Haulotte Scissor Lift HS21E to HS6395E PRO Operators Manual 4001367990 01.2026 EN
Brand: Haulotte
Type of Machine: Scissor Lift
Model: Haulotte HS21E, HS6395E, HS21E PRO, HS6395E PRO Touch Screen Display Scissor Lift
Part Number: 4001367990
Publication Date: 01.2026
Number of Pages: 234 Pages
1 Foreword
2 Responsibilities
2.1 Owner's responsibility
2.2 Employer's responsibility
2.3 Trainer's responsibility
2.4 Operator's responsibility
3 Safety
3.1 Safety instructions
3.1.1 Incorrect use
3.1.2 Falling Hazards
3.1.3 Overturning / Tip-over Hazards
3.1.4 Risk of shock (electrocution)
3.1.5 Explosion / Fire Hazards
3.1.6 Crushing / Collision Hazards
3.1.7 Risk of involuntary movements
4 Safety inquiries
5 Incident notification
6 Compliance
6.1 Product modification
6.1.1 Implementing manufacturer safety campaigns
6.2 Product specifications
6.3 Change of Ownership Notification
6.4 Declaration of conformity
6.4.1 Declaration of conformity - All machines
6.4.2 Declaration of conformity - platforms
Familiarization
1 General safety
1.1 Intended use
1.2 Decal content
1.3 Level of severity
1.4 Symbols legend and definitions
1.5 Symbols and colors
2 Primary machine components
2.1 Layout
2.2 Maintenance support
2.3 Ground control box - Service / Emergency station
2.3.1 Layout - Touch screen display
2.3.2 Touch screen display
2.4 Platform control box - Main station
2.4.1 Layout
2.4.2 Screen
3 Performance Specifications
3.1 Technical characteristics
3.2 Working area / Range of motion
4 Decals and markings locations
Pre-operation inspection
1 Recommendations
2 Working area assessment
3 Inspection and Functional test
3.1 Daily inspection
4 Safety functional checks
4.1 Emergency Stop button check
4.2 Activation of controls
4.3 Fault detector
4.3.1 Indicators/LED's test
4.3.2 Buzzers test
4.4 Automatic engine cut-out (If machine equipped with the option Range Extender)
4.5 Overload sensing system
4.6 Slope warning device
4.7 Machine braking
4.8 Travel speed limitation
4.9 On-board electronics
4.10 Anti-crush system when lowering
4.11 Braking test
4.12 Overload test
Operation instructions
1 Operation
1.1 Introduction
1.2 Major description
1.3 Operation from the ground control box (Service / Emergency station)
1.4 Operation from the platform control box (Main station)
1.5 Mode operation
1.5.1 Full mode (If machine equipped with the option Range Extender)
1.5.2 Auto mode (If machine equipped with the option Range Extender)
1.5.3 Forced engine mode (If machine equipped with the option Range Extender)
2 Ground control box - Service / Emergency station
2.1 To start and stop the machine
2.2 Movement control
2.3 Additional controls
3 Platform control box - Main station
3.1 To start and stop the machine
3.1.1 To start the machine
3.1.2 To stop the engine
3.2 Drive and steer control
3.3 Movement control
3.4 Additional controls
3.4.1 Activ' Lighting System
4 Rescue and emergency procedures
4.1 In case of power loss
4.2 To rescue operator in platform
4.2.1 Operation of overriding system from ground control box
4.3 No power available
4.3.1 Manual emergency lowering procedure
5 Transportation
5.1 Transport configuration
5.2 Machine stowage for transport
5.3 Loading by ramp
5.4 Folding guardrails
5.4.1 Description
5.4.2 Safety precautions
5.4.3 Guardrail folding procedure
5.4.4 Fitting guardrails in working position
5.5 Unloading
5.5.1 Unloading by ramp
5.6 Towing
5.6.1 Manual brake release
5.7 Storage
5.8 Lifting operation
5.8.1 Procedure for the use of slings HS21E - HS6395E - HS21E PRO - HS6395E PRO
6 Cold Weather Recommendations
6.1 Hydraulic oil
6.2 Li-ion battery
7 Battery care and maintenance (For machines equipped with the lithium-ion battery option)
7.1 Battery recharge
7.1.1 On-board charger
7.1.2 Battery charging
7.2 Optimise battery life
General Specifications
1 Machine dimensions
2 Major component masses
3 Acoustics and vibrations
4 Wheel/Tire assembly
4.1 Technical specifications
4.2 Inspection and maintenance
Maintenance
1 General
2 Maintenance Schedule
3 Inspection program
3.1 General program
3.2 Daily inspection
3.3 Periodic inspection
3.4 Reinforced inspection
3.5 Major inspection
4 Repairs and adjustments
Options
1 Compatibility
2 Advanced Access Management - Access control and usage restriction
2.1 Description
2.1.1 Access control
2.1.2 Usage restriction
2.1.3 GEOFENCE
2.1.4 TIMEFENCE
2.1.5 Remote restriction
2.2 Additional functions
2.2.1 Access control and usage restriction combination
2.2.2 tracker default function
2.3 SUPER USER status
2.4 Code for removing restrictions
2.5 Operation
2.5.1 Using a machine with access control enabled
2.5.2 Starting a machine with usage restriction enabled
3 Range Extender
3.1 Description
3.2 Characteristics
3.3 Safety precautions
3.4 Pre-operation inspection
3.5 Installing / Removing the Range Extender
3.6 Specific decals
4 Fast Charge
4.1 Description
4.3 Specifications
4.4 Operation
5 Plate holder/Tube holder
5.1 Description
5.2 Characteristics
5.2.1 Plate holder usage
5.2.2 Tube holder usage
5.3 Safety precautions
5.4 Pre-operation inspection
5.5 Disassembly - Assembly
5.6 Operation
5.6.1 Plate/panel holder version
5.6.2 Tube/pipe holder version
5.7 Strapping (Strap not provided)
5.8 Storage of the supports on the platform
5.9 Folding guardrails if machine equipped with plate/tube holder support
6 Activ’Shield Bar Scissors - Secondary guarding system (if the function is present and the device is installed in its support)
6.1 Description
6.2 Characteristics
6.3 Safety precautions
6.4 Pre-operation inspection
6.5 Operation
6.5.1 Travel speed limitation (Activ’Shield Bar Scissors option)
6.5.2 Raising speed limitation (Activ’Shield Bar Scissors option)
6.6 Specific decals
6.7 Insert the console into its support
7 Central tube holder
7.1 Description
7.2 Characteristics
7.3 Safety precautions
7.4 Pre-operation inspection
7.5 Disassembly - Assembly
7.6 Strapping (Supplied strap)
7.7 Storage
7.8 Folding guardrails if machine equipped with plate/tube holder support
Other information
1 Conditions of warranty
2 Subsidiary contact information
2.1 California warning
Records
1 Intervention register
Brand: Haulotte
1 Foreword
2 Responsibilities
3 Safety
3.1.1 Incorrect use
4 Safety inquiries
6 Compliance
Familiarization
1 General safety
1.1 Intended use
1.2 Decal content
2.1 Layout
2.4.1 Layout
2.4.2 Screen
1 Recommendations
4.3 Fault detector
4.3.2 Buzzers test
4.7 Machine braking
4.11 Braking test
4.12 Overload test
1 Operation
1.1 Introduction
1.5 Mode operation
5 Transportation
5.3 Loading by ramp
5.4.1 Description
5.5 Unloading
5.6 Towing
5.7 Storage
6.1 Hydraulic oil
6.2 Li-ion battery
Maintenance
1 General
3.1 General program
Options
1 Compatibility
2.1 Description
2.1.3 GEOFENCE
2.1.4 TIMEFENCE
2.5 Operation
3 Range Extender
3.1 Description
3.2 Characteristics
3.6 Specific decals
4 Fast Charge
4.1 Description
4.3 Specifications
4.4 Operation
5.1 Description
5.2 Characteristics
5.6 Operation
6.1 Description
6.2 Characteristics
6.5 Operation
6.6 Specific decals
7.1 Description
7.2 Characteristics
7.7 Storage
Other information
Records
- Haulotte Articulated Boom Lift 4527A, HTA 16P Parts and Service Manual
- Haulotte Bil-Jax Articulated Boom Lift 5533A Parts and Service Manual
- Haulotte Scissor Lift Compact 8 Parts Manual
- Haulotte HA20PX HA26PX Self Propelled LIft Repair Manual
- Haulotte Articulated Boom Lift HA15IP-HA43JE Parts Manual_2420339510
- Haulotte Scissor Lift Compact 10, 2747E Parts Manual
- Haulotte 4527A HTA 16P Part Manual
- Haulotte Articulated Boom Lift HA16PX-HA18PX Parts Manual_2420344550
- Haulotte Scissor Lift Optimum 6, Optimum 8 Parts Manual
- Haulotte OPTIMUM 8 - 1931E_E04.20 Part Manual
- Haulotte Scissor Lift Optimum 1530E, 1930E Repair Manual_2420318690
- Haulotte Articulated Boom Lift HA20PX, HA80JRT Parts Manual_2420340850
- Haulotte Telescopic Boom HT21TX-HB62 Parts Manual_2420311040
- Haulotte Self Propelled Scissor Optimum 6,8 Operating and Maintenance Instructions
- Haulotte Articulated Boom Lift HA18-HA51 Parts Manual_4000415260
