Hangcha XF Series 5.0t-10t CPCD50-XW95G to CPCD100-XH15B Service Manual 2023
Brand: Hangcha
Type of Machine: Forklift Truck
Type of Manual: Service Manual, Wiring Diagrams, Hydraulic Diagrams
Model: Hangcha XF Series 5.0t-10t Forklift Truck
CPCD50-XW95G CPCD60-XW95G CPCD70-XW95G CPCD80-XW96G CPCD100-XW96G CPCD50-XH16B
CPCD60-XH16B CPCD70-XH16B CPCD80-XH16B CPCD100-XH16B CPCD50-XH15B CPCD60-XH15B
CPCD70-XH15B CPCD80-XH15B CPCD100-XH15B CPYD50-XH20 CPYD60-XH20 CPYD70-XH20
Publication Date: 2023
Number of Pages: 98 Pages
I.Power system
III.Hydraulic transmission gear box
IV. Drive axle assembly
Electrical plate assembly
Key switch(start)
Combination switch assembly
Electrical system diagram
X. Overhead guard disassembly and installation
Brand: Hangcha
I.Power system
1.Engine
2.Air intake system
3.Exhaust system
4.Cooling system
II.Transmission shaftIII.Hydraulic transmission gear box
1. Drive axle basic structure and its working prin
2.Periodical technical maintenance
3.Drive axle oil adding way
4. Drive axle hoisting
5. Driven spiral bevel gear engagement contact con
6. Fault diagnosis and corrections
7. Dismantle and assemble
V. Steering system1.Hydraulic steering gear
2.Steering axle
VI. Brake system1.Data
2.Fault diagnosis and corrections
3.Pedal height, free stroke
4. Brake valve and accumulator
5. Hand brake
6.Service brake
7. Hydraulic brake malfunction diagnosis
8. Exhaust of air in the hydraulic system
VII. Hydraulic system1.Oil pump
2. Multiple directional control valve
3. Rotary type piping filter
4. One-way governor valve
5. Lifting cylinder
6. Tilting cylinder
7. Air exhaust in hydraulic system
8. Hydraulic system fault diagnosis and correction
9. Hydraulic system schematic diagram
VIII. Lifting system1. Assemble debugging data
2. Fault diagnosis and corrections
3. Summarize
4. Mast dismantle and install adjustment
5. Disassembly and installation of lifting cylinde
6.Disassembly and installation of tilting cylinder
7. Noticing proceeding of debugging
IX. Electrical systemElectrical plate assembly
Key switch(start)
Gear combination switch(H15-H16)
Light combination switch
Starter and generator repairElectrical system diagram
- Hangcha Forklift 1.5-3.5 T R Series LPG Service And Parts Manual
- Hangcha R Series 5-10t Forklift Truck Parts Catalog
- Hangcha Forklift Truck 1~5t J Series Counterbalanced Battery SERVICE MANUAL
- Hangcha Forklift Truck R series 2.0-2.5t Parts Catalogue
- Hangcha Forklift Truck 1t-3.5t R Series SERVICE MANUAL
- HANGCHA J Series Battery Forklift Service Manual
- Hangcha Forklift Truck J series 4 wheel electric 1.0-3.5t Parts Catalogue
- Hangcha Forklift Truck 5.0-10.0t Parts Catalogue
- Hangcha Forklift Truck 5.0-6.0t Parts Catalogue
- Hangcha Forklift Truck 4.0-5.0t Parts Catalogue
- Hangcha J Series 4 Wheel Electric Forklift Truck 1-3.5t
- Hangcha Forklift Truck R series 1.0-1.8t Parts Catalogue
- Hangcha Forklift Truck J SERIES THREE WHEEL COUNTERBALANCED ELECTRICAL Parts Catalogue
- Hangcha Forklift Truck R2_25t Parts Catalog
- Hangcha Forklift Truck 12-16t Parts Catalogue (2011)
