Haulotte Scissor Lift OPTIMUM 8 OPTIMUM 1931 E Operators Manual 4001404750 03.2026 EN
Brand: Haulotte
Type of Machine: Scissor Lift
Model: Haulotte OPTIMUM 8, OPTIMUM 1931 E Color Screen Display Scissor Lift
Part Number: 4001404750
Publication Date: 03.2026
Number of Pages: 178 Pages
Foreword
1 Foreword
2 Responsibilities
2.1 Owner's Responsibility
2.2 Employer's Responsibility
2.3 Trainer's Responsibility
2.4 Operator's Responsibility
3 Safety
3.1 Safety Instructions
3.1.1 Incorrect Use
3.1.2 Falling Hazards
3.1.3 Overturning / Tip-Over Hazards
3.1.4 Risk Of Electric Shock (Electrocution)
3.1.5 Explosion / Fire Hazards
3.1.6 Crushing / Collision Hazards
3.1.7 Risk Of Involuntary Movements
4 Safety Inquiries
5 Incident Notification
6 Compliance
6.1 Product Modification
6.1.1 Implementing Manufacturer Safety Campaigns
6.2 Product Specifications
6.3 Change Of Ownership Notification
6.4 Declaration Of Conformity
6.4.1 Declaration Of Conformity - All Machines
6.4.2 Declaration Of Conformity - Electric Platforms
Familiarization
1 General Safety
1.1 Intended Use
1.2 Decal Content
1.3 Level Of Severity
1.4 Symbols Legend And Definitions
1.5 Symbols And Colors
2 Models Description
3 Primary Machine Components
3.1 Layout
3.2 Maintenance Support
3.3 Extension Deck
3.4 Ground Control Box - Service / Emergency Station
3.4.1 Layout
3.4.2 Haulotte Activ'screen
3.4.2.1 Lcd Screen
3.5 Platform Control Box - Main Station
3.5.1 Layout
4 Performance Specifications
4.1 Technical Characteristics
4.2 Working Area / Range Of Motion
5 Decals And Markings Locations
Pre-Operation Inspection
1 Recommendations
2 Working Area Assessment
3 Inspection And Functional Test
3.1 Daily Inspection
4 Safety Functional Checks
4.1 Emergency Stop Button Check
4.2 Activation Of Controls
4.3 Fault Detector
4.3.1 Buzzers Test
4.4 Overload Sensing System
4.5 Slope Warning Device
4.6 Travel Speed Limitation
4.7 Electronic Variable Speed Drive
4.8 Machine Braking
4.9 Wheel Motor Brake Release
4.10 Pothole Protection System
4.11 On-Board Charger (For Optimum 8 - Optimum 1931 E Only)
4.12 Anti-Crush System When Lowering
4.13 Braking Test
4.14 Overload Test
Operation Instructions
1 Operation
1.1 Introduction
1.2 Major Description
1.3 Operation From The Ground Control Box (Service / Emergency Station)
1.4 Operation From The Platform Control Box (Main Station)
2 Ground Control Box - Service / Emergency Station
2.1 To Start And Stop The Machine
2.2 Movement Control
2.3 Additional Controls From The Ground Control Box
3 Platform Control Box - Main Station
3.1 To Start And Stop The Machine
3.2 Drive And Steer Control
3.3 Movement Control
4 Rescue And Emergency Procedures
4.1 In Case Of Power Loss
4.2 To Rescue Operator In Platform
5 Transportation
5.1 Transport Configuration
5.2 Machine Stowage For Transport- Optimum 8 - Optimum 1931 E - Optimum 8 Li - Optimum 1931 E Li
5.3 Unloading
5.4 Towing
5.4.1 Free Wheel Mode
5.5 Storage
5.6 Loading By Ramp
5.7 Unloading By Ramp
5.8 Lifting Operation
5.9 Loading And Unloading With Forklift
6 Cold Weather Recommendations
6.1 Li-Ion Battery
6.2 Environmental Conditions
6.2.1 Hydraulic Oil
7 Battery Care And Maintenance (For Optimum 8 - Optimum 1931 E Only)
7.1 Battery Recharge
7.1.1 On-Board Charger
7.1.2 Battery Charging
7.2 Battery Care And Maintenance
7.2.1 Filling Batteries
7.2.1.1 Procedure To Fill The Batteries Manually–Option
7.2.1.2 Procedure To Fill The Batteries Automatically–Option
7.2.2 Desulfation Charge
7.3 Optimise Battery Life
8 Battery Care And Maintenance (For Optimum 8 Li - Optimum 1931 E Li Only - For Machines Equipped With The Lithium-Ion Battery Option)
8.1 Battery Recharge
8.1.1 On-Board Charger
8.1.2 Battery Charging
8.2 Optimise Battery Life
General Specifications
1 Machine Dimensions
2 Major Component Masses
3 Acoustics And Vibrations
4 Wheel/Tire Assembly
4.1 Technical Specifications
4.2 Inspection And Maintenance
4.2.1 Procedure Of Replacement
Maintenance
1 General
2 Maintenance Schedule
3 Inspection Program
3.1 General Program
3.2 Daily Inspection
3.3 Periodic Inspection
3.4 Reinforced Inspection
3.5 Major Inspection
4 Repairs And Adjustments
Options
1 Compatibility
2 Advanced Access Management - Access Control And Usage Restriction
2.1 Description
2.1.1 Access Control
2.1.2 Usage Restriction
2.1.3 Geofence
2.1.4 Timefence
2.1.5 Remote Restriction
2.2 Additional Functions
2.2.1 Access Control And Usage Restriction Combination
2.2.2 Tracker Default Function
2.3 Super User Status
2.4 Code For Removing Restrictions
2.5 Operation
2.5.1 Using A Machine With Access Control Enabled
2.5.2 Starting A Machine With Usage Restriction Enabled
3 Swing Gate
3.1 Description
3.2 Specifications
3.3 Safety Precautions
3.4 Pre-Operation Instructions
4 Folding Guardrails
4.1 Description
4.2 Safety Precautions
4.3 Fold Down Operation
4.4 Specific Decals
4.5 Raising Guardrails To Working Position
5 Pipe Holder Option
5.1 Description
5.2 Characteristics
5.3 Safety Precautions
5.4 Pre-Operation Inspection
5.5 Operation
5.6 Disassembly - Assembly
5.7 Specific Decals
6 Panel Carrier
6.1 Description
6.2 Characteristics
6.3 Safety Precautions
6.4 Pre-Operation Inspection
6.5 Operation
6.6 Disassembly - Assembly
6.7 Specific Decals
7 Sgs - Secondary Guarding System
7.1 Foreword
7.2 Safety Precautions
7.3 Familiarization
7.4 How The System Works
7.5 Inspecting The System Before Using The Machine
7.6 Operating And Using The Sgs
7.7 Evacuation Procedure If The Operator Is Crushed Or Loses Consciousness
8 Extra Step
8.1 Description
8.2 Characteristics
8.3 Safety Precautions
8.4 Pre-Operation Inspection
8.5 Assembly - Disassembly
8.5.1 Assembling The Guardrail Assembly
8.5.1.1 Assembling The Fixed Guardrails
8.5.1.2 Installing The Hinges
8.5.1.3 Installing The Access Gates And Accessories
8.5.2 Assembly Of The Lower Platform And Platform Support Bracket Assemblies
8.5.2.1 Inner Platform Assembly
8.5.2.2 Platform Support Bracket Assembly
8.5.2.3 Assembling The Basket Support Bracket
8.5.2.4 Installing The Basket Support Bracket Assembly On The Machine
8.5.2.5 Installing The Guardrail Assembly
8.5.2.6 Installing The Floor And Step
8.5.2.7 Checks
8.5.2.8 Switching From Raised To Lowered Position
8.5.2.9 Dis-Assembly
8.6 Specific Decals
Other Information
1 Conditions Of Warranty
2 Subsidiary Contact Information
Records
1 Intervention Register
Brand: Haulotte
Foreword
1 Foreword
2 Responsibilities
3 Safety
3.1.1 Incorrect Use
4 Safety Inquiries
6 Compliance
Familiarization
1 General Safety
1.1 Intended Use
1.2 Decal Content
3.1 Layout
3.3 Extension Deck
3.4.1 Layout
3.4.2.1 Lcd Screen
3.5.1 Layout
1 Recommendations
4.3 Fault Detector
4.3.1 Buzzers Test
4.8 Machine Braking
4.13 Braking Test
4.14 Overload Test
1 Operation
1.1 Introduction
5 Transportation
5.3 Unloading
5.4 Towing
5.5 Storage
5.6 Loading By Ramp
6.1 Li-Ion Battery
6.2.1 Hydraulic Oil
Maintenance
1 General
3.1 General Program
Options
1 Compatibility
2.1 Description
2.1.3 Geofence
2.1.4 Timefence
2.5 Operation
3 Swing Gate
3.1 Description
3.2 Specifications
4.1 Description
4.4 Specific Decals
5.1 Description
5.2 Characteristics
5.5 Operation
5.7 Specific Decals
6 Panel Carrier
6.1 Description
6.2 Characteristics
6.5 Operation
6.7 Specific Decals
7.1 Foreword
7.3 Familiarization
8 Extra Step
8.1 Description
8.2 Characteristics
8.5.2.7 Checks
8.6 Specific Decals
Other Information
Records
- Haulotte Articulated Boom Lift 4527A, HTA 16P Parts and Service Manual
- Haulotte Bil-Jax Articulated Boom Lift 5533A Parts and Service Manual
- Haulotte Scissor Lift Compact 8 Parts Manual
- Haulotte HA20PX HA26PX Self Propelled LIft Repair Manual
- Haulotte Articulated Boom Lift HA15IP-HA43JE Parts Manual_2420339510
- Haulotte Scissor Lift Compact 10, 2747E Parts Manual
- Haulotte 4527A HTA 16P Part Manual
- Haulotte Articulated Boom Lift HA16PX-HA18PX Parts Manual_2420344550
- Haulotte Scissor Lift Optimum 6, Optimum 8 Parts Manual
- Haulotte OPTIMUM 8 - 1931E_E04.20 Part Manual
- Haulotte Scissor Lift Optimum 1530E, 1930E Repair Manual_2420318690
- Haulotte Articulated Boom Lift HA20PX, HA80JRT Parts Manual_2420340850
- Haulotte Telescopic Boom HT21TX-HB62 Parts Manual_2420311040
- Haulotte Self Propelled Scissor Optimum 6,8 Operating and Maintenance Instructions
- Haulotte Articulated Boom Lift HA18-HA51 Parts Manual_4000415260
