Haulotte Articulating Boom Lift HA26 RTJ O to HA80 RTJ PRO Service Repair Manual 4001319010 05.2025 EN
Momed80
151
35,863
Brand: Haulotte
Type of Machine: Articulating Boom Lift
Type of Manual: Service Manual, Repair Manual, Wiring Diagram, Hydraulic Diagram
Model: Haulotte HA26 RTJ O, HA26 RTJ O SW, HA26 RTJ PRO, HA26 RTJ PRO SW, HA80 RTJ O, HA80 RTJ PRO Color Screen Display Articulating Boom Lift
Part Number: 4001319010
Publication Date: 05.2025
Number of Pages: 328 Pages
Responsibilities And Commitments
1 Foreword
2 Responsibilities
2.1 Owner's Responsibility
2.2 Technician's Responsability
3 Haulotte® Commitments
3.1 Haulotte Services®
3.2 Training
3.3 Product Information
4 Conditions Of Warranty
Safety
1 General Safety Rules
1.1 Uncontrolled Movement Hazard
1.2 Electric Shock Hazards
1.3 Explosion / Fire Hazards
2 Safety Rules Energy Source Motorization
2.1 General Safety And Specific Interventions On The Thermal Engine
Familiarization
1 Haulotte Activ'screen 2
2 List Of Actuators And Sensors
2.1 Sensors And Actuators
3 Consumables (Oils - Fuels - Engine Oil - Coolant Level...)
3.1 Fuel
3.2 Engine Oil
3.3 Hydraulic Oil
3.4 Gear Motor Oil
3.5 Coolant
3.6 Cylinder Storage Oil
3.7 Grease
3.8 Marine Protection
3.9 Consumables
4 Movement Speed
Machine Sheets
Machine Sheets
Ms0001, Structural Part Inspection
1 Warning
2 Risk Prevention
3 You Will Need
4 Control And Maintenance
Ms0002, Pins And Bearing Inspection
1 Warning
2 Risk Prevention
3 You Will Need
5 Criteria Of Replacement
6 Procedure Of Reassembly
Ms0003, Cylinder Inspection
1 Warning
2 Risk Prevention
3 You Will Need
Ms0004, Braking Test Procedure
1 Warning
2 Risk Prevention
3 You Will Need
4 Test Procedure
Ms0005, Torque Values
1 Metric Torque Chart
2 Sae Fastener Torque Chart
3 Hydraulic Couplings And Hoses Tightening Torque Charts
4 Ha26 Rtj O, Ha26 Rtj Pro, Ha80 Rtj O, Ha80 Rtj Pro
Ms0009, Fuel Tank - Filling-Up
1 Warning
2 Risk Prevention
3 You Will Need
4 Consumable
5 Filling
Ms0020, Hoses Inspection - Replacement
1 You Will Need
2 Control And Inspections
3 Hoses Disassembling
4 Hoses Reassembly
Ms0029a, Kubota Diesel Engine
1 Product Information
2 Localization Identification Plate
3 Names Of Parts
4 Operating The Engine
5 Maintenance
6 Periodic Service
7 Carriage And Storage
8 Troubleshooting
Ms0029b, Kohler Diesel Engine
1 Localization Identification Plate
2 Names Of Parts
3 Operating The Engine
4 Maintenance
5 Fuel
6 Oil
7 Anti-Freeze
8 Carriage And Storage
9 Troubleshooting
Ms0029d, Perkins Diesel Engine
2 Safety Precautions
3 Technical Specifications
4 Names Of Parts
5 Operating The Engine
6 Maintenance
7 Fuel
8 Oil
9 Anti-Freeze
10 Carriage And Storage
11 Troubleshooting
Ms0031, Overload System
1 You Will Need
2 Level Of Knowledge Required
3 Safety Instructions
4 Periodic Inspection
5 Calibration Procedure
6 Checks
Ms0119, Remove/Re-Install The Hydraulic Motor
1 You Will Need
2 Preliminary Operation
3 Removal
4 Re-Installation
5 Additional Operations
Ms0123, Wheel Replacement
1 You Will Need
4 Wheel And Tires/Tyres Inspections
5 Wheel Replacement
6 Bronze Washer Replacement
Ms0133, Universal Plug
1 You Will Need
2 Procedure
Ms0137, Remove/Re-Install The Harness Bus Can
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
6 Re-Installation
7 Additional Operations
Ms0138, Remove/Re-Install The Main Counterweights
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
6 Re-Installation
Ms0139, Remove, Replace Arm Assembly
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
6 Re-Installation
Ms0140, Remove, Replace Boom Assembly
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
6 Re-Installation
Ms0141, Removing / Replacing The Pads
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
6 Re-Installation
Ms0142, Remove, Replace Boom Cylinder
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
6 Re-Installation
Ms0143, Remove/Re-Install Output Compensation Cylinder
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
6 Re-Installation
Ms0144, Remove/Re-Install Input Compensation Cylinder
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
6 Re-Installation
Ms0145, Remove, Replace Arm Cylinder
1 Warning
2 Risk Prevention
3 You Will Need
4 Removing The Cylinder
5 Re-Installing The Cylinder
6 Additional Operations
Ms0146, Remove, Replace Telescope Cylinder
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removing The Cylinder
6 Re-Installing The Cylinder
Ms0149, Battery (Ies)
1 You Will Need
2 Technical Specifications
3 Battery Inspection
4 Battery
Ms0151, Remove/Re-Install The Covers
1 You Will Need
3 Removal
4 Re-Installation
Ms0152, Remove/Re-Install Wheel Reduction Gear
1 You Will Need
3 Removal
4 Re-Installation
Ms0285, Maintenance Implementation
1 Placing In Configuration
Trouble Shooting
1 Trouble Shooting
1.1 Recommendations
1.2 Description
1.3 Requirements
1.4 Failures List
2 Legend
2.1 Pcb Turret
Electric And Hydraulic Diagrams
1 Wiring Diagram
1.1 Electric Diagram
2 Hydraulic Diagram
2.1 Hydraulic Diagram
Records
1 Intervention Register
