Hyundai
85
171,303
Hangcha XE Series 1.5t-5.0t CPD15-XEYS-SI to CPD50-XEYS-SI Maintenance Manual 2025
Brand: Hangcha
Type of Machine: Electric Forklift Truck
Type of Manual: Maintenance Manual, Wiring Diagrams, Hydraulic Diagrams
Model: Hangcha XE Series 1.5t-5.0t Electric Forklift Truck
CPD15-XEY2-SI CPD18-XEY2-SI CPD20-XEY2-SI CPD25-XEY2-SI CPD30-XEY2-SI CPD35-XEY2-SI
CPD38-XEY2-SI CPD20-XEXY2-SI CPD40-XEXY2-SI CPD30-XEY2H1-SI CPD35-XEY2H1-SI
CPD38-XEY2H1-SI CPD20-XEY2H-SI CPD25-XEY2H-SI CPD30-XEY2H-SI CPD35-XEY2H-SI
CPD38-XEY2H-SI CPD40-XEY2-SI CPD45-XEY2-SI CPD50-XEY2-SI
CPD50-XEXY2-SI CPD40-XEY2-SIGW CPD45-XEY2-SIGW CPD50-XEY2-SIGW CPD50-XEXY2-SIGW
CPD20-XEY2H2-SI CPD25-XEY2H2-SI CPD30-XEY2H2-SI CPD35-XEY2H2-SI
CPD38-XEY2H2-SI CPD15-XEY2HA-SI CPD18-XEY2HA-SI CPD20-XEY2HA-SI CPD25-XEY2HA-SI
CPD27-XEY2HA-SI CPD30-XEY2HA-SI CPD35-XEY2HA-SI CPD38-XEY2HA-SI CPD20-XEXY2HA-SI
Publication Date: 2025
Number of Pages: 748 Pages
1. Lithium-Ion Battery
1.1 Instructions And Precautions For Use​
1.2 Structure And Size​
1.3 Definition Of Charging Socket Interfaces​
1.4 Daily Maintenance​
1.5 Internal Components​
1.6 Structure Of The Lithium-Ion Battery​
1.7 Fault Diagnosis​
1.8 Battery Maintenance​
1.9 Battery Common Fault Diagnosis​
2 Transmission System
2.1 Overview Of The Transmission System​
2.2 Transmission System Disassembly​
2.3 Drive Axle​
2.4 Transmission​
2.5 Tires​
3 Steering Device And Steering Axle
3.1 Overview​
3.2 Steering Device​
3.3 Steering Axle​
4. Braking System
4.1 Overview​
4.2 Service Brake And Brake Master Cylinder​
4.3 Hand Brake​
4.4 Service Brake​
Park The Forklift On A Level And Solid Surface, Th​
Use A Hydraulic Jack Near The Front Wheel To Lift​
1.Remove The 6 Hub Nuts (1) From The Wheel Rim And​
Fig. 4-13​
Fig. 4-14​
4.Pull Out The Half Shaft, Loosen The 2 Screws (It​
Fig. 4-15​
Fig. 4-16​
Fig. 4-17​
Fig. 4-18​
Fig. 4-19​
Fig. 4-20​
Fig. 4-25​
Fig. 4-26​
Fig. 4-27​
4.4.2.3 Install​
Fig. 4-28​
Fig. 4-29​
Fig. 4-30​
4.Install The Brake Cable Assembly And Clip The E​
Fig. 4-31​
Fig. 4-32​
Fig. 4-33​
7.Install The Left Gap Adjuster Assembly (9) And​
Fig. 4-34​
Fig. 4-36​
5.Unscrew The 2 Screws.​
Fig. 4-37​
6.Install The Locking Piece So That Its Hole Match​
7.Screw On The Brake Washer. (The Locating Pin Of​
Fig. 4-38​
8.Turn The Hub Forward And Backward For 2-3 Turns,​
Fig. 4-39​
9.Measure The Axial Clearance Of The Hub With (4)​
Fig. 4-40​
10.Use The Locating Pin (5) To Guide And Position​
Fig. 4-41​
11.Tighten The 6 Screws.​
12.Turn The Wheel Clockwise While Pressing The Bra​
13.Remove The Hydraulic Jack And Wood Pads. Start​
4.5 Electromagnetic Brake(Optional)​
4.6 Fault Diagnosis And Troubleshooting​
5. Truck Body
5.1 Overview​
5.2 Dashboard Assembly​
5.3 Machine Hood And Floor Assembly​
5.4 Battery Clamping Device​
5.5 Counterweight​
5.6 Overhead Guard​
5.7 Seat​
6. Hydraulic System
6.1 Overview Of Hydraulic System​
6.2 Oil Pump Device​
6.3 Multi-Way Valve​
6.5 Hydraulic Oil Tank​
6.6 Electromagnetic Proportional Control Valve (O​
6.7 Priority Valve (Optional Thumb Switch)​
6.8 Steering Gear​
Cpd20-Xexy2ha-Si​
Cpd30-35-38-Xey2-Si​
Cpd30-35-38-Xey2h1-Si​
Cpd20-25-Xey2-Si​
Cpd20-25-Xey2h-Si​
Cpd30-35-38-Xey2h-Si​
-202403​
Cpd30-35-38-Xey2ha-Si​
202403-​
Cpd40-45-Xey2-Si​
Cpd50-Xey2-Si​
Cpd50-Xexy2-Si​
Cpd40-45-Xey2-Sigw​
Cpd50-Xey2-Sigw​
6.9 Common Fault Diagnosis And Troubleshooting​
7. Motor
7.1 Traction Motor​
7.2 Oil Pump Motor​
7.3 Motor Maintenance​
7.4 Precautions For Disassembly​
7.5 Replacement Of The Speed Sensor And Temperatu​
8. Mast
8.1. Overview​
8.2 Parameters For Adjustment​
8.3 Main Structural Components Of The Lifting Asse​
8.4 Disassembly, Assembly And Adjustment Of The L​
8.5 Fault Diagnosis And Troubleshooting​
9. Controller
9.1 Overview​
9.2 Features​
9.3 Traction Controller Fault Codes (E1 Series)​
9.4 Troubleshooting For Traction Controller Fault​
9.5 Oil Pump Controller Fault Codes (E3 Series)​
9.6 Troubleshooting For Oil Pump Controller Fault​
9.7 Checks And Adjustment For The Parameters Of T​
9.8 Disassembly And Assembly​
10 Electrical Components
10.1 Dashboard​
10.2 Lighting System​
10.3 Switch​
10.4 Fuse​
10.5 Others​
10.6 Common Faults And Troubleshooting Of The Ele​
Whether The Angle Sensor Line Is Disconnected
Yes: Line Problem, Repair Line.
No: Unplug The Angle Sensor And Measure Whether Th
Yes: The Angle Sensor Is Damaged. Replace The Angl
No:If The Power Supply Cable Of The Angle Sensor O
11. Schematic Diagrams
11.1 Braking Schematic Diagram​
11.2 Hydraulic Schematic Diagram​
11.3 Electrical Schematic Diagram​
12. Cab
12.1 Cab Overhead Guard​
12.2 Cab Door Assembly​
12.3 Cab Rear Window Assembly​
12.4 Cab Front Windshield Assembly​
12.5 Cab Fan​
12.6 Electrical Schematic Diagram For The Cab​
13 Main Accessories
13.1 Thumb Switch​
13.2 Attachments​
14. Bolts Tightening Torque Table
