Hangcha A Series 1.5t-2.0t CBD15-AMA-SI to CBD20-AMA-SID Service Manual 2024
Brand: Hangcha
Type of Machine: Pallet Truck
Type of Manual: Service Manual, Wiring Diagrams, Hydraulic Diagrams
Model: Hangcha A Series 1.5t-2.0t Pallet Truck
CBD15-AMA-SI CBD20-AMA-SI CBD15-AMJ-SI CBD15-AMJ2-SI CBD15-AMA-SID CBD15-AMJ-SID CBD20-AMA-SID
Publication Date: 2024
Number of Pages: 40 Pages
1 Driving Assembly Overview
Precautions For Disassembly And Assembly
Brand: Hangcha
1.1 Technical Parameters
1.2 Precautions For Installation And Use
1.3 Faults And Troubleshooting
1.4 Driving Motor
Technical ParametersPrecautions For Disassembly And Assembly
Temperature Sensor, Encoder Replacement
Main Faults Of The Temperature Sensor:
Main Encoder Faults:
Encoder Replacement
2 Hydraulic System2.1 Hydraulic Schematic Diagram
Cbd20-Ama-Si Hydraulic Schematic Diagram
2.2 Hydraulic System Fault Diagnosis And Troublesh
3 Electrical System3.1 Electrical Schematic Diagram
3.2 Traction Motor Controller
一、Azm2410 Controller Fault(I)1 Motor Stall
(Ii)2 Motor Hall Sensor Fault
(Ii)3 Motor Overheating
(Iv)4 Drive Tube Overheating
(V) 5 Alarm Temperature Of Drive Tube
(Vi)6 U-Phase Over-Current Hardware Fault
(Vii)7 V-Phase Over-Current Hardware Fault
(Viii)8 W-Phase Over-Current Hardware Fault
(Iv)9 Bus Over-Voltage Hardware Fault
(X)10 Bus Over-Current Hardware Fault
(Xi)11 Hardware Fault
(Xii)12 Battery Over-Voltage
(Xiii)13 Battery Under-Voltage
(Xiv) 14 Motor Reaches Warning Temperature
(Xv)15 Low Battery Level
(Xvi)16 Bus Over-Voltage
(Xvii)17 Bus Under-Voltage
(Xviii)18 Bus Over-Current Fault
(Xix)19 Max. Iq Value And Timeout Error
(Xx)20 Power-On Accelerator Non-Reset (Return To Z
(Xxi)21 Loss Of Tie Bar Interlock Signal During Ne
(Xxii)22 Startup Error Of Accelerator Before Lever
(Xxiii)23 Emergency Reverse Trigger Fault
(Xxiv) 24 Forward And Reverse Switch Error
(Xxv) 25 Speeding Error
(Xxvi)31 Motor Temperature Sensor Disconnected
(Xxvi) 32 Motor Temperature Sensor Short Circuit
- Hangcha Forklift 1.5-3.5 T R Series LPG Service And Parts Manual
- Hangcha R Series 5-10t Forklift Truck Parts Catalog
- Hangcha Forklift Truck 1~5t J Series Counterbalanced Battery SERVICE MANUAL
- Hangcha Forklift Truck R series 2.0-2.5t Parts Catalogue
- Hangcha Forklift Truck 1t-3.5t R Series SERVICE MANUAL
- HANGCHA J Series Battery Forklift Service Manual
- Hangcha Forklift Truck J series 4 wheel electric 1.0-3.5t Parts Catalogue
- Hangcha Forklift Truck 5.0-10.0t Parts Catalogue
- Hangcha Forklift Truck 5.0-6.0t Parts Catalogue
- Hangcha Forklift Truck 4.0-5.0t Parts Catalogue
- Hangcha J Series 4 Wheel Electric Forklift Truck 1-3.5t
- Hangcha Forklift Truck R series 1.0-1.8t Parts Catalogue
- Hangcha Forklift Truck J SERIES THREE WHEEL COUNTERBALANCED ELECTRICAL Parts Catalogue
- Hangcha Forklift Truck R2_25t Parts Catalog
- Hangcha Forklift Truck 12-16t Parts Catalogue (2011)
