Hangcha Transmission 1.5t-1.8t KAPEC Operation Maintenance Manual 2012 EN
Brand: Hangcha
Type of Machine: Transmission
Type of Document: Disassembly and Assembly, Maintenance Manual, Trouble Shooting, Structure and Operation Manual
Model: Hangcha 1.5t-1.8t KAPEC Transmission
Date: 2012
Number of Pages: 75 Pages
-Transmission
Transmission structure and operation
1. Structure
2. Specification
3. Installation view
4. Operation
5. Hydraulic circuit
6. Power flow
7. Control valve
8. Clutch
Transmission disassembly and assembly
1. Disassembly.
1-1 Disassembly of transmission assay
1-2 Disassembly of gear assemblies
2. Assembly
2-1 Assembly of gear assemblies
2-2 Assembly of transmission assay
Maintenance
1. Oil recommendation
2. Period of exchange oil
3. Period of overhaul exchange of parts
4. Test
Trouble shooting
1. Output does not go up
2. Power is not transmitted
3. Oil temperature rise abnormally
4. Clutch or converter oil pressure is too high
5. Clutch or converter oil pressure is too low
6. Noise occurs
Drive axle Structure and Operation
1. Power train Diagram
1) Structure
2) Specification
3) Installation View
4) Operation
2. Carrier sub ass'y
1) Structure
2) Operation
3. Diff sub ass'y
1) Operation
2) Structure
Drive axle Disassembly and Assembly
1. Disassembly
2. Assembly
2-1 Carrier sub assembly
2-1-1 Differential device assembly
2-1-2 Adjusting shim and pinion shaft assembly
2-1-3 Assemble of parking sub assembly
2-1-4 Assemble of carrier case cover assemble
2-1-5 Adjusting the gearset backlash
2-1-6 Adjusting tooth contact pattern of the gearset
2-2 Assemble of carrier assembly
2-3 Traveling brake system assembly
2-3-1 Axle shaft assembly
2-3-2 Piston assembly
2-4 Hub assembly
2-4-1 Hub sub assembly
2-5 Assemble of hub sub assembly
2-6 The rest part assembly
- Drive axle
- Drive axle
2-7 Functional Test of Hydraulic apply brake
Lubrication and Maintenance
1. General Information
2. Magnets and Magnetic Drain Plugs
3. Breather
4. Oil level
4-1. Check and Adjust Oil
4-2. Oil Change
4-3. Oil Capacity and Using oil list
5. Period of overhaul
Trouble shooting
1. Noise and Vibration
2. Oil leakage
3. Axle Does Not Revolution
4. Brake Does Not Apply
5. Brake Does Not Release
6. Braking Performance
Brand: Hangcha
Date: 2012
-Transmission
1. Structure
2. Specification
4. Operation
6. Power flow
7. Control valve
8. Clutch
1. Disassembly.
2. Assembly
Maintenance
4. Test
Trouble shooting
6. Noise occurs
1) Structure
2) Specification
4) Operation
1) Structure
2) Operation
3. Diff sub ass'y
1) Operation
2) Structure
1. Disassembly
2. Assembly
2-4 Hub assembly
- Drive axle
- Drive axle
3. Breather
4. Oil level
4-2. Oil Change
Trouble shooting
2. Oil leakage
- Hangcha Forklift 1.5-3.5 T R Series LPG Service And Parts Manual
- Hangcha R Series 5-10t Forklift Truck Parts Catalog
- Hangcha Forklift Truck 1~5t J Series Counterbalanced Battery SERVICE MANUAL
- Hangcha Forklift Truck R series 2.0-2.5t Parts Catalogue
- Hangcha Forklift Truck 1t-3.5t R Series SERVICE MANUAL
- HANGCHA J Series Battery Forklift Service Manual
- Hangcha Forklift Truck J series 4 wheel electric 1.0-3.5t Parts Catalogue
- Hangcha Forklift Truck 5.0-10.0t Parts Catalogue
- Hangcha Forklift Truck 5.0-6.0t Parts Catalogue
- Hangcha Forklift Truck 4.0-5.0t Parts Catalogue
- Hangcha J Series 4 Wheel Electric Forklift Truck 1-3.5t
- Hangcha Forklift Truck R series 1.0-1.8t Parts Catalogue
- Hangcha Forklift Truck J SERIES THREE WHEEL COUNTERBALANCED ELECTRICAL Parts Catalogue
- Hangcha Forklift Truck R2_25t Parts Catalog
- Hangcha Forklift Truck 12-16t Parts Catalogue (2011)
