Hyundai
86
176,834
Hangcha XC Series 4.0t-5.0t CPD40-XCY2-SI to CPD50-XCXY2-SI Maintenance Manual 2024
Brand: Hangcha
Type of Machine: Forklift Truck
Type of Manual: Maintenance Manual, Wiring Diagrams, Hydraulic Diagrams
Model: Hangcha XC Series 4.0t-5.0t Forklift Truck
CPD40-XCY2-SI CPD45-XCY2-SI CPD50-XCY2-SI CPD50-XCXY2-SI
Publication Date: 2024
Number of Pages: 301 Pages
1 Lithium-Ion Battery
1.1 Instructions And Precautions For Use​
1.2 Structure And Size​
1.3 Charging Socket Port Definition​
1.4 Daily Maintenance​
1.5 Internal Components​
1.6 Structure Of The Lithium-Ion Battery​
1.7 Component Condition​
1.8 Battery Maintenance​
1.9 Analysis Of Common Battery Faults​
2 Motor
2.1 Main Technical Parameters​
2.2 Motor Maintenance​
2.3 Precautions For Motor Disassembly And Assembly​
2.4 Replace The Speed Sensor And The Temperature S​
2.5 Common Faults And Troubleshooting​
3.1 Overview​
3.2. Disassembly And Assembly Of The Transmission​
3.3 Drive Axle​
3.4 Reduction Drive​
3.5 Common Faults And Troubleshooting​
4 Steering System
4.1 Overview​
4.2 Steering Device​
4.3 Steering Axle​
5 Braking System
5.1 Overview​
5.2 Brake Pedal Assembly​
5.3 Parking Brake​
5.4 Brake Assembly​
5.5 Bleeding The Braking System​
6 Truck Body
6.1 Overview​
6.2 Dashboard Assembly​
6.3 Machine Hood And Floor​
6.4 Door Assembly​
6.5 Overhead Guard​
6.6 Counterweight Assembly​
6.7 Battery Removal And Fixtures​
6.8 Driving Seat​
7 Hydraulic System
7.1 Overview​
7.2 Oil Tank Assembly​
7.3 Oil Pump Unit​
7.4 Steering Pipe​
7.5 Tilt Pipeline​
7.6 Multi-Way Valve Control​
7.7 Multi-Way Valve Assembly​
7.8 Pressure Adjustment Of The Main Safety Valve​
7.9 Hydraulic Steering Gear​
7.12 Fault Diagnosis And Troubleshooting​
8 Lifting System
8.1 Overview​
8.2 Main Technical Parameters Of The Lifting Compo​
8.3 Lift-Up Assembly Removal And Installation​
8.4 Tilt Cylinder​
8.5 Lifting Cylinder​
8.6 Troubleshooting The Lifting Components​
9 Controller Assembly
9.1 Enpower Controller​
9.2 Disassembly And Assembly​
10 Electric Attachments
10.1 Dashboard​
10.2 Control Box Assembly​
10.2 Switch​
10.3 Lighting System​
10.4 Other Electrical Components​
11 Schematic Diagrams
11.1 Electrical Schematic Diagram​
11.2 Hydraulic Schematic Diagram​
12 Cab
12.1 Overview​
12.2 Cab Overhead Guard​
12.3 Cab Door Assembly​
12.4 Cab Rear Window Assembly​
12.5 Cab Front Windshield Assembly​
13 Bolts Tightening Torque Table
