Momed80
151
35,863
Haulotte Scissor Lift C10N C12 C14 Service Repair Manual 4001334430 07.2024 EN
Brand: Haulotte
Type of Machine: Scissor Lift
Type of Manual: Service Manual, Repair Manual, Wiring Diagram, Hydraulic Diagram
Model: Haulotte C10N, C12, C14 Scissor Lift
Part Number: 4001334430 AU
Publication Date: 07.2024
Number of Pages: 182 Pages
Responsibilities And Commitments
1 Foreword
2 Responsibilities
2.1 Owner's Responsibility
2.1.1 Product Modification
2.2 Technician's Responsability
3 Haulotte® Commitments
3.1 Haulotte Services®
3.2 Training
3.3 Product Information
3.3.1 Implementing Manufacturer Safety Campaigns
4 Conditions Of Warranty
Safety
1 General Safety Rules
1.1 Uncontrolled Movement Hazard
1.2 Electric Shock Hazards
1.3 Explosion / Fire Hazards
2 Safety Rules Energy Source Motorization
2.1 General Safety And Specific Interventions On Energy Storage
Familiarization
1 Screen
1.1 Display
2 List Of Actuators And Sensors
2.1 Sensors And Actuators
3 Consumables (Oils...)
3.1 Hydraulic Oil
3.2 Cylinder Storage Oil
3.3 Grease
3.4 Marine Protection
3.5 Consumables
4 Movement Speed
Machine Sheets
Machine Sheets
Ms0001 - Structural Part Inspection
1 Warning
2 Risk Prevention
3 You Will Need
4 Control And Maintenance
4.1 Daily Inspection
4.2 Major Inspection
4.3 Functional Tests
4.4 Dynamic Tests
4.5 Structural Test
Ms0002 - Pins And Bearing Inspection
1 Warning
2 Risk Prevention
3 You Will Need
5 Criteria Of Replacement
6 Procedure Of Reassembly
6.1 Pins And Bushes
6.2 Bearings
Ms0003 - Cylinder Inspection
1 Warning
2 Risk Prevention
3 You Will Need
4.1 Visual Inspections
4.2 Functional Tests
4.3 Major Inspection
Ms0004 - Braking Test Procedure
1 Warning
2 Risk Prevention
3 You Will Need
4 Test Procedure
Ms0005 - Torque Values
1 Metric Torque Chart
2 Sae Fastener Torque Chart
3 Hydraulic Couplings And Hoses Tightening Torque Charts
Ms0020 - Hoses Inspection - Replacement
1 You Will Need
2 Control And Inspections
3 Hoses Disassembling
4 Hoses Reassembly
Ms0314 - Maintenance Implementation
1 Placing In Configuration
Ms0462 - Rear Wheel Disassembly/Assembly
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
6 Re-Installation
Ms0463 - Brake Disassembly/Assembly
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
6 Re-Installation
Ms0464 - Wheel Steering Pivot Disassembly/Assembly
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
6 Re-Installation
Ms0465 - Removal - Replacement Of The Steering Cylinder
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
6 Re-Installation
Ms0466 - Motor Pump Unit Disassembly/Assembly
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
6 Re-Installation
Ms0467 - Replacing The Carbon Contacts Of The Motor Pump Unit
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
6 Re-Installation
Ms0468 - Variable Speed Drive Disassembly/Assembly
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
6 Re-Installation
Ms0469 - Pothole Cylinder Removal/Refitting
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
6 Re-Installation
Ms0470 - Removal - Replacement Of Semi-Traction Batteries
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
Ms0471 - Removal - Replacement Of On-Board Charger
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
6 Re-Installation
Ms0472 - Removal - Reinstallation Of The Platform Extension
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
6 Re-Installation
Ms0473 - Removal / Replacement Of Platform Assembly
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
6 Re-Installation
Ms0474 - Remove - Replace Arm Assembly
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
6 Re-Installation
Ms0475 - Removing/Refitting The Top Lifting Cylinder
1 Concerned Machines
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Removal
7 Re-Installation
Ms0476 - Removing/Refitting The Bottom Lifting Cylinder
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
6 Re-Installation
Ms0477 - Removing/Refitting The External Arm
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
6 Re-Installation
Ms0478 - Removing/Refitting The Arm Wiring Harness
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
6 Re-Installation
Ms0479 - Remove/Re-Install The Hydraulic Motor
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
6 Re-Installation
Trouble Shooting
1 Trouble Shooting
1.1 Recommendations
1.2 Failures List
1.2.1 Failures Codes
Electric And Hydraulic Diagrams
1 Wiring Diagram
1.1 Electric Diagram
2 Hydraulic Diagram
2.1 Hydraulic Diagram
Records
1 Intervention Register
