX, HA80JRT Parts Manual_2420340850
- Haulotte Telescopic Boom HT21TX-HB62 Parts Manual_2420311040
- Haulotte Self Propelled Scissor Optimum 6,8 Operating and Maintenance Instructions
- Haulotte Articulated Boom Lift HA18-HA51 Parts Manual_4000415260
