Momed80
151
35,863
Haulotte Articulating Boom Lift HA16RTJ to HA16RTJPRO Service Repair Manual 4001317360 06.2025 EN
Brand: Haulotte
Type of Machine: Articulating Boom Lift
Type of Manual: Service Manual, Repair Manual, Wiring Diagram, Hydraulic Diagram
Model: Haulotte HA16RTJ, HA46RTJ, HA16RTJO, HA46RTJO, HA16RTJPRO Color Screen Display Articulating Boom Lift
Part Number: 4001317360
Publication Date: 06.2025
Number of Pages: 400 Pages
Responsibilities And Commitments
1 Foreword
2 Responsibilities
2.1 Owner's Responsibility
2.2 Technician's Responsability
3 Haulotte Commitments
3.1 Haulotte Services
3.2 Training
3.3 Product Information
4 Conditions Of Warranty
Safety
1 General Safety Rules
1.1 Uncontrolled Movement Hazard
1.2 Electric Shock Hazards
1.3 Explosion / Fire Hazards
2 Safety Rules Energy Source Motorization
2.1 General Safety And Specific Interventions On The Thermal Engine
Familiarization
1 Haulotte Activ'screen 2
2 List Of Actuators And Sensors
2.1 Sensors And Actuators
3 Consumables (Oils - Fuels - Engine Oil - Coolant Level...)
3.1 Fuel
3.2 Engine Oil
3.3 Hydraulic Oil
3.4 Gear Motor Oil
3.5 Coolant
3.6 Cylinder Storage Oil
3.7 Grease
3.8 Marine Protection
3.9 Consumables
4 Movement Speed
Machine Sheets
Machine Sheets
Ms0001 - Structural Part Inspection
1 Warning
2 Risk Prevention
3 You Will Need
4 Control And Maintenance
Ms0002 - Pins And Bearing Inspection
1 Warning
2 Risk Prevention
3 You Will Need
5 Criteria Of Replacement
6 Procedure Of Reassembly
Ms0003 - Cylinder Inspection
1 Warning
2 Risk Prevention
3 You Will Need
Ms0004 - Braking Test Procedure
1 Warning
2 Risk Prevention
3 You Will Need
4 Test Procedure
Ms0005 - Torque Values
1 Metric Torque Chart
2 Sae Fastener Torque Chart
3 Hydraulic Couplings And Hoses Tightening Torque Charts
4 Ha16rtj - Ha16rtjo - Ha16rtj Pro - Ha46rtjo - Ha46rtj Pro
Ms0008 - Oscillating Axles - Functional Tests
1 Warning
2 Risk Prevention
3 You Will Need
4 Oscillating Axles
Ms0009 - Fuel Tank - Filling-Up
1 Warning
2 Risk Prevention
3 You Will Need
4 Consumable
5 Filling
Ms0010 - Slew Ring Inspection
1 You Will Need
2 Preliminary Operation
3 Lubrication
4 Tightening
5 Slew Ring Inspection
Ms0019 - Hydraulic Oil-Level Replacement
1 You Will Need
3 Level Control
4 Replacement Of Hydraulic Oil
Ms0020 - Hoses Inspection - Replacement
1 You Will Need
2 Control And Inspections
3 Hoses Disassembling
4 Hoses Reassembly
Ms0021 - Hydraulic Filter Cartridge Replacement
1 You Will Need
2 Hydraulic Filter Cartridge Replacement
Ms0029a - Kubota Diesel Engine
1 Product Information
2 Localization Identification Plate
3 Names Of Parts
4 Operating The Engine
5 Maintenance
6 Periodic Service
7 Carriage And Storage
8 Troubleshooting
Ms0029c - Perkins Diesel Engine
1 Localization Identification Plate
2 Safety Precautions
3 Technical Specifications
4 Names Of Parts
5 Operating The Engine
6 Maintenance
7 Fuel
8 Oil
9 Anti-Freeze
10 Carriage And Storage
11 Troubleshooting
Ms0029f - Kohler Diesel Engine
2 Technical Specifications
3 Names Of Parts
5 Maintenance
6 Fuel
7 Oil
8 Anti-Freeze
9 Carriage And Storage
10 Troubleshooting
Ms0030 - Component Location
1 You Will Need
2 Localization Of Hydraulic Blocks In The Chassis
3 Drive Unit
4 Steering Unit - Ha16rtj - Ha16rtjo - Ha46rtjo
5 Steering Unit - Ha16rtj Pro - Ha46rtj Pro
6 Oscillating Axle Locking Block - Ha16rtj O / Pro - Ha46rtj O / Pro
7 Location Of The Turntable Components
8 Unit Pvg
9 Ground Control Box And Spu
10 Pcb Inside The Ground Control Box
11 Spu7066
12 Engine
13 Hydraulic Pump
14 Recapitulation Of Pressures
15 Position Of Ils Sensors, Arm, Boom And Telescop
16 Hydraulic Block On/Off
17 Load Cell
18 Platform Control Box
Ms0031 - Overload System
1 You Will Need
2 Level Of Knowledge Required
3 Safety Instructions
4 Periodic Inspection
5 Calibration Procedure
6 Checks
Ms0032 - Tires (Tyres) And Pressures-Wheel Replacement
1 You Will Need
4 Wheel And Tires/Tyres Inspections
5 Wheel Replacement
Ms0034 - Dismantling / Reassembling Wheels Reducer
1 You Will Need
4 Removal
5 Reinstall
6 Additional Operations
Ms0035 - Check And Replacing The Pads
1 You Will Need
4 Removal/Reinstall-Rear Pads
Ms0036 - Telescopic Cylinder Replacement
1 You Will Need
4 Removal
5 Reinstall
Ms0038 - Pressure Adjustment
1 You Will Need
2 Pressure Adjustment
3 Pressure Plug Location
Ms0109 - Draining The Wheel Reducer
1 You Will Need
4 Additional Operations
Ms0133 - Universal Plug
1 You Will Need
2 Procedure
Ms0165 - Remove/Re-Install Output Compensation Cylinder
1 Warning
2 Risk Prevention
3 You Will Need
4 Removal
5 Re-Installation
Ms0166 - Remove - Replace Load Cell
1 Warning
2 Risk Prevention
3 You Will Need
4 Removal
5 Re-Installation
Ms0167 - Remove - Replace Boom Cylinder
1 Warning
2 Risk Prevention
3 You Will Need
4 Removal
5 Re-Installation
Ms0168 - Remove - Replace Arm Cylinder
1 Warning
2 You Will Need
3 Preliminary Operation
4 Removal
5 Re-Installation
Ms0169 - Remove/Re-Install Input Compensation Cylinder
1 Warning
2 You Will Need
4 Removal
5 Re-Installation
Ms0170 - Removal - Replacement Of The Platform
1 Warning
2 You Will Need
4 Removal
5 Re-Installation
Ms0171 - Remove - Replace Arm Assembly
1 Warning
2 You Will Need
4 Removal
5 Re-Installation
Ms0172 - Remove - Replace Boom Assembly
1 Warning
2 You Will Need
4 Removal
5 Re-Installation
Ms0180 - Battery (Ies)
1 You Will Need
3 Starter Battery Inspection
Ms0237 - Remove - Replace Counterweight
1 Warning
2 You Will Need
4 Ha16rtjpro/Ha16rtjo Counterweight General Arrangement Plan
5 Ha16rtj Counterweight General Arrangement Plan
6 Removal
7 Re-Installation
8 Additional Operations
Ms0285 - Maintenance Implementation
1 Placing In Configuration
Ms0396 - Overload System - Instrumented Axis
1 Concerned Machines
4 You Will Need
5 Location Of The Load Pin Sensor
6 When Should You Make A Calibration
7 Configuring The Machine Before Start Calibration
8 Procedure
9 Offset Of Load Management System With Platform Empty
10 Gain Of Load Management System With Fixed Weight
11 Gain Of Load Management System With Adjustable Weight
12 Fault Codes Linked To The Overload System
13 Checks
Ms0503 - Removal - Refitting Of The Weighing System Force Sensor
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
6 Re-Installation
7 Additional Operations
Trouble Shooting
1 Trouble Shooting
1.1 Recommendations
1.2 Description
1.3 Requirements
1.4 Failures List
2 Legend
2.1 Pcb Turret
Electric And Hydraulic Diagrams
1 Wiring Diagram
1.1 Electric Diagram
2 Hydraulic Diagram
2.1 Hydraulic Diagram
Records
1 Intervention Register
