Haulotte Articulating Boom Lift HA32RTJ PRO to HA130RTJ PRO Operators Manual 4001323860 08.2025 EN
Momed80
150
35,046
Brand: Haulotte
Type of Machine: Articulating Boom Lift
Model: Haulotte HA32RTJ PRO, HA100RTJ PRO, HA41RTJ PRO, HA130RTJ PRO Articulating Boom Lift
Part Number: 4001323860
Publication Date: 08.2025
Number of Pages: 160 Pages
Contents
Foreword
1 Foreword
2 Responsibilities
2.1 Owner's responsibility
2.2 Employer's responsibility
2.3 Trainer's responsibility
2.4 Operator's responsibility
3 Safety
3.1 Safety instructions
4 Safety inquiries
5 Incident notification
6 Compliance
6.1 Product modification
6.2 Product specifications
6.3 Change of Ownership Notification
6.4 Declaration of conformity
Familiarization
1 General safety
1.1 Intended use
1.2 Decal content
1.3 Level of severity
1.4 Symbols legend and definitions
1.5 Symbols and colors
2 Models description
3 Primary machine components
3.1 Layout
3.2 Ground control box - Service/Emergency station
3.3 Platform control box - Main station
3.4 DPF (Diesel Particle Filter) (If equipped - Deutz 2,2 TDC engine only)
3.5 Axle extension control box
4 Performance Specifications
4.1 Technical characteristics
4.2 Engine specifications
4.3 Working area / Range of motion
5 Decals and markings locations
Pre-operation inspection
1 Recommendations
2 Working area assessment
3 Inspection and Functional test
3.1 Daily inspection
4 Safety functional checks
4.1 Emergency Stop button check
4.2 Activation of controls
4.3 Fault detector
4.4 Automatic engine cut-out
4.5 Overload sensing system
4.6 Oscillating axles
4.7 Slope warning device
4.8 Travel speed limitation
4.9 Movement speed
4.10 On-board electronics
4.11 Radius limitation
4.12 Axle extension
4.13 Drive buzzer
4.14 Boom control system
4.15 Braking test
4.16 Overload test
Operation instructions
1 Operation
1.1 Introduction
1.2 Major description
1.3 Operation from the ground control box (Service/Emergency station)
1.4 Operation from the platform control box (Main station)
2.1 To start and stop the machine
2.2 Movement control
2.3 Additional controls from the ground control box
3.1 To start and stop the machine
3.2 Drive and steer control
3.3 Movement control
3.4 Additional controls
4 Axle extension control box
4.1 Prepare the machine
4.2 Axle extension operation
4.3 Axle retraction operation
5 Link piece position check
6 Radius limitation
6.1 Principle
6.2 Procedure
7 Rescue and emergency procedures
7.1 In case of power loss
7.2 To rescue operator in platform
7.3 Operation of overriding system from ground control box
7.4 No power available
8 Transportation
8.1 Transport configuration
8.2 Machine stowage for transport- HA32RTJ PRO - HA100RTJ PRO - HA41RTJ PRO - HA130RTJ PRO
8.3 Unloading
8.4 Towing
8.5 Storage
8.6 Lifting operation
9 Cold Weather Recommendations
9.1 Engine oil
9.2 Hydraulic oil
9.3 Preheating operation
General Specifications
1 Machine dimensions
2 Major component masses
3 Acoustics and vibrations
4 Wheel/Tire assembly
4.1 Technical specifications
4.2 Inspection and maintenance
5 Options
5.1 Compatibility
5.2 Platform
5.3 On-board generator
5.4 Welder's kit
5.5 Plumber's kit
5.6 Activ' Shield Bar - Secondary crush risk reduction system (If fitted)
Maintenance
1 General
2 Maintenance Schedule
3 Inspection program
3.1 General program
3.2 Daily inspection
3.3 Periodic inspection
3.4 Reinforced inspection
3.5 Major inspection
4 Repairs and adjustments
Other information
1 Conditions of warranty
2 Subsidiary contact information
2.1 California warning
Records
1 Intervention register
