Momed80
150
35,046
Haulotte Scissor Lift HS15E to HS5390E MAX Service Repair Manual 4001309460 06.2025 EN
Brand: Haulotte
Type of Machine: Scissor Lift
Type of Manual: Service Manual, Repair Manual, Wiring Diagram, Hydraulic Diagram
Model: Haulotte HS15E, HS4390E, HS15E PRO, HS4390E PRO, HS18E, HS5390E, HS18E PRO, HS5390E PRO, HS18E MAX, HS5390E MAX Touch Screen Display Scissor Lift
Part Number: 4001309460
Publication Date: 06.2025
Number of Pages: 460 Pages
Responsibilities And Commitments
1 Foreword
2 Responsibilities
3 Haulotte Commitments
4 Conditions Of Warranty
Safety
1 General Safety Rules
2 Safety Rules Energy Source Motorization
Familiarization
1 Touch Screen Display
2 List Of Actuators And Sensors
3 Consumables (Oils...)
4 Movement Speed
Machine Sheets
Machine Sheets
Ms0001, Structural Part Inspection
Ms0002, Pins And Bearing Inspection
Ms0003, Cylinder Inspection
Ms0004, Braking Test Procedure
Ms0133, Universal Plug
Ms0163, Lock-Out Procedure
Ms0311, Replacing The Rod Of The Activ’shield Bar Scissors System
Ms0312, Replacing The Spring Of The Activ’shield Bar Scissors System
Ms0313, Replacing The Guide Shoes Of The Activ’shield Bar Scissors System
Ms0314, Maintenance Implementation
Ms0315, Removing, Reinstalling The Scissors Lifting Cylinder - High
Ms0316, Removing, Reinstalling The Scissors Lifting Cylinder-Low
Ms0317, Removal / Replacement Of Platform Assembly
Ms0318, Removal, Replacement Of The Range Extender
Ms0319, Removal, Reinstallation Of The Platform Extension
Ms0320, Removal-Reinstallation Of The Stabiliser Cylinder
Ms0321, Removal, Reinstallation Of The Oscillating Axle Locking Cylinder
Ms0322a, Removal, Reinstallation Of The Front Axle
Ms0322b, Removal, Reinstallation Of The Front Axle
Ms0323a, Removal, Reinstallation Of The Rear Axle
Ms0323b, Removal, Reinstallation Of The Rear Axle
Ms0324, Dismantling/Reassembling The Tilt Sensor
Ms0325, Removal, Reinstallation Of The Scissor Arm Assembly
Ms0326, Removal, Reinstallation Of The Scissor Arm Lower Pads
Ms0327, Dismantling/Reassembling The Strain Gauge
Ms0328, Removal, Reinstallation Of The Chargers (Main And Fast Charge)
Ms0329a, Removal, Replacement Of Drive Motor
Ms0330a, Removal, Reinstallation Of The Pump Or Drive Motor Alone Or Pump Alone
Ms0331, Remove, Reinstall The Drive Shaft
Ms0332, Replacing The Chassis/Platform Wiring Harnesses (Wiring Harness Can, Cable 220v, Als)
Ms0333, Removal, Reinstallation Of The Battery Compartment Or Battery By Battery
Trouble Shooting
1 Trouble Shooting
2 Legend
And Hydraulic Diagrams
1 Wiring Diagram
2 Hydraulic Diagram
Records
1 Intervention Register
