Momed80
151
35,863
Haulotte Scissor Lift OPTIMUM 8 OPTIMUM 1931 E Service Repair Manual 4001405210 03.2026 EN
Brand: Haulotte
Type of Machine: Scissor Lift
Type of Manual: Service Manual, Repair Manual, Wiring Diagram, Hydraulic Diagram
Model: Haulotte OPTIMUM 8, OPTIMUM 1931 E Color Screen Display Scissor Lift
Part Number: 4001405210
Publication Date: 03.2026
Number of Pages: 246 Pages
Responsibilities and commitments
1 Foreword
2 Responsibilities
2.1 Owner's responsibility
2.1.1 Product modification
2.2 Technician's responsability
3 HAULOTTE® commitments
3.1 HAULOTTE Services®
3.2 Training
3.3 Product information
3.3.1 Implementing manufacturer safety campaigns
4 Conditions of warranty
Safety
1 General safety rules
1.1 Uncontrolled movement Hazard
1.2 Electric Shock Hazards
1.3 Explosion / Fire Hazards
2 Safety rules energy source motorization
2.1 General safety and specific interventions on energy storage
Familiarization
1 HAULOTTE Activ'Screen
1.1 LCD screen
2 List of actuators and sensors
2.1 Sensors and actuators
3 Consumables (Oils...)
3.1 Hydraulic oil
3.2 Gear motor oil
3.3 Cylinder storage oil
3.4 Grease
3.5 Marine protection
3.6 Consumables
4 Movement speed
Machine sheets
Machine sheets
MS0072 - Pressure adjustment
1 You will need
2 Preliminary operation
3 Pressure adjustment
4 Pressure plug location
MS0073 - Scissor arms screw-Periodical checks
1 You will need
2 Checks
3 Tightening the screws of the scissor arms
MS0084 - Removal / Replacement of motor reducer assembly
1 You will need
3 Plan of the assembly
4 Removal
5 Reinstall
6 Checks
MS0090 - Removal / replacement of steering pivot assembly
1 You will need
2 Plan of the assembly
3 Removal
4 Reinstall
5 Complementary operations
6 Checks
MS0095 - Removal / replacement of platform assembly
1 You will need
2 Level of knowledge required
3 Preliminary operation
4 Removal
5 Reinstall
6 Complementary operations
7 Checks
MS0096 - Removal / replacement of Scissor pack
1 You will need
3 Removal
4 Reinstall
6 Checks
MS0097 - Calibration steering
1 You will need
3 Level of knowledge required
4 Steering calibration procedure
5 Checks
MS0098 - Calibration Load management system
1 You will need
4 Load management calibration Procedure
5 Checks
MS0099 - Calibration arm angle sensors
1 You will need
4 Procedure of load management system calibration
5 Checks
MS0102 - Tires (Tyres) - Wheel replacement
1 You will need
3 Technical specifications
4 Wheel and tires/tyres inspections
5 Procedure of replacement
MS0106 - HAULOTTE Activ'Screen
1 You will need
2 Simplified menus
3 Detailed menus
3.1 Screen access code settings
3.1.1 Screen 0d
MS0133 - Universal plug
1 You will need
2 Procedure
MS0174 - Platform extension lock assembly
1 You will need
4 Procedure
5 Additional operations
6 Checks
MS0175 - Removal - Replacement of the motor/pump assembly
1 You will need
4 Removal
5 Reinstall
7 Checks
MS0176 - Hydraulic filter
1 You will need
4 Removal
5 Reinstall
7 Checks
MS0177 - Assembly electro-brake unit
1 You will need
4 Removal
5 Reinstall
7 Checks
MS0178 - Brake unit protection installation
1 You will need
4 Removal
4.1 Remove the counterweight
4.2 Treating a stuck brake
5 Reinstall
5.1 Installing the protection kit
5.2 Reinstall the counterweight
6 Checks
MS0179 - Assembly moto - reducer
1 You will need
4 Assembly
6 Checks
MS0242 - Check of tilt sensor
1 Warning
2 Risk prevention
3 You will need
4 Check of tilt sensor
MS0245 - Dismantling/Reassembling the Tilt Sensor
1 Warning
2 Risk prevention
3 You will need
4 Dis-assembly
5 Reassembly
6 Calibration
7 Additional operations
MS0283 - Assembly electro-brake unit (For the Asia-Pacific market only)
1 You will need
4 Removal
5 Reinstall
7 Checks
MS0314 - Maintenance implementation
1 Placing in configuration
MS0383 - Removal - Replacement of lithium-ion battery (For machines fitted with)
1 Warning
2 Risk prevention
3 You will need
4 Removal
Trouble shooting
1 Trouble shooting
1.1 Recommendations
1.2 Description
1.3 Requirements
1.4 Failures list
1.4.1 Failures list
1.4.2 List of failures per category
Electric and hydraulic diagrams
1 Wiring diagram
1.1 Electric diagram
2 Hydraulic diagram
2.1 Hydraulic diagram
Records
1 Intervention register
