Hyundai
86
176,834
Hangcha XE Series 6.0t-10t CPD60-XEY2-SI to CPD100-XEY2-SI Maintenance Manual 2024
Brand: Hangcha
Type of Machine: Forklift Truck
Type of Manual: Maintenance Manual, Electrical Schematic, Hydraulic Schematic
Model: Hangcha XE Series 6.0t-10t Forklift Truck
CPD60-XEY2-SI CPD70-XEY2-SI CPD80-XEY2-SI CPD90-XEY2-SI CPD100-XEY2-SI
Publication Date: 2024
Number of Pages: 417 Pages
1 Lithium-Ion Battery
1.1 Instructions And Precautions For Use​
1.2 Structure And Size​
1.3 Charging Socket Port Definition​
1.4 Daily Maintenance​
1.5 Internal Components​
1.6 Structure Of The Lithium-Ion Battery​
1.7 Component Condition​
1.8 Battery Maintenance​
1.9 Analysis Of Common Battery Faults​
2 Motor
2.1 Main Technical Parameters​
2.2 Motor Maintenance​
2.3 Precautions For Motor Disassembly And Assembly​
2.4 Common Faults And Troubleshooting​
3 Driving System
3.1 Overview​
3.2. Disassembly And Assembly Of The Transmission System​
3.3 Drive Axle​
3.4 Tires​
4. Steering
4.1 Overview​
4.2 Steering Device​
4.3 Steering Axle​
5 Braking System
5.1 Overview​
5.2 The Handbrake And Brake Lines​
5.3 Brake Control​
5.4 Brake Assembly​
5.5 Bleeding The Braking System​
6 Truck Body
6.1 Overview​
6.2 Dashboard Assembly​
6.3 Machine Hood And Floor​
6.4 Door Assembly​
6.5 Pedal Assembly​
6.6 Battery Removal And Fixing Device​
6.7 Overhead Guard​
6.8 Counterweight Assembly​
6.9 Seat​
7 Hydraulic System
7.1 Overview​
7.2 Oil Tank Assembly​
7.3 Oil Pump Unit​
7.4 Steering Pipe​
7.5 Oil Return Filter Assembly​
7.6 Brake Line​
7.7 Tilt Pipeline​
7.8 Multi-Way Valve Control​
7.9 Multi-Way Valve Assembly​
7.10 Multi-Port Valve Control Mechanism​
7.11 Pressure Adjustment Of The Main Safety Valve​
7.12 Hydraulic Steering Gear​
7.13 Steering Cylinder​
7.14 Fault Diagnosis And Troubleshooting​
8 Lifting System
8.1 Overview​
8.2 Main Technical Parameters​
8.3 Removal And Installation​
8.4 Tilt Cylinder​
8.5 Lifting Cylinder​
