Haulotte Articulating Boom Lift HA26 RTJ O to HA80 RTJ PRO Service Repair Manual 4001319010 08.2025 EN
Momed80
151
35,863
Brand: Haulotte
Type of Machine: Articulating Boom Lift
Type of Manual: Service Manual, Repair Manual, Wiring Diagram, Hydraulic Diagram
Model: Haulotte HA26 RTJ O, HA26 RTJ O SW, HA26 RTJ PRO, HA26 RTJ, PRO SW, HA80 RTJ O, HA80 RTJ PRO Color Screen Display Articulating Boom Lift
Part Number: 4001319010
Publication Date: 08.2025
Number of Pages: 352 Pages
Responsibilities And Commitments
1 Foreword
2 Responsibilities
2.1 Owner's Responsibility
2.2 Technician's Responsability
3 Haulotte® Commitments
3.1 Haulotte Services®
3.2 Training
3.3 Product Information
4 Conditions Of Warranty
Safety
1 General Safety Rules
1.1 Uncontrolled Movement Hazard
1.2 Electric Shock Hazards
1.3 Explosion / Fire Hazards
2 Safety Rules Energy Source Motorization
2.1 General Safety And Specific Interventions On The Thermal Engine
Familiarization
1 Haulotte Activ'screen 2
2 List Of Actuators And Sensors
2.1 Sensors And Actuators
3 Consumables (Oils - Fuels - Engine Oil - Coolant Level...)
3.1 Fuel
3.2 Engine Oil
3.3 Hydraulic Oil
3.4 Gear Motor Oil
3.5 Coolant
3.6 Cylinder Storage Oil
3.7 Grease
3.8 Marine Protection
3.9 Consumables
4 Movement Speed
Machine Sheets
Machine Sheets
Ms0001, Structural Part Inspection
1 Warning
2 Risk Prevention
3 You Will Need
4 Control And Maintenance
Ms0002, Pins And Bearing Inspection
1 Warning
2 Risk Prevention
3 You Will Need
5 Criteria Of Replacement
6 Procedure Of Reassembly
Ms0003, Cylinder Inspection
1 Warning
2 Risk Prevention
3 You Will Need
Ms0004, Braking Test Procedure
1 Warning
2 Risk Prevention
3 You Will Need
4 Test Procedure
Ms0005, Torque Values
1 Metric Torque Chart
2 Sae Fastener Torque Chart
3 Hydraulic Couplings And Hoses Tightening Torque Charts
4 Ha26 Rtj O, Ha26 Rtj Pro, Ha80 Rtj O, Ha80 Rtj Pro
Ms0009, Fuel Tank - Filling-Up
1 Warning
2 Risk Prevention
3 You Will Need
4 Consumable
5 Filling
Ms0020, Hoses Inspection - Replacement
1 You Will Need
2 Control And Inspections
3 Hoses Disassembling
4 Hoses Reassembly
Ms0029a, Kubota Diesel Engine
1 Product Information
2 Localization Identification Plate
3 Names Of Parts
4 Operating The Engine
5 Maintenance
6 Periodic Service
7 Carriage And Storage
8 Troubleshooting
Ms0029b, Kohler Diesel Engine
1 Localization Identification Plate
2 Names Of Parts
3 Operating The Engine
4 Maintenance
5 Fuel
6 Oil
7 Anti-Freeze
8 Carriage And Storage
9 Troubleshooting
Ms0029d, Perkins Diesel Engine
2 Safety Precautions
3 Technical Specifications
4 Names Of Parts
5 Operating The Engine
6 Maintenance
7 Fuel
8 Oil
9 Anti-Freeze
10 Carriage And Storage
11 Troubleshooting
Ms0031, Overload System
1 You Will Need
2 Level Of Knowledge Required
3 Safety Instructions
4 Periodic Inspection
5 Calibration Procedure
6 Checks
Ms0119, Remove/Re-Install The Hydraulic Motor
1 You Will Need
2 Preliminary Operation
3 Removal
4 Re-Installation
5 Additional Operations
Ms0123, Wheel Replacement
1 You Will Need
4 Wheel And Tires/Tyres Inspections
5 Wheel Replacement
6 Bronze Washer Replacement
Ms0133, Universal Plug
1 You Will Need
2 Procedure
Ms0137, Remove/Re-Install The Harness Bus Can
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
6 Re-Installation
7 Additional Operations
Ms0138, Remove/Re-Install The Main Counterweights
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
6 Re-Installation
Ms0139, Remove, Replace Arm Assembly
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
6 Re-Installation
Ms0140, Remove, Replace Boom Assembly
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
6 Re-Installation
Ms0141, Removing / Replacing The Pads
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
6 Re-Installation
Ms0142, Remove, Replace Boom Cylinder
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
6 Re-Installation
Ms0143, Remove/Re-Install Output Compensation Cylinder
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
6 Re-Installation
Ms0144, Remove/Re-Install Input Compensation Cylinder
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
6 Re-Installation
Ms0145, Remove, Replace Arm Cylinder
1 Warning
2 Risk Prevention
3 You Will Need
4 Removing The Cylinder
5 Re-Installing The Cylinder
6 Additional Operations
Ms0146, Remove, Replace Telescope Cylinder
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removing The Cylinder
6 Re-Installing The Cylinder
Ms0149, Battery (Ies)
1 You Will Need
2 Technical Specifications
3 Battery Inspection
4 Battery
Ms0151, Remove/Re-Install The Covers
1 You Will Need
3 Removal
4 Re-Installation
Ms0152, Remove/Re-Install Wheel Reduction Gear
1 You Will Need
3 Removal
4 Re-Installation
Ms0285, Maintenance Implementation
1 Placing In Configuration
Ms0396, Overload System - Instrumented Axis
1 Concerned Machines
4 You Will Need
5 Location Of The Load Pin Sensor
6 When Should You Make A Calibration
7 Configuring The Machine Before Start Calibration
8 Procedure
9 Offset Of Load Management System With Platform Empty
10 Gain Of Load Management System With Fixed Weight
11 Gain Of Load Management System With Adjustable Weight
12 Fault Codes Linked To The Overload System
13 Checks
Ms0503, Removal, Refitting Of The Weighing System Force Sensor
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
6 Re-Installation
Trouble Shooting
1 Trouble Shooting
1.1 Recommendations
1.2 Description
1.3 Requirements
1.4 Failures List
2 Legend
2.1 Pcb Turret
Electric And Hydraulic Diagrams
1 Wiring Diagram
1.1 Electric Diagram
2 Hydraulic Diagram
2.1 Hydraulic Diagram
Records
1 Intervention Register
