Haulotte Telescopic Booms HT16 RTJ O to HT46 RTJ PRO Operators Manual 4001326540 11.2025 EN
Momed80
150
35,046
Brand: Haulotte
Type of Machine: Telescopic Booms
Model: Haulotte HT16 RTJ O, HT16 RTJ PRO, HT46 RTJ O, HT46 RTJ PRO Telescopic Booms
Part Number: 4001326540
Publication Date: 11.2025
Number of Pages: 180 Pages
Foreword
1 Foreword
2 Responsibilities
2.1 Owner's responsibility
2.2 Employer's responsibility
2.3 Trainer's responsibility
2.4 Operator's responsibility
3 Safety
3.1 Safety instructions
3.1.1 Incorrect use
3.1.2 Falling Hazards
3.1.3 Overturning / Tip-over Hazards
3.1.4 Risk of electric shock (electrocution)
3.1.5 Explosion / Fire Hazards
3.1.6 Crushing / Collision Hazards
3.1.7 Risk of involuntary movements
4 Safety inquiries
5 Incident notification
6 Compliance
6.1 Product modification
6.1.1 Implementing manufacturer safety campaigns
6.2 Product specifications
6.3 Change of Ownership Notification
6.4 Declaration of conformity
6.4.1 Declaration of conformity - All machines
6.4.2 Declaration of conformity - Thermal platforms
Familiarization
1 General safety
1.1 Intended use
1.2 Decal content
1.3 Level of severity
1.4 Symbols legend and definitions
1.5 Symbols and colors
2 Models description
3 Primary machine components
3.1 Layout
3.2 Ground control box - Service / Emergency station
3.2.1 Layout-Color screen display
3.2.2 HAULOTTE Activ'Screen 2
3.3 Platform control box - Main station
3.3.1 Layout
3.3.2 Display Panel (LED'S 101, 117)
4 Performance Specifications
4.1 Technical characteristics
4.2 Engine specifications
4.2.1 Kubota engines
4.2.2 Perkins engines
4.3 Working area / Range of motion
5 Decals and markings locations
Pre-operation inspection
1 Recommendations
2 Working area assessment
3 Inspection and Functional test
3.1 Daily inspection
4 Safety functional checks
4.1 Emergency Stop button check
4.2 Activation of controls
4.3 Fault detector
4.3.1 Indicators/LED's test
4.3.2 Buzzers test
4.4 Automatic engine cut-out
4.5 Overload sensing system
4.6 Oscillating axles (If equipped)
4.7 Slope warning device
4.8 Travel speed limitation
4.9 Load selection system (if fitted)
Operation instructions
1 Operation
1.1 Introduction
1.2 Major description
1.3 Operation from the ground control box (Service / Emergency station)
1.4 Operation from the platform control box (Main station)
2.1 To start and stop the machine - Diesel engine
2.2 To start and stop the machine - Petrol / gas (Propane) Engine
2.3 Movement control
2.4 Additional controls
3.1 To start and stop the machine
3.1.1 To start the machine
3.1.1.1 To stop the engine
3.1.1.2 If engine is stopped by Stop Emission System
3.2 Drive and steer control
3.3 Movement control
3.4 Additional controls
3.4.1 Stop Emission System
3.4.2 Activ' Lighting System
3.4.3 Dual load selector (if fitted)
4 Rescue and emergency procedures
4.1 In case of power loss
4.2 To rescue operator in platform
4.3 Operation of overriding system from ground control box
4.4 No power available
5 Transportation
5.1 Transport configuration
5.2 Machine stowage for transport - HT16 RTJ O, HT16 RTJ PRO, HT46 RTJ O, HT46 RTJ PRO
5.3 Unloading
5.4 Towing
5.4.1 Brake release
5.4.2 Adjustment after manual release
5.5 Storage
5.6 Lifting operation
6 Cold Weather Recommendations
6.1 Engine oil
6.2 Hydraulic oil
General Specifications
1 Machine dimensions
2 Major component masses
3 Acoustics and vibrations
4 Wheel/Tire assembly
4.1 Technical specifications
4.2 Inspection and maintenance
5 Options
5.1 Compatibility
5.2 Advanced Access Management - Access control and usage restriction
5.2.1 Description
5.2.1.1 Usage restriction
5.2.1.2 GEOFENCE
5.2.1.3 TIMEFENCE
5.2.1.4 Remote restriction
5.2.2 Additional functions
5.2.2.1 Access control and usage restriction combination
5.2.2.2 tracker default function
5.2.3 SUPER USER status
5.2.4 Code for removing restrictions
5.2.5 Operation
5.2.5.1 Using a machine with access control enabled
5.2.5.2 Starting a machine with usage restriction enabled
5.3 Platform
5.4 Swing gate
5.4.1 Description
5.4.2 Specifications
5.4.3 Safety precautions
5.4.4 Pre-operation instructions
5.4.5 Specific decals, optional
5.5 On-board generator
5.5.1 Description
5.5.2 Characteristics
5.5.3 Safety precautions
5.5.4 Pre-operation inspection
5.5.5 Operation
5.6 Glazier's kit
5.6.1 Description
5.6.2 Characteristics
5.6.3 Safety precautions
5.6.4 Pre-operation inspection
5.6.5 Operation
5.6.6 Assembly/Dis-assembly
5.6.7 Specific decals
5.7 Welder's kit
5.7.1 Description
5.7.2 Characteristics
5.7.3 Safety precautions
5.7.4 Pre-operation inspection
5.7.5 Operation
5.7.6 Assembly-Dis-assembly
5.7.7 Specific decals
5.8 Plumber's kit
5.8.1 Description
5.8.2 Characteristics
5.8.3 Safety precautions
5.8.4 Pre-operation inspection
5.8.5 Operation
5.8.6 Assembly-Dis-assembly
5.8.7 Specific decals, optional
5.9 Activ' Shield Bar - Secondary crush risk reduction system (If fitted)
5.9.1 Description
5.9.2 Characteristics
5.9.3 Safety precautions
5.9.4 Pre-operation inspection
5.9.5 Operation
5.9.6 Specific decals
5.10 Sand tires
5.10.1 Technical specifications
5.10.2 Inspection and maintenance
Maintenance
1 General
2 Maintenance Schedule
3 Inspection program
3.1 General program
3.2 Daily inspection
3.3 Periodic inspection
3.4 Reinforced inspection
3.5 Major inspection
4 Repairs and adjustments
Other information
1 Conditions of warranty
2 Subsidiary contact information
2.1 California warning
Records
1 Intervention register
