Momed80
151
35,046
Haulotte Articulating Boom HA16 E to HA46 E PRO Service Repair Manual 4001296660 01.2024 EN
Brand: Haulotte
Type of Machine: Articulating Boom
Type of Manual: Service Manual, Repair Manual, Wiring Diagram, Hydraulic Diagram
Model: Haulotte HA16 E HA46 E, HA16 E PRO HA46 E PRO Touch Screen Display Articulating Boom
Part Number: 4001296660
Publication Date: 01.2024
Number of Pages: 354 Pages
Responsibilities And Commitments
1 Foreword
2 Responsibilities
2.1 Owner's Responsibility
2.2 Technician's Responsability
3 Haulotte® Commitments
3.1 Haulotte Services®
3.2 Training
3.3 Product Information
4 Conditions Of Warranty
Safety
1 General Safety Rules
1.1 Uncontrolled Movement Hazard
1.2 Electric Shock Hazards
1.3 Explosion / Fire Hazards
2 Safety Rules Energy Source Motorization
2.1 General Safety And Specific Interventions On The Thermal Engine
2.2 General Safety And Specific Interventions On Energy Storage
Familiarization
1 Touch Screen Display
2 List Of Actuators And Sensors
2.1 Sensors And Actuators
3 Consumables (Oils...)
3.1 Engine Oil
3.2 Hydraulic Oil
3.3 Axle, Gearbox And Reducer Oil
3.4 Cylinder Storage Oil
3.5 Grease
3.6 Marine Protection
3.7 Consumables
4 Movement Speed
Machine Sheets
Machine Sheets
Ms0001 - Structural Part Inspection
1 Warning
2 Risk Prevention
3 You Will Need
4 Control And Maintenance
Ms0002 - Pins And Bearing Inspection
1 Warning
2 Risk Prevention
3 You Will Need
5 Criteria Of Replacement
6 Procedure Of Reassembly
Ms0003 - Cylinder Inspection
1 Warning
2 Risk Prevention
3 You Will Need
Ms0004 - Braking Test Procedure
1 Warning
2 Risk Prevention
3 You Will Need
4 Test Procedure
Ms0009 - Fuel Tank - Filling-Up
1 Warning
2 Risk Prevention
3 You Will Need
4 Consumable
5 Filling
Ms0133 - Universal Plug
1 You Will Need
2 Procedure
Ms0222 - Draining The Rotary Cylinder
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Draining The Rotary Cylinder
Ms0285 - Maintenance Implementation
1 Placing In Configuration
Ms0435 - Removal - Replacement Of The Platform
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
6 Re-Installation
Ms0436 - Remove/Re-Install Rotary Actuator
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
6 Re-Installation
7 Additional Operations
Ms0437 - Remove - Replace Load Cell
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
6 Re-Installation
Ms0438 - Remove/Re-Install Jib Cylinder
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
6 Re-Installation
Ms0439 - Removal - Replacement Of The Jib And Platform
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
6 Re-Installation
Ms0440 - Remove/Re-Install Input Compensation Cylinder
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
6 Re-Installation
Ms0441 - Remove/Re-Install Output Compensation Cylinder
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
6 Re-Installation
Ms0442 - Remove - Replace Telescope Cylinder
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
6 Re-Installation
Ms0443 - Removing The Boom Lifting Cylinder
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
6 Re-Installation
Ms0444 - Remove - Replace Counterweight
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
6 Re-Installation
Ms0445 - Remove - Replace Arm Cylinder
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
6 Re-Installation
Ms0446 - Removing / Replacing The Pads
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Remove - Replace The Rear Pads
6 Removing - Refitting The Upper Rear Pads
7 Removing And Installing All The Pads At The Rear Of The Telescope
8 Re-Installation
9 Additional Operations
Ms0447 - Remove - Replace The Boom/Jib/Box Assembly
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
6 Re-Installation
Ms0448 - Remove - Replace Arm Assembly
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
6 Re-Installation
Ms0449 - Removal - Replacement Of The Drive Controller + Equipment Pump
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
6 Re-Installation
Ms0450 - Remove/Re-Install The Harnesscan Bus
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
6 Re-Installation
Ms0451 - Removal - Reinstallation Of The Chargers
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal - General Points
6 Removal - Standard Charger
7 Removal: Optional Charger (If The Machine Is Equipped With The Fast Charge Option With Range Extender)
8 Re-Installation
Ms0452 - Removal - Reinstallation Of The Electric Pump Or Electric Drive Motor Alone Or Pump Alone
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Refit The Motor Pump Unit
6 Removing The Electric Motor Without Draining
7 Removing The Hydraulic Pump
8 Re-Installation
Ms0453 - Dismantling/Reassembling The Tilt Sensor
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Information
6 Dis-Assembly
7 Reassembly
8 Additional Operations
Ms0454 - Placing The Machine In Maintenance Configuration
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Placing The Machine In Maintenance Configuration
6 Putting In Use Position
Ms0455 - Removal - Replacement Of Semi-Traction Batteries
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
6 Re-Installation
Ms0456 - Removal - Replacement Of Battery Compartments
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
6 Re-Installation
Ms0457 - Removal - Replacement Of The Bms (Battery Monitoring Sensor)
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
6 Re-Installation
Ms0458 - Removal - Reinstallation Of The Oscillating Axle Locking Cylinder
1 Concerned Machines
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Removal
7 Re-Installation
Ms0459 - Removal - Replacement Of Electric Drive Motor
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
6 Re-Installation
Ms0460 - Remove - Reinstall The Drive Shaft
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
6 Re-Installation
Ms0461 - Remove - Reinstall The Axle Assembly
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Removal
6 Re-Installation
Trouble Shooting
1 Trouble Shooting
1.1 Recommendations
1.2 Description
1.3 Requirements
1.4 Failures List
Electric And Hydraulic Diagrams
1 Wiring Diagram
1.1 Electric Diagram
2 Hydraulic Diagram
2.1 Hydraulic Diagram
Records
1 Intervention Register
