Hyundai
86
176,834
Hangcha A Series 1.2t-1.6t CQDB12-AC1S-J to CQDB16-AC2S-IJ Operation Maintenance Manual 2023
Brand: Hangcha
Type of Machine: Pallet Truck
Type of Manual: Operation And Maintenance Manual, Hydraulic Diagrams, Electric Diagrams
Model: Hangcha A Series 1.2t-1.6t Pallet Stackers
CQDB12-AC1S-J CQDB16-AC1S-J CQDB12-AZ3S-J CQDB16-AZ3S-J CQDB12-AC1S-IJ
CQDB16-AC1S-IJ CQDB12-AC2S-J CQDB16-AC2S-J CQDB12-AC2S-IJ CQDB16-AC2S-IJ
Publication Date: 2023
Number of Pages: 150 Pages
Part 1: Operation And Maintenance
1 Correct Use And Application
2.1 General​
1.2 Correct Application​
1.3 Approved Application Conditions​
1.4 Cautions For The Use Of Cold Storage Truck​
1.5 Cautions For The Use Of Lithium Battery Truck​
1.6 Proprietor Responsibilities​
1.7 Attachment Installation Or Modification To The Truck​
2 Truck Introduction
2.1 Truck Models Meaning​
2.2 Main Parts And Functional Description​
2.2.1 Main Part Introduction​
2.2.2 Functional Description​
2.3 Displays And Controls​
2.3.1 Display​
D13l Display Characteristics:
2.3.2 Open Or Down The Safety Side Arms​
2.4 Standard Technical Specifications​
2.5 Product Plates And Warning Labels Location​
3 Safety Rules
4 Transport
4.1 Lifting The Truck By Crane​
4.2 Securing The Truck For Transport​
4.3 Transport​
5 Battery
5.1 Battery Safety Precautions​
5.1.1 Safety Precautions For Using Lead-Acid Batteries​
5.1.2 Safety Precautions For Using Lithium Battery​
5.2 Battery Maintenance​
5.2.1 Lead-Acid Battery Maintenance​
5.2.2 Lithium Battery Maintenance​
5.3 Dimension - Weight​
5.4 Charging The Battery​
Lithium Battery Charging
5.5 Changing The Battery​
Spc Series Intelligent Charger User Manual
6 New Truck Breaking-In
7 Operation
7.1 Check Before Operation​
7.2 Starting Up​
7.3 Travel​
7.4 Steering​
7.5 Brakes​
7.6 Loading​
7.7 Unloading​
7.8 Parking The Truck Securely​
8 Deposit The Truck
8.1 Deposit The Truck For Long Time​
8.2 Start Running After Deposit For A Long Time​
9 Maintenance
9.1 Maintenance General​
9.2 Periodic Maintenance Schedule​
9.3 Truck Used Oil And Lubrication​
9.4 Replace The Key Safe Parts Periodically​
9.5 Screw Down The Wheel Retaining Nut​
9.7 Removing The Safety Guard​
9.8 Install The Load Bracket​
9.9 Adjust The Forks​
Part 2: Structure, Principle And Maintenance
1 Drive System
1.1 Reduction Gearbox​
1.1.1 Working Principle​
1.1.2 Dismount And Assemble Order​
1.1.3 Notice To Installment And Use​
1.1.4 Fault And Troubleshooting​
1.2 Motor​
1.3 Electromagnetic Brake​
1.3.1 Working Principle​
1.3.2 Brake Installment​
1.3.3 Brake Air Gap Adjustment​
1.3.4 Maintenance​
1.3.5 Common Fault And Troubleshooting​
2 Hydraulic System
2.1 Hydraulic System Working Principle​
2.2 Hydraulic Unit​
2.3 Hydraulic System Fault Diagnosis And Correction​
3 Electric System
3.1 Principles Of Electrical System​
3.2 Fault Code Table​
Attachment:Table For Bolt’s Tightening Torque
Relevant Safety Command And Standard (Ce Models)
