Martin Welker
104
230,792
Hangcha Forklift 5t-10t CPCD50-XRG77-X to CPCD100-XRW28B-X Service Manual 2020 EN
Brand: Hangcha
Type of Machine: Container Forklift Truck
Type of Document: Service Manual, Electrical and Hydraulic Diagram
Model: Hangcha X Series 5t-10t
CPCD100-XRW70-X, CPCD100-XRW28B-X, CPCD50-XRG77-X, CPCD60-XRG77-X
CPCD70-XRG77-X, CPCD85-XRG77-X, CPCD100-XRG77-X, CPCD100-XRW70-X
CPCD100-XRW28B-X, CPCD50-XRG77-X, CPCD60-XRG77-X, CPCD70-XRG77-X
Date: 2020
Number of Pages: 103 Pages
I.POWER SYSTEM
1.POWER DISPOSITION
2.AIR INTAKE SYSTEM
3.EXHAUST SYSTEM
4.COOLING SYSTEM
II.TRANSMISSION SHAFT
III.HYDRAULIC TRANSMISSION GEAR BOX
1.SUMMARIZE
2.MAIN TECHNICAL PARAMETER
3.WORKING PRINCIPLE
4.STRUCTURE INTRODUCTION
5.INSTALLMENT AND USE NOTICE
6. FAULT REASON AND CORRECTIONS
IV. DRIVE AXLE ASSEMBLY
1. DRIVE AXLE BASIC STRUCTURE AND ITS WORKING PRINCIPLE
2.PERIODICAL TECHNICAL MAINTENANCE
3.DRIVE AXLE OIL ADDING /DRAINAGE WAY AND FUEL-INJECTION QUANTITY
4. DRIVE AXLE HOISTING
5. DRIVEN SPIRAL BEVEL GEAR ENGAGEMENT CONTACT CONDITION AND ADJUSTMENT
6. FAULT DIAGNOSIS AND CORRECTIONS
7. DISMANTLE AND ASSEMBLE
V. STEERING SYSTEM
1.HYDRAULIC STEERING GEAR
2.STEERING AXLE
VI BREAK SYSTEM
1. GENERAL SPECIFICATION
2. TROUBLE DIAGNOSES AND CORRECTION
3. BRAKE PEDAL AND INCHING BRAKE PEDAL
4. SERVICE BRAKE (5T-7T)
5. HYDRAULICBOOSTER (5T-7T)
6. BRAKE AND WHEEL CYLINDER(5T-7T)
7. SERVICE BRAKE BOOSTER VALVE AND ACCUMULATOR(8T-10T)
8.SERVICE BRAKE(8T-10T)
9. HYDRAULIC BRAKE MALFUNCTION DIAGNOSIS
10. EXHAUST OF AIR IN THE HYDRAULIC SYSTEM.
11. BRAKING SYSTEM SCHEMATIC DIAGRAM
VII. HYDRAULIC SYSTEM
1. DATA
2. TROUBLE DIAGNOSES AND CORRECTIONS
3.PUMP
4. CONTROL VALVE
5. ONE WAY GOVERNED SPEED VALVE
6. LIFTING CYLINDER
7. TILTING CYLINDER
8.AIR EXHAUST IN HYDRAULIC SYSTEM
9. HYDRAULIC SYSTEM FAULT DIAGNOSIS AND CORRECTIONS
10.HYDRAULIC SYSTEM PRINCIPLE DIAGRAM
VIII. LIFTING SYSTEM
1. ASSEMBLE DEBUGGING DATA
2. FAILURE DIAGNOSE AND CORRECTIONS
3.GENERAL
4. MAST DISMANTLE AND INSTALL ADJUSTMENT
5. DISASSEMBLY AND INSTALLATION OF LIFTING CYLINDER
6.DISASSEMBLY AND INSTALLATION OF TILTING CYLINDER
7.NOTICING PROCEEDING OF DEBUGGING
IX. ELECTRICAL SYSTEM
1.ELECTRICAL PLATE ASSEMBLY
2.KEY SWITCH(START
3.COMBINATION INSTRUMENT ASSEMBLY
4.COMBINATION SWITCH ASSEMBLY
5.STARTER AND GENERATOR REPAIR
6.ELECTRICAL SYSTEM DIAGRAM
X. OVERHEAD GUARD DISASSEMBLY AND INSTALLATION
