Hangcha Forklift 1t-3.5t CPQ10N-RW21 to CPCD35N-RW43B Service Manual 2019 EN
Brand: Hangcha
Type of Machine: Counterbalanced Forklift Truck
Type of Document: Service Manual, Electrical and Hydraulic Diagram
Model: Hangcha R Series 1t-3.5t
CPQ10N-RW21, CPQ15N-RW21, CPQ18N-RW21, CPQD10N-RW21, CPQD15N-RW21
CPQD18N-RW21, CPQ10N-RW21-Y, CPQ15N-RW21-Y, CPQ18N-RW21-Y, CPQD10N-RW21-Y
CPQD15N-RW21-Y, CPQD18N-RW21-Y, CPQD20N-RW21-Y, CPQD25N-RW21-Y, CPQ20N-RW22
CPQ25N-RW22, CPQ30N-RW22, CPQ35N-RW22, CPQD20N-RW22, CPQD25N-RW22
CPQD30N-RW22, CPQD35N-RW22, CPQD20N-RW22A, CPQD25N-RW22A, CPQD30N-RW22A
CPQD35N-RW22A, CPQD20N-RW22B, CPQD25N-RW22B, CPQD30N-RW22B, CPQD35N-RW22B
CPQ20N-RW22-Y, CPQ25N-RW22-Y, CPQ30N-RW22-Y, CPQ35N-RW22-Y, CPQD20N-RW22-Y
CPQD25N-RW22-Y, CPQD30N-RW22-Y, CPQD35N-RW22-Y, CPQD20N-RW22A-Y, CPQD25N-RW22A-Y
CPQD30N-RW22A-Y, CPQD35N-RW22A-Y, CPQD20N-RW22B-Y, CPQD25N-RW22B-Y, CPQD30N-RW22B-Y
CPQD35N-RW22B-Y, CPQD15N-RW51-Y, CPQD18N-RW51-Y, CPQD20N-RW51-Y, CPQD25N-RW51-Y
CPQD20N-RW52-Y, CPQD25N-RW52-Y, CPQD30N-RW52-Y, CPQD35N-RW52-Y, CPQD20N-RW52B-Y
CPQD25N-RW52B-Y, CPQD30N-RW52B-Y, CPQD35N-RW52B-Y, CPQ10N-RG26, CPQ15N-RG26
CPQ18N-RG26, CPQ10N-RG26, CPQ15N-RG26, CPQ18N-RG26, CPQ10N-RG26-J
CPQ15N-RG26-J, CPQ18N-RG26-J, CPQ10N-RG26-J, CPQ15N-RG26-J, CPQ18N-RG26-J
CPCD20N-RW15A, CPCD25N-RW15A, CPCD30N-RW15A, CPCD35N-RW15A, CPC20N-RW13
CPC25N-RW13, CPC30N-RW13, CPC35N-RW13, CPCD20N-RW13, CPCD25N-RW13
CPCD30N-RW13, CPCD35N-RW13, CPCD20N-W13B, CPCD25N-W13B, CPCD30N-W13B
CPCD35N-W13B, CPC20N-RG2, CPC25N-RG2, CPCD30N-RG2, CPCD35N-RG2
CPC20N-RG2, CPC25N-RG2, CPCD30N-RG2, CPCD35N-RG2, CPC20N-RG5
CPC25N-RG5, CPCD30N-RG5, CPCD35N-RG5, CPC20N-RG5, CPC25N-RG5
CPCD30N-RG5, CPCD35N-RG5, CPC20N-RG32, CPC25N-RG32, CPCD20N-RG32
CPCD25N-RG32, CPC30N-RG32, CPC35N-RG32, CPCD30N-RG32, CPCD35N-RG32
CPQ(D)10N-RW7, CPQ(D)15N-RW7, CPQ(D)18N-RW7, CPQ(D)20N-RW7, CPQ(D)25N-RW7
CPQ(D)30N-RW7, CPQ(D)35N-RW7, CPQD10N-RW7-Y, CPQD15N-RW7-Y, CPQD18N-RW7-Y
CPQD20N-RW7-Y, CPQD25N-RW7-Y, CPQD30N-RW7-Y, CPQD35N-RW7-Y, CPQD20N-RW26-Y
CPQD25N-RW26-Y, CPQD30N-RW26-Y, CPQD35N-RW26-Y, CPCD20N-RW27, CPCD25N-RW27
CPCD30N-RW27, CPCD35N-RW27, CPCD20N-RW56, CPCD25N-RW56, CPCD20N-RW56B
CPCD25N-RW56B, CPCD30N-RW56, CPCD35N-RW56, CPCD30N-RW56B, CPCD35N-RW56B
CPCD10N-RW32, CPCD15N-RW32, CPCD18N-RW32, CPCD20N-RW32, CPCD25N-RW32
CPCD20N-RW33, CPCD25N-RW33, CPCD20N-RW33B, CPCD25N-RW33B, CPCD20N-RW33M
CPCD25N-RW33M, CPCD30N-RW33, CPCD35N-RW33, CPCD30N-RW33B, CPCD35N-RW33B
CPCD30N-RW33M, CPCD35N-RW33M, CPCD10N-RW10, CPCD15N-RW10, CPCD18N-RW10
CPCD20N-RW10, CPCD25N-RW10, CPCD30N-RW10, CPCD35N-RW10, CPCD20N-RW10B
CPCD25N-RW10B, CPCD30N-RW10B, CPCD35N-RW10B, CPCD20N-RW55, CPCD25N-RW55
CPCD20N-RW55B, CPCD25N-RW55B, CPCD30N-RW55, CPCD35N-RW55, CPCD30N-RW55B
CPCD35N-RW55B, CPC10N-RG50, CPC15N-RG50, CPC18N-RG50, CPCD10N-RG50
CPCD15N-RG50, CPCD18N-RG50, CPC20N-RG51, CPC25N-RG51, CPCD20N-RG51
CPCD25N-RG51, CPC30N-RG51, CPC35N-RG51, CPCD30N-RG51, CPCD35N-RG51
CPC38-RG51, CPCD38-RG51, CPC20N-RG52, CPC25N-RG52, CPCD20N-RG52
CPCD25N-RG52, CPC30N-RG52, CPC35N-RG52, CPCD30N-RG52, CPCD35N-RG52
CPC38-RG52, CPCD38-RG52, CPC20N-RG59, CPC25N-RG59, CPCD20N-RG59
CPCD25N-RG59, CPC30N-RG59, CPC35N-RG59, CPCD30N-RG59, CPCD35N-RG59
CPC38-RG59, CPCD38-RG59, CPC20N-RG60, CPC25N-RG60, CPCD20N-RG60
CPCD25N-RG60, CPC30N-RG60, CPC35N-RG60, CPCD30N-RG60, CPCD35N-RG60
CPC38-RG60, CPCD38-RG60, CPC20N-RG59, CPC25N-RG59, CPCD20N-RG59
CPC38-RG60, CPCD38-RG60, CPCD20N-RW43, CPCD25N-RW43, CPCD20N-RW43B
CPCD25N-RW43B, CPCD30N-RW43, CPCD35N-RW43, CPCD30N-RW43B, CPCD35N-RW43B
CPCD20N-RW59, CPCD25N-RW59, CPCD20N-RW59B, CPCD25N-RW59B, CPCD30N-RW59
CPCD35N-RW59, CPCD30N-RW59B, CPCD35N-RW59B, CPCD38-RW59, CPCD38-RW59B
Date: 2019
Number of Pages: 128 Pages
I . Power System
1. Engine for Forklift
2. GCT(NISSAN) K21 K25 gasoline
3. C240 PKJ-30 Diesel
4. TD27AA diesel
II . Clutch
1. Data
2. Inspection and Adjustment
3.Trouble diagnoses and correction
4. Clutch
III. Manual transmission reduction gear and differential
1. Parameter
2. Trouble diagnoses and correction
3. Summary
4. Gear shift
5. Reduction gear
6. Differential
7. Replace for yoke
8. Reassemble yoke
9.Remove transmission assemble
IV. Hydrodynamic power transmission gear-box hydrodynamic torque converter
1.Data
2. Summary
3. Working principles
4. Torque converter
5. Hydrodynamic clutch
6. Oil-supply pump
7. Inching valve
8. Case and control valve
9. Gear-box shell body
10. Reduction transmission and differentials
V . Driving axle
1. Date
2. Trouble diagnoses and corrections
3. Assembly and disassembly of driving axle
4. Axle shaft and wheel hub
5. Bearing adjusting
VI. Steering axle
1. General specifications
2. Trouble diagnoses corrections
3. Steering axle
4.Kingpin and steering spindle
5. Wheel bearing adjustment
VII. Steering system
1. Data
2.Trouble diagnoses
3. Summarize
4. Install steering system
VIII. Brake system
1.Trouble and diagnoses and corrections
2. Summary
IX.Hydraulic system
1. Data
3. Main pump
4. Control valve
5. Hydraulic piping
X .Lifting system
1. Assemble debugging data
3. Summary
4. Removal and adjustment
5. Disassembly and installation of lifting jack
6. Disassembly and installation of tilting cylinder
7. Noticing proceeding of debugging
IX.Electrical system
Brand: Hangcha
Date: 2019
I . Power System
4. TD27AA diesel
II . Clutch
1. Data
4. Clutch
1. Parameter
3. Summary
4. Gear shift
5. Reduction gear
6. Differential
7. Replace for yoke
8. Reassemble yoke
1.Data
2. Summary
4. Torque converter
6. Oil-supply pump
7. Inching valve
V . Driving axle
1. Date
VI. Steering axle
3. Steering axle
1. Data
2.Trouble diagnoses
3. Summarize
VIII. Brake system
2. Summary
IX.Hydraulic system
1. Data
3. Main pump
4. Control valve
5. Hydraulic piping
X .Lifting system
3. Summary
- Hangcha Forklift 1.5-3.5 T R Series LPG Service And Parts Manual
- Hangcha R Series 5-10t Forklift Truck Parts Catalog
- Hangcha Forklift Truck 1~5t J Series Counterbalanced Battery SERVICE MANUAL
- Hangcha Forklift Truck R series 2.0-2.5t Parts Catalogue
- Hangcha Forklift Truck 1t-3.5t R Series SERVICE MANUAL
- HANGCHA J Series Battery Forklift Service Manual
- Hangcha Forklift Truck J series 4 wheel electric 1.0-3.5t Parts Catalogue
- Hangcha Forklift Truck 5.0-10.0t Parts Catalogue
- Hangcha Forklift Truck 5.0-6.0t Parts Catalogue
- Hangcha Forklift Truck 4.0-5.0t Parts Catalogue
- Hangcha J Series 4 Wheel Electric Forklift Truck 1-3.5t
- Hangcha Forklift Truck R series 1.0-1.8t Parts Catalogue
- Hangcha Forklift Truck J SERIES THREE WHEEL COUNTERBALANCED ELECTRICAL Parts Catalogue
- Hangcha Forklift Truck R2_25t Parts Catalog
- Hangcha Forklift Truck 12-16t Parts Catalogue (2011)
