Hangcha Forklift 5t-10t CPCD50-XRW70 to CPCD100-XRG87B Service Manual 2019 EN
Brand: Hangcha
Type of Machine: Internal Combustion Counterbalanced Forklift Truck
Type of Document: Service Manual, Electrical and Hydraulic Diagram
Model: Hangcha X Series 5t-10t
CPCD50-XRW70, CPCD60-XRW70, CPCD70-XRW70, CPCD85-XRW70
CPCD100-XRW70, CPCD50-XRW70B, CPCD60-XRW70B, CPCD70-XRW70B
CPCD85-XRW70B, CPCD100-XRW70B, CPCD50-XRW14, CPCD60-XRW14
CPCD70-XRW14, CPCD85-XRW14, CPCD100-XRW14, CPCD50-XRW14B
CPCD60-XRW14B, CPCD70-XRW14B, CPCD85-XRW14B, CPCD100-XRW14B
CPQYD50-XRW57, CPQYD60-XRW57, CPQYD70-XRW57, CPCD50-XRG76
CPCD60-XRG76, CPCD70-XRG76, CPCD50-XRG77, CPCD60-XRG77
CPCD70-XRG77, CPCD85-XRG77, CPCD100-XRG77, CPCD50-XRG77-GW
CPCD60-XRG77-GW, CPCD70-XRG77-GW, CPCD50-XRG78, CPCD60-XRG78
CPCD70-XRG78, CPCD85-XRG78, CPCD100-XRG78, CPCD50-XRG79
CPCD60-XRG79, CPCD70-XRG79, CPCD85-XRG79, CPCD100-XRG79
CPCD50-XRW28, CPCD60-XRW28, CPCD70-XRW28, CPCD85-XRW28
CPCD100-XRW28, CPCD50-XRW28B, CPCD60-XRW28B, CPCD70-XRW28B
CPCD85-XRW28B, CPCD100-XRW28B, CPCD50-XRG87, CPCD60-XRG87
CPCD70-XRG87, CPCD85-XRG87, CPCD100-XRG87, CPCD50-XRG87B
CPCD60-XRG87B, CPCD70-XRG87B, CPCD85-XRG87B, CPCD100-XRG87B
Date: 2019
Number of Pages: 113 Pages
I.POWER SYSTEM
1.POWER DISPOSITION
2.AIR INTAKE SYSTEM
3.EXHAUST SYSTEM
4.COOLING SYSTEM
II.TRANSMISSION SHAFT
III.HYDRAULIC TRANSMISSION GEAR BOX
1.SUMMARIZE
2.MAIN TECHNICAL PARAMETER
3.WORKING PRINCIPLE
4.STRUCTURE INTRODUCTION
5.INSTALLMENT AND USE NOTICE
6. FAULT REASON AND CORRECTIONS
IV. DRIVE AXLE ASSEMBLY
1. DRIVE AXLE BASIC STRUCTURE AND ITS WORKING PRINCIPLE
2.PERIODICAL TECHNICAL MAINTENANCE
3.DRIVE AXLE OIL ADDING /DRAINAGE WAY AND FUEL-INJECTION QUANTITY
4. DRIVE AXLE HOISTING
5. DRIVEN SPIRAL BEVEL GEAR ENGAGEMENT CONTACT CONDITION AND ADJUSTMENT
6. FAULT DIAGNOSIS AND CORRECTIONS
7. DISMANTLE AND ASSEMBLE
V. STEERING SYSTEM
1.HYDRAULIC STEERING GEAR
2.STEERING AXLE
VI BREAK SYSTEM
1. GENERAL SPECIFICATION
2. TROUBLE DIAGNOSES AND CORRECTION
3. BRAKE PEDAL AND INCHING BRAKE PEDAL
4. SERVICE BRAKE (5T-7T)
5. HYDRAULICBOOSTER (5T-7T)
6. BRAKE AND WHEEL CYLINDER(5T-7T)
7. SERVICE BRAKE BOOSTER VALVE AND ACCUMULATOR(8T-10T)
8.SERVICE BRAKE(8T-10T)
9. HYDRAULIC BRAKE MALFUNCTION DIAGNOSIS
10. EXHAUST OF AIR IN THE HYDRAULIC SYSTEM
11. BRAKING SYSTEM SCHEMATIC DIAGRAM
VII. HYDRAULIC SYSTEM
1. DATA
2. TROUBLE DIAGNOSES AND CORRECTIONS
3. PUMP
4. CONTROL VALVE
5. ONE WAY GOVERNED SPEED VALVE
6. LIFTING CYLINDER
7. TILTING CYLINDER
8.AIR EXHAUST IN HYDRAULIC SYSTEM
9. HYDRAULIC SYSTEM FAULT DIAGNOSIS AND CORRECTIONS
10.HYDRAULIC SYSTEM PRINCIPLE DIAGRAM
VIII. LIFTING SYSTEM
1. ASSEMBLE DEBUGGING DATA
2. FAILURE DIAGNOSE AND CORRECTIONS
3.GENERAL
4. MAST DISMANTLE AND INSTALL ADJUSTMENT
5. DISASSEMBLY AND INSTALLATION OF LIFTING CYLINDER
6.DISASSEMBLY AND INSTALLATION OF TILTING CYLINDER
7.NOTICING PROCEEDING OF DEBUGGING
IX. ELECTRICAL SYSTEM
1.ELECTRICAL PLATE ASSEMBLY
2.KEY SWITCH(START)
3.COMBINATION INSTRUMENT ASSEMBLY
4.COMBINATION SWITCH ASSEMBLY
5.STARTER AND GENERATOR REPAIR
6.ELECTRICAL SYSTEM DIAGRAM
X. OVERHEAD GUARD DISASSEMBLY AND INSTALLATION
Brand: Hangcha
Date: 2019
I.POWER SYSTEM
1.POWER DISPOSITION
2.AIR INTAKE SYSTEM
3.EXHAUST SYSTEM
4.COOLING SYSTEM
1.SUMMARIZE
3.WORKING PRINCIPLE
V. STEERING SYSTEM
2.STEERING AXLE
VI BREAK SYSTEM
1. DATA
3. PUMP
4. CONTROL VALVE
6. LIFTING CYLINDER
7. TILTING CYLINDER
3.GENERAL
2.KEY SWITCH(START)
- Hangcha Forklift 1.5-3.5 T R Series LPG Service And Parts Manual
- Hangcha R Series 5-10t Forklift Truck Parts Catalog
- Hangcha Forklift Truck 1~5t J Series Counterbalanced Battery SERVICE MANUAL
- Hangcha Forklift Truck R series 2.0-2.5t Parts Catalogue
- Hangcha Forklift Truck 1t-3.5t R Series SERVICE MANUAL
- HANGCHA J Series Battery Forklift Service Manual
- Hangcha Forklift Truck J series 4 wheel electric 1.0-3.5t Parts Catalogue
- Hangcha Forklift Truck 5.0-10.0t Parts Catalogue
- Hangcha Forklift Truck 5.0-6.0t Parts Catalogue
- Hangcha Forklift Truck 4.0-5.0t Parts Catalogue
- Hangcha J Series 4 Wheel Electric Forklift Truck 1-3.5t
- Hangcha Forklift Truck R series 1.0-1.8t Parts Catalogue
- Hangcha Forklift Truck J SERIES THREE WHEEL COUNTERBALANCED ELECTRICAL Parts Catalogue
- Hangcha Forklift Truck R2_25t Parts Catalog
- Hangcha Forklift Truck 12-16t Parts Catalogue (2011)
