Haulotte Articulating Boom HA16 E to HA46 E PRO Maintenance Manual 4001296580 01.2024 EN
Brand: Haulotte
Type of Machine: Articulating Boom
Type of Manual: Maintenance Manual, Wiring Diagram, Hydraulic Diagram
Model: Haulotte HA16 E HA46 E, HA16 E PRO, HA46 E PRO Touch Screen Display Articulating Boom
Part Number: 4001296580
Publication Date: 01.2024
Number of Pages: 200 Pages
Responsibilities And Commitments
1 Foreword
2 Responsibilities
2.1 Owner's Responsibility
2.2 Technician's Responsability
3 Haulotte® Commitments
3.1 Haulotte Services®
3.2 Training
3.3 Product Information
4 Conditions Of Warranty
Safety
1 General Safety Rules
1.1 Uncontrolled Movement Hazard
1.2 Electric Shock Hazards
1.3 Explosion / Fire Hazards
2 Safety Rules Energy Source Motorization
2.1 General Safety And Specific Interventions On The Thermal Engine
2.2 General Safety And Specific Interventions On Energy Storage
Familiarization
1 Touch Screen Display
2 List Of Actuators And Sensors
2.1 Sensors And Actuators
3 Consumables (Oils...)
3.1 Engine Oil
3.2 Hydraulic Oil
3.3 Axle, Gearbox And Reducer Oil
3.4 Cylinder Storage Oil
3.5 Grease
3.6 Marine Protection
3.7 Consumables
4 Movement Speed
Inspection And Maintenance Schedule
1 Inspection Program
2 Daily Inspection
3 Preventive Maintenance
3.1 Preventive Maintenance Level 1 / 2
3.2 Engine Maintenance - Option Range Extender
4 Periodic Inspection
5 Major Inspection
Machine Sheets
Machine Sheets
Mp0001n - Wheel Tightening Procedure
1 Concerned Machines
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Procedure
7 Additional Operations
Mp0002l - Wheel Reducer Level Procedure
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Consumables
7 Procedure
8 Additional Operations
Mp0003m - Procedure For Checking The Level Of Engine Oil
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Procedure
Mp0004o - Replacing The Engine Oil Filter/Drain The Engine Oil
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Consumables
7 Procedure
Mp0005m - Diesel Filter Replacement
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Procedure
Mp0006n - Hydraulic Oil Filter Replacement
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Procedure
Mp0008g - Front Axle Locking Function Check
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Procedure
Mp0010m - Air Filter Replacement
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Procedure
Mp0011o - Wear Pad Check
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Procedure
Mp0012c - Platform Overload Check
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Procedure
Mp0013h - Hydraulic Tank Level
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Consumable
7 Procedure
Mp0014m - Emptying The Hydraulic Tank
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Consumable
7 Procedure
Mp0015a - Load Cell Tightness Check
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Procedure
Mp0016a - Rotary Cylinder Tightness Check
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Procedure
Mp0017a - Checking The Platform
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Procedure
Mp0018d - Slew Ring Clearance Check
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Procedure
Mp0019l - Torque Tightening Of The Slew Ring
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Procedure
Mp0024m - Checking The Pin Stop Mechanisms
2 Warning
3 Risk Prevention
4 You Will Need
5 Procedure
Mp0027i - Steering System Greasing
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Consumables
7 Procedure
Mp0028k - Greasing The Pads
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Consumable
7 Procedure
Mp0029e - Jib Cylinder Lubrication
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Consumable
7 Procedure
Mp0043k - Draining The Wheel Reducer
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Consumable
7 Procedure
Mp0044g - Greasing The Turntable Rotation Gearbox
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Procedure
Mp0047c - At Axle Level-At The Transfer Box
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Consumable
7 Procedure
Mp0048d - Draining The Axles And Transfer Box
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Consumable
7 Procedure
Mp0050b - Brake Release Check Procedure
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Procedure
Mp0053c - Check The Operation Of The Safety Valves
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Machine Configuration
7 Accessing The Safety Test Menu
Ms0238 - Links To Engine Manufacturer Manuals - Fuel-Powered Machines
1 Links To Engine Manufacturer Manuals - Fuel-Powered Machines
2 Kubota
3 Perkins
4 Deutz
5 Kohler
6 Yanmar
Ms0285 - Maintenance Implementation
1 Placing In Configuration
Ms0454 - Placing The Machine In Maintenance Configuration
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
5 Placing The Machine In Maintenance Configuration
6 Putting In Use Position
Electric And Hydraulic Diagrams
1 Wiring Diagram
1.1 Electric Diagram
2 Hydraulic Diagram
2.1 Hydraulic Diagram
Records
1 Intervention Register
Brand: Haulotte
1 Foreword
2 Responsibilities
3.2 Training
Safety
Familiarization
3.1 Engine Oil
3.2 Hydraulic Oil
3.5 Grease
3.7 Consumables
4 Movement Speed
2 Daily Inspection
5 Major Inspection
Machine Sheets
Machine Sheets
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Procedure
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Consumables
7 Procedure
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Procedure
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Consumables
7 Procedure
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Procedure
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Procedure
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Procedure
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Procedure
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Procedure
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Procedure
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Consumable
7 Procedure
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Consumable
7 Procedure
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Procedure
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Procedure
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Procedure
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Procedure
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Procedure
2 Warning
3 Risk Prevention
4 You Will Need
5 Procedure
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Consumables
7 Procedure
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Consumable
7 Procedure
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Consumable
7 Procedure
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Consumable
7 Procedure
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Procedure
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Consumable
7 Procedure
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Consumable
7 Procedure
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Procedure
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
2 Kubota
3 Perkins
4 Deutz
5 Kohler
6 Yanmar
1 Concerned Area
2 Warning
3 Risk Prevention
4 You Will Need
1 Wiring Diagram
2 Hydraulic Diagram
Records
- Haulotte Articulated Boom Lift 4527A, HTA 16P Parts and Service Manual
- Haulotte Bil-Jax Articulated Boom Lift 5533A Parts and Service Manual
- Haulotte Scissor Lift Compact 8 Parts Manual
- Haulotte HA20PX HA26PX Self Propelled LIft Repair Manual
- Haulotte Articulated Boom Lift HA15IP-HA43JE Parts Manual_2420339510
- Haulotte Scissor Lift Compact 10, 2747E Parts Manual
- Haulotte 4527A HTA 16P Part Manual
- Haulotte Articulated Boom Lift HA16PX-HA18PX Parts Manual_2420344550
- Haulotte Scissor Lift Optimum 6, Optimum 8 Parts Manual
- Haulotte OPTIMUM 8 - 1931E_E04.20 Part Manual
- Haulotte Scissor Lift Optimum 1530E, 1930E Repair Manual_2420318690
- Haulotte Articulated Boom Lift HA20PX, HA80JRT Parts Manual_2420340850
- Haulotte Telescopic Boom HT21TX-HB62 Parts Manual_2420311040
- Haulotte Self Propelled Scissor Optimum 6,8 Operating and Maintenance Instructions
- Haulotte Articulated Boom Lift HA18-HA51 Parts Manual_4000415260
