Haulotte Telescopic Booms HT28 RTJ O to HT85 RTJ PRO Operators Manual 4001324430 12.2025 EN
Brand: Haulotte
Type of Machine: Telescopic Booms
Model: Haulotte HT28 RTJ O, HT28 RTJ O SW, HT28 RTJ PRO, HT28 RTJ PRO SW, HT85 RTJ O, HT85 RTJ PRO Color Screen Display Telescopic Booms
Part Number: 4001324430
Publication Date: 12.2025
Number of Pages: 190 Pages
Foreword
1 Foreword
2 Responsibilities
2.1 Owner's Responsibility
2.2 Employer's Responsibility
2.3 Trainer's Responsibility
2.4 Operator's Responsibility
3 Safety
3.1 Safety Instructions
3.1.1 Incorrect Use
3.1.2 Falling Hazards
3.1.3 Overturning / Tip-Over Hazards
3.1.4 Risk Of Electric Shock (Electrocution)
3.1.5 Explosion / Fire Hazards
3.1.6 Crushing / Collision Hazards
3.1.7 Risk Of Involuntary Movements
4 Safety Inquiries
5 Incident Notification
6 Compliance
6.1 Product Modification
6.1.1 Implementing Manufacturer Safety Campaigns
6.2 Product Specifications
6.3 Change Of Ownership Notification
6.4 Declaration Of Conformity
6.4.1 Declaration Of Conformity - All Machines
6.4.2 Declaration Of Conformity - Thermal Platforms
Familiarization
1 General Safety
1.1 Intended Use
1.2 Decal Content
1.3 Level Of Severity
1.4 Symbols Legend And Definitions
1.5 Symbols And Colors
2 Models Description
3 Primary Machine Components
3.1 Layout
3.2 Ground Control Box - Service / Emergency Station
3.2.1 Layout - Color Screen Display
3.2.2 Haulotte Activ'screen 2
3.3 Platform Control Box - Main Station
3.3.1 Layout
3.3.2 Display Panel (Led's 101, 117)
3.4 Dpf (Diesel Particle Filter) (If Equipped)
3.4.1 Kubota Engine
3.4.2 Deutz Engine
3.4.3 Automatic Regeneration
3.4.4 Manual Regeneration
3.4.5 To Inhibit Regeneration
3.4.6 To Stop Manual Regeneration
4 Performance Specifications
4.1 Technical Characteristics
4.2 Engine Specifications
4.2.1 Kubota Engines
4.2.2 Deutz Engines
4.3 Working Area / Range Of Motion
5 Decals And Markings Locations
Pre-Operation Inspection
1 Recommendations
2 Working Area Assessment
3 Inspection And Functional Test
3.1 Daily Inspection
4 Safety Functional Checks
4.1 Emergency Stop Button Check
4.2 Activation Of Controls
4.3 Fault Detector
4.3.1 Indicators/Led's Test
4.3.2 Buzzers Test
4.4 Automatic Engine Cut-Out
4.5 Overload Sensing System
4.6 Oscillating Axles (If Equipped)
4.7 Slope Warning Device
4.8 Travel Speed Limitation
4.9 On-Board Electronics
4.10 Load Selection System (If Fitted)
4.11 Braking Test
4.12 Overload Test
Operation Instructions
1 Operation
1.1 Introduction
1.2 Major Description
1.3 Operation From The Ground Control Box (Service / Emergency Station)
1.4 Operation From The Platform Control Box (Main Station)
2.1 To Start And Stop The Machine - Diesel Engine
2.2 To Start And Stop The Machine - Petrol / Gas (Propane) Engine
2.3 Movement Control
2.4 Additional Controls
3.1 To Start And Stop The Machine
3.1.1 To Start The Machine
3.1.1.1 To Stop The Engine
3.1.1.2 If Engine Is Stopped By Stop Emission System
3.2 Drive And Steer Control
3.3 Movement Control
3.4 Additional Controls
3.4.1 Stop Emission System
3.4.2 Activ' Lighting System
3.4.3 Dual Load Selector (If Fitted)
4 Rescue And Emergency Procedures
4.1 In Case Of Power Loss
4.2 To Rescue Operator In Platform
4.3 Operation Of Overriding System From Ground Control Box
4.4 No Power Available
5 Transportation
5.1 Transport Configuration
5.2 Machine Stowage For Transport , Ht28 Rtj O, Ht28 Rtj O Sw, Ht85 Rtj O, Ht28 Rtj Pro, Ht28 Rtj Pro Sw, Ht85 Rtj Pro
5.3 Unloading
5.4 Towing
5.4.1 Disengaging The Drive Hubs
5.4.2 Re-Engaging The Drive Hubs
5.5 Storage
5.6 Lifting Operation
6 Cold Weather Recommendations
6.1 Engine Oil
6.2 Hydraulic Oil
General Specifications
1 Machine Dimensions
2 Major Component Masses
3 Acoustics And Vibrations
4 Wheel/Tire Assembly
4.1 Technical Specifications
4.2 Inspection And Maintenance
5 Options
5.1 Compatibility
5.2 Advanced Access Management - Access Control And Usage Restriction
5.2.1 Description
5.2.1.1 Access Control
5.2.1.2 Usage Restriction
5.2.1.3 Geofence
5.2.1.4 Timefence
5.2.1.5 Remote Restriction
5.2.2 Additional Functions
5.2.2.1 Access Control And Usage Restriction Combination
5.2.2.2 Tracker Default Function
5.2.3 Super User Status
5.2.4 Code For Removing Restrictions
5.2.5 Operation
5.2.5.1 Using A Machine With Access Control Enabled
5.2.5.2 Starting A Machine With Usage Restriction Enabled
5.3 Platform
5.3.1 Swing Gate
5.3.1.1 Description
5.3.1.2 Specifications
5.3.1.3 Safety Precautions
5.3.1.4 Pre-Operation Instructions
5.3.1.5 Specific Decals, Optional
5.4 On-Board Generator
5.4.1 Description
5.4.2 Characteristics
5.4.3 Safety Precautions
5.4.4 Pre-Operation Inspection
5.4.5 Operation
5.5 Glazier's Kit
5.5.1 Description
5.5.2 Characteristics
5.5.3 Safety Precautions
5.5.4 Pre-Operation Inspection
5.5.5 Operation
5.5.6 Assembly/Dis-Assembly
5.5.7 Specific Decals
5.6 Welder's Kit
5.6.1 Description
5.6.2 Characteristics
5.6.3 Safety Precautions
5.6.4 Pre-Operation Inspection
5.6.5 Operation
5.6.6 Assembly-Dis-Assembly
5.6.7 Specific Decals
5.7 Plumber's Kit
5.7.1 Description
5.7.2 Characteristics
5.7.3 Safety Precautions
5.7.4 Pre-Operation Inspection
5.7.5 Operation
5.7.6 Assembly-Dis-Assembly
5.7.7 Specific Decals, Optional
5.8 Activ' Shield Bar - Secondary Crush Risk Reduction System (If Fitted)
5.8.1 Description
5.8.2 Characteristics
5.8.3 Safety Precautions
5.8.4 Pre-Operation Inspection
5.8.5 Operation
5.8.6 Specific Decals
5.9 Sand Tires
5.9.1 Technical Specifications
5.9.2 Inspection And Maintenance
5.9.3 Specific Decal(S)
Maintenance
1 General
2 Maintenance Schedule
3 Inspection Program
3.1 General Program
3.2 Daily Inspection
3.3 Periodic Inspection
3.4 Reinforced Inspection
3.5 Major Inspection
4 Repairs And Adjustments
Other Information
1 Conditions Of Warranty
2 Subsidiary Contact Information
2.1 California Warning
Records
1 Intervention Register
Brand: Haulotte
Foreword
1 Foreword
2 Responsibilities
3 Safety
3.1.1 Incorrect Use
4 Safety Inquiries
6 Compliance
Familiarization
1 General Safety
1.1 Intended Use
1.2 Decal Content
3.1 Layout
3.3.1 Layout
3.4.1 Kubota Engine
3.4.2 Deutz Engine
4.2.2 Deutz Engines
1 Recommendations
4.3 Fault Detector
4.3.2 Buzzers Test
4.11 Braking Test
4.12 Overload Test
1 Operation
1.1 Introduction
5 Transportation
5.3 Unloading
5.4 Towing
5.5 Storage
6.1 Engine Oil
6.2 Hydraulic Oil
5 Options
5.1 Compatibility
5.2.1 Description
5.2.1.3 Geofence
5.2.1.4 Timefence
5.2.5 Operation
5.3 Platform
5.3.1 Swing Gate
5.3.1.1 Description
5.4.1 Description
5.4.5 Operation
5.5 Glazier's Kit
5.5.1 Description
5.5.5 Operation
5.6 Welder's Kit
5.6.1 Description
5.6.5 Operation
5.7 Plumber's Kit
5.7.1 Description
5.7.5 Operation
5.8.1 Description
5.8.5 Operation
5.9 Sand Tires
Maintenance
1 General
3.1 General Program
Other Information
Records
- Haulotte Articulated Boom Lift 4527A, HTA 16P Parts and Service Manual
- Haulotte Bil-Jax Articulated Boom Lift 5533A Parts and Service Manual
- Haulotte Scissor Lift Compact 8 Parts Manual
- Haulotte HA20PX HA26PX Self Propelled LIft Repair Manual
- Haulotte Articulated Boom Lift HA15IP-HA43JE Parts Manual_2420339510
- Haulotte Scissor Lift Compact 10, 2747E Parts Manual
- Haulotte 4527A HTA 16P Part Manual
- Haulotte Articulated Boom Lift HA16PX-HA18PX Parts Manual_2420344550
- Haulotte Scissor Lift Optimum 6, Optimum 8 Parts Manual
- Haulotte OPTIMUM 8 - 1931E_E04.20 Part Manual
- Haulotte Scissor Lift Optimum 1530E, 1930E Repair Manual_2420318690
- Haulotte Articulated Boom Lift HA20PX, HA80JRT Parts Manual_2420340850
- Haulotte Telescopic Boom HT21TX-HB62 Parts Manual_2420311040
- Haulotte Self Propelled Scissor Optimum 6,8 Operating and Maintenance Instructions
- Haulotte Articulated Boom Lift HA18-HA51 Parts Manual_4000415260
