Haulotte Articulating Boom Lift HA26 RTJ O to HA80 RTJ PRO Operators Manual 4001317620 08.2025 EN
Momed80
151
35,863
Brand: Haulotte
Type of Machine: Articulating Boom Lift
Model: Haulotte HA26 RTJ O, HA26 RTJ O SW, HA26 RTJ PRO, HA26 RTJ PRO SW, HA80 RTJ O, HA80 RTJ PRO Articulating Boom Lift
Part Number: 4001317620
Publication Date: 08.2025
Number of Pages: 192 Pages
Foreword
1 Foreword
2 Responsibilities
2.1 Owner's responsibility
2.2 Employer's responsibility
2.3 Trainer's responsibility
2.4 Operator's responsibility
3 Safety
3.1 Safety instructions
4 Safety inquiries
5 Incident notification
6 Compliance
6.1 Product modification
6.2 Product specifications
6.3 Change of Ownership Notification
6.4 Declaration of conformity
Familiarization
1 General safety
1.1 Intended use
1.2 Decal content
1.3 Level of severity
1.4 Symbols legend and definitions
1.5 Symbols and colors
2 Models description
3 Primary machine components
3.1 Layout
3.2 Ground control box - Service/Emergency station
3.3 Platform control box - Main station
3.4 DPF (Diesel Particle Filter) (If equipped)
4 Performance Specifications
4.1 Technical characteristics
4.2 Engine specifications
4.3 Working area / Range of motion
5 Decals and markings locations
Pre-operation inspection
1 Recommendations
2 Working area assessment
3 Inspection and Functional test
3.1 Daily inspection
4 Safety functional checks
4.1 Emergency Stop button check
4.2 Activation of controls
4.3 Fault detector
4.4 Automatic engine cut-out
4.5 Overload sensing system
4.6 Oscillating axles (If equipped)
4.7 Slope warning device
4.8 Travel speed limitation
4.9 On-board electronics
4.10 Load selection system (if fitted)
4.11 Braking test
4.12 Overload test
Operation instructions
1 Operation
1.1 Introduction
1.2 Major description
1.3 Operation from the ground control box (Service/Emergency station)
1.4 Operation from the platform control box (Main station)
2.1 To start and stop the machine - Diesel engine
2.2 To start and stop the machine - Petrol / gas (Propane) Engine
2.3 Movement control
2.4 Additional controls
3.1 To start and stop the machine
3.2 Drive and steer control
3.3 Movement control
3.4 Additional controls
4 Rescue and emergency procedures
4.1 In case of power loss
4.2 To rescue operator in platform
4.3 Operation of overriding system from ground control box
4.4 No power available
5 Transportation
5.1 Transport configuration
5.2 Machine stowage for transport- HA26 RTJ O/PRO
5.3 Unloading
5.4 Towing
5.5 Storage
5.6 Lifting operation
6 Cold Weather Recommendations
6.1 Engine oil
6.2 Hydraulic oil
General Specifications
1 Machine dimensions
2 Major component masses
3 Acoustics and vibrations
4 Wheel/Tire assembly
4.1 Technical specifications
4.2 Inspection and maintenance
5 Options
5.1 Compatibility
5.2 Advanced Access Management - Access control and usage restriction
5.3 Swing gate
5.4 On-board generator
5.5 Glazier's kit
5.6 Welder's kit
5.7 Plumber's kit
5.8 Activ' Shield Bar - Secondary crush risk reduction system (If fitted)
5.9 Sand tires
Maintenance
1 General
2 Maintenance Schedule
3 Inspection program
3.1 General program
3.2 Daily inspection
3.3 Periodic inspection
3.4 Reinforced inspection
3.5 Major inspection
4 Repairs and adjustments
Other information
1 Conditions of warranty
2 Subsidiary contact information
2.1 California warning
Records
1 Intervention register
