Hyundai
86
176,834
Hangcha XF Series 12t CPCD120-XXW75 CPCD120-XXW96 Service Manual 2023
Brand: Hangcha
Type of Machine: Forklift Truck
Type of Manual: Service Manual, Wiring Diagrams, Hydraulic Diagrams
Model: Hangcha XF Series 12t CPCD120-XXW75 CPCD120-XXW96 Forklift Truck
Publication Date: 2023
Number of Pages: 132 Pages
I.Power system
1.Engine​
2.Air intake system​
3.Exhaust system​
4.Cooling system​
II.Transmission shaft
III.Hydraulic transmission gear box
1.Summarize​
2.Main technical parameter​
3.Working principle​
4.Structure introduction​
5.Installment and use notice​
6. Fault reason and corrections​
IV. Drive axle assembly
1. Drive axle basic structure and its working prin​
2.Periodical technical maintenance​
3.Drive axle oil adding /drainage way and fuel-inj​
4. Drive axle hoisting​
5. Driven spiral bevel gear engagement contact con​
6. Fault diagnosis and corrections​
7. Dismantle and assemble​
V. Steering system
1.Hydraulic steering gear​
2.Steering axle​
VI. Brake system
1.Data​
2.Fault diagnosis and corrections​
3.Pedal height, free stroke​
4. Brake valve and accumulator​
5. Hand brake​
6.Service brake​
7. Hydraulic brake malfunction diagnosis​
8. Exhaust of air in the hydraulic system​
9.Brake system schematic diagram​
VII. Hydraulic system
1.Oil pump​
2. Multiple directional control valve​
3. Rotary type piping filter​
4. One-way governor valve​
5. Lifting cylinder​
6. Tilting cylinder​
7. Air exhaust in hydraulic system​
8. Hydraulic system fault diagnosis and correction​
9. Hydraulic system schematic diagram​
VIII. Lifting system
1. Assemble debugging data​
2. Fault diagnosis and corrections​
3. Summarize​
4. Mast dismantle and install adjustment​
5. Disassembly and installation of lifting cylinde​
6.Disassembly and installation of tilting cylinder​
7. Noticing proceeding of debugging​
IX. Electrical system
Electrical plate assembly
Key switch(start)
Combination instrument assembly(W48、W41)
Combination switch assembly
Gear combination switch​
Light combination switch​
Starter and generator repair
Engine fault detection
CUMMINS stage ⅢB Diagnostic Trouble Codes and Cumm​
Electrical system diagram
X. Overhead guard disassembly and installation
