Hyundai
86
176,834
Hangcha A Series 1.2t-1.6t CDD12-AC1-L to CDD16-AC2-LI Operation Maintenance Manual 2022
Brand: Hangcha
Type of Machine: Pallet Stackers
Type of Manual: Operation And Maintenance Manual, Wiring Diagrams, Hydraulic Diagram
Model: Hangcha A Series 1.2t-1.6tPallet Stackers
CDD12-AC1-L CDD14-AC1-L CDD16-AC1-L CDD12-AC1-LI CDD14-AC1-LI CDD16-AC1-LI
CDD12-AZ3-L CDD14-AZ3-L CDD16-AZ3-L CDD12-AZ3-LI CDD14-AZ3-LI CDD16-AZ3-LI
CDD12-AC2-L CDD14-AC2-L CDD16-AC2-L CDD12-AC2-LI CDD14-AC2-LI CDD16-AC2-LI
Publication Date: 2022
Number of Pages: 112 Pages
Part 1: Operation And Maintenance
1 Correct Use And Application
1.1 General​
1.2 Correct Application​
1.3 Approved Application Conditions​
1.4 Cautions For The Use Of Cold Storage Truck​
1.5 Cautions For The Use Of Lithium Battery Truck​
1.6 Proprietor Responsibilities​
1.7 Attachment Installation Or Modification To The Truck​
2 Truck Introduction
2.1 Application​
2.1.1 Truck Models Meaning​
2.2 Main Parts And Functional Description​
2.2.1 Main Part Introduction​
2.2.2 Functional Description​
2.3 Displays And Controls​
2.3.1 Display​
D13l Display Characteristics:
2.4 Standard Technical Specifications​
2.5 Product Plates And Warning Labels Location​
2.5.1 Nameplate​
2.5.2 Truck Rated Capacities And Load Centers Graph​
2.5.3 Double Decker Mode Load Chart​
3 Safety Rules
4 Transport
4.1 Lifting The Truck By Crane​
4.2 Securing The Truck For Transport​
4.3 Transport​
5 Battery
5.1 Attention For Using Battery​
5.2 Dimension - Weight​
5.3 Charging The Battery​
5.4 Changing The Battery​
6 New Truck Breaking-In
7 Operation
7.1 Check Before Operation​
7.2 Starting Up​
7.3 Travel​
7.4 Steering​
7.5 Brakes​
7.6 Lifting Load​
7.7 Transporting Load​
7.8 Depositing Load​
7.9 Parking The Truck Securely​
8 Deposit The Truck
8.1 Deposit The Truck For Long Time​
8.2 Start Running After Deposit For A Long Time​
9 Maintenance
9.1 Maintenance General​
9.2 Periodic Maintenance Schedule​
9.3 Truck Used Oil And Lubrication​
9.4 Replace The Key Safe Parts Periodically​
9.5 Screw Down The Wheel Retaining Nut​
9.6 Removing The Rear Panel Assy​
9.7 Install The Load Bracket​
Part 2: Structure, Principle And Maintenance
1.1 Reduction Box​
1.1.1 Working Principle​
1.1.2 Dismount And Assemble Order​
1.1.3 Notice To Installment And Use​
1.1.4 Fault And Troubleshooting​
1.2 Motor​
1.3 Electromagnetic Brake​
1.3.1 Working Principle​
1.3.2 Brake Installment​
1.3.3 Brake Air Gap Adjustment​
1.3.4 Maintenance​
1.3.5 Common Fault And Troubleshooting​
1.3.6 Braking Diagram​
2 Hydraulic System
2.1 Hydraulic System Working Principle​
2.2 Hydraulic Unit​
2.3 Hydraulic System Fault Diagnosis And Correction​
3 Electric System
3.1 Principles Of Electrical System​
3.2 Fault Code Table​
Attachment:Table For Bolt’s Tightening Torque
Relevant Safety Command And Standard (Ce Models)
