Momed80
150
35,046
Haulotte Scissor Lift HS15E to HS5390E PRO Operators Manual 4001074390 02.2021 EN
Brand: Haulotte
Type of Machine: Electric Scissor Lift
Model: Haulotte HS15E, HS4390E, HS15E PRO, HS4390E PRO, HS18E -HS5390E, HS18E PRO, HS5390E PRO Scissor Lift
Part Number: 4001074390
Publication Date: 02.2021
Number of Pages: 192 Pages
A - Foreword
1 - User Responsibility
1.1 - Owner’s Responsibility
1.2 - Employer’s Responsibility
1.3 - Trainer’s Responsibility
1.4 - Operator’s Responsibility
2 - Safety
2.1 - Safety Instructions
2.1.1 - Misuse Hazards
2.1.2 - Falling Hazards
2.1.3 - Overturning / Tip-Over Hazards
2.1.4 - Electric Shock Hazards
2.1.5 - Explosion / Fire Hazards
2.1.6 - Crushing / Collision Hazards
2.1.7 - Uncontrolled Movement Hazards
3 - Safety Inquiries
4 - Incident Notification
5 - Compliance
5.1 - Product Modification
5.1.1 - Implementing Manufacturer Safety Campaigns
5.2 - Product Specifications
5.3 - Change Of Ownership Notification
5.4 - Declaration Of Conformity
B - Familiarization
1 - General Safety
1.1 - Intended Use
1.2 - Decal Content
1.3 - Symbols And Colors
1.4 - Level Of Severity
1.5 - Symbols Legend And Definitions
2 - Models Description
3 - Primary Machine Components
3.1 - Layout
3.2 - Maintenance Support
3.3 - Ground Control Box
3.3.1 - Layout
3.3.1.1 - Haulotte Activ'screen 2
3.3.1.2 - Maintenance Counter Reset
3.4 - Platform Control Box
3.4.1 - Layout
4 - Performance Specifications
4.1 - Technical Characteristics
4.2 - Working Area / Range Of Motion
5 - Decals And Markings Locations
C - Pre-Operation Inspection
1 - Recommendations
2 - Working Area Assessment
3 - Inspection And Functional Test
3.1 - Daily Inspection
4 - Safety Functional Checks
4.1 - E-Stop Button Check
4.2 - Activation Of Controls
4.3 - Fault Detector
4.3.1 - Indicators/Led's Test
4.3.2 - Buzzers Test
4.4 - Automatic Engine Cut-Out (If Machine Equipped With The Option Range Extender)
4.5 - Oscillating Axles (If Equipped)
4.6 - Slope Warning Device
4.7 - Travel Speed Limitation
4.8 - On-Board Electronics
D - Operation Instructions
1 - Operation
1.1 - Introduction
1.2 - Major Description
1.3 - Operation From The Ground Control Box
1.4 - Operation From The Platform Control Box
1.5 - Mode Operation
1.5.1 - Full Electric Mode (If Machine Equipped With The Option Range Extender)
1.5.2 - Auto Mode (If Machine Equipped With The Option Range Extender)
1.5.3 - Forced Engine Mode (If Machine Equipped With The Option Range Extender)
1.5.4 - Overview Of Mode Operation
2 - Ground Control Box
2.1 - To Start And Stop The Machine
2.2 - Movement Control
2.3 - Additional Controls
3 - Platform Control Box
3.1 - To Start And Stop The Machine
3.1.1 - To Start The Machine
3.1.2 - To Stop The Engine
3.2 - Drive And Steer Control
3.3 - Movement Control
3.4 - Additional Controls
3.4.1 - Activ' Lighting System
4 - Rescue And Emergency Procedures
4.1 - In Case Of Power Loss
4.2 - To Rescue Operator In Platform
4.2.1 - Operation Of Overriding System From Ground Control Box
4.3 - No Power Available
4.3.1 - Manual Emergency Lowering Procedure
5 - Transportation
5.1 - Putting In Transport Position
5.2 - Machine Layout - Hs15 E (Hs4390 E) - Hs15 E Pro (Hs4390 E Pro) - Hs18 E (Hs5390 E) - Hs18 E Pro (Hs5390 E Pro)
5.3 - Loading By Ramp
5.4 - Folding Guardrails
5.4.1 - Description
5.4.2 - Safety Precautions
5.4.3 - Fold Down Operation
5.4.4 - Raising Guardrails To Working Position
5.5 - Unloading
5.5.1 - Unloading By Ramp
5.6 - Towing
5.6.1 - Brake Release
5.7 - Storage
5.8 - Lifting Operation
5.8.1 - Procedure For The Use Of Slings Hs15 E (Hs4390 E) - Hs15 E Pro (Hs4390 E Pro) - Hs18 E (Hs5390 E) - Hs18 E Pro (Hs5390 E Pro)
6 - Cold Weather Recommendations
6.1 - Hydraulic Oil
7 - Battery Care And Maintenance
7.1 - Locations
7.2 - Battery Recharge
7.2.1 - On-Board Charger
7.2.2 - Battery Charging
7.3 - Battery Care And Maintenance
7.3.1 - Filling Batteries
7.3.1.1 - Procedure To Fill The Batteries Manually
7.3.1.2 - Procedure To Fill The Batteries Automatically – Option
7.3.2 - Desulfation Charge
7.4 - Optimise Battery Life
E - General Specifications
1 - Machine Dimensions
2 - Major Component Masses
3 - Acoustics And Vibrations
4 - Wheels
4.1 - Technical Specifications
4.2 - Inspection And Maintenance
5 - Options
5.1 - Activ'shield Bar Scissors - Secondary Guarding System (If The Function Is Present And The Device Is Installed In Its Support)
5.1.1 - Description
5.1.1.1 - Summary Of The Indicator States
5.1.2 - Characteristics
5.1.3 - Safety Precautions
5.1.4 - Pre-Operation Inspection
5.1.5 - Operation
5.1.5.1 - Travel Speed Limitation (Activ'shield Bar Scissors Option)
5.1.5.2 - Raising Speed Limitation (Activ'shield Bar Scissors Option)
5.1.6 - Specific Decals
5.1.7 - Insert The Console Into Its Support
5.2 - Range Extender
5.2.1 - Description
5.2.2 - Characteristics
5.2.3 - Safety Precautions
5.2.4 - Pre-Operation Inspection
5.2.5 - Installing / Removing The Range Extender
5.2.6 - Specific Decals
5.3 - Fast Charge
5.3.1 - Description
5.3.2 - Safety Precautions
5.3.3 - Specifications
5.3.4 - Operation
F - Maintenance
1 - General
2 - Maintenance Schedule
3 - Inspection Program
3.1 - General Program
3.2 - Daily Inspection
3.3 - Periodic Inspection
3.4 - Reinforced Inspection
3.5 - Major Inspection
4 - Repairs And Adjustments
G - Other Information
1 - Conditions Of Warranty
2 - Subsidiary Contact Information
2.1 - California Warning
H - Intervention Register
1 - Intervention Register
