118
6,911
Grove Crane YB5518 Parts Manual 2021
Brand: Grove
Model: Grove YB5518 Crane
Serial Number: 321422
Publication Date: 2021
Number of Pages: 463 Pages
Boom
Boom Group - 4 Section
18.5 - 54.5 Long
Boom Assembly - 1st Section
(Complete Assembly)
Boom Assembly - 2nd Section
(Complete Assembly)
Boom Assembly - 3rd Section
(Complete Assembly)
Guide Assembly - Cable
(Complete Assembly)
Grp,Chain Assy,4sect Long Boom
Guide Assembly - Roller
(Complete Assembly)
Pivoting Boom Head Group
Load Sense Indicator Installation
With Rated Capacity Limiter
18 Ton
Transmitter, Anti Two Block
Work Lights Group - Boom 5560b
Searcher Hook Group - 6000lb
5560b/5518
Mounting Group - Boom Extension
5560b/5518
Telecylinder/Crowd Group - 5560b
Cylinder Assembly - Hydraulic
(Complete Assembly)
Winch Assembly,5540f,5560b
Mast And Attaching Parts Group
Swivel Assembly - Hydraulic
(Complete Assembly)
Cylinder Assembly - Lift
Yb5518
(Complete Assembly)
Piston Motor Installation
5560b/5515
Hookblock Tie-Down Installation
(All Industrial Cranes)
Swivel Installation And Connectors -
2 Pass
Carrier/Lowerworks
Frame Assembly
Tank Group - Dual Fuel
5560b
(For Reference Only)
Tank Assembly - Dual Fuel
5540f
Hydraulic Plumbing Group
Cd5560b / Yb5518
Valve Assembly - Solenoid
(Complete Assembly)
Valve Assembly - Dump 2 Way
Valve Assembly - Priority Flow Regulator
(Complete Assembly)
Valve Assembly - Relief
(Complete Assembly)
Valve Assembly - Combination
(Complete Assembly)
Valve Assembly
Steering Mode
(Complete Assembly)
Valve Assembly - Control
1 Section
(Complete Assembly)
3 Section
(Complete Assembly)
Tank Assembly - Hydraulic Oil
Engine Installation
(Dual Fuel)
5560
Engine, Dual Fuel, 4.3l
Pump Assembly - Gear
Exhaust Group - Dual Fuel
(With Spark Arrester)
5540f
Valve And Plumbing Group - Outrigger
(Industrial)
Cylinder, Hydraulic
Cylinder Assembly - Jack
Yb5518
(Complete Assembly)
Valve Assembly - Outrigger
9 Section With 12 Volt - Dt Coils
(Complete Assembly)
Adapter Assembly - Harness
Oscillation Axle Lockout With
Outriggers - Independent
5560
Cylinder Assembly
Axle Lockout
(Complete Assembly)
Decal-Danger Oscillation Lockout Tipover
(English)
Axle Group Front - 5560b
Brake Assembly - Parking
(Complete Assembly)
Drive Line Assembly
(Complete Assembly)
Axle Drive Assembly - Pad Mounted
(Complete Assembly)
Drive Head Group
Differential Assy. Parts Group
Wheel Hubs Group
Hub Swivels And Track Rod Group
Tire And Wheel Group - 385/65r22.5
Tire And Wheel Assembly
(385/65r22.5 Tbls)
Hitch Group - Front Pintle
Pintle Hook Assy.Chain & Cable
Pintle Hook.W/Chain Safety Pin
Pintle Hook.W/Cable Safety Pin
Jaw Assy.
Hitch Group - Pintle Rear
Jaw Assy.
Light Guard Group - 3330/5500
Electrical Steering Circuits Group -
Return To Center Steer
Mirror Group - Dual Rear View
5550
Windshield Washer Kit Group
5560b
Swing Gear Group - 5560
Gearcase, Swing - T Model
Motor Assembly - Hydraulic Swing
(Complete Assembly)
Battery Group - 5560b
Electrical Group - Common Parts
Harness Assembly - Dash 5560b
(Tier 3)
(Complete Assembly)
Axle Assembly - Rear 4 Wheel Drive
5560
Driveline Assembly - Rear
(Complete Assembly)
Axle Assembly - Rear Drive
(Complete Assembly)
Axle Housing Group - Rear Drive
(4 Wheel Drive Units Only)
Differential Carrier Group
Hub And Track Group
Planetary Hub Group
Brake Group - Wheel Brakes
Shaft Group - Drive
Cylinder Group - Steer
Cylinder Assembly - Steering
(Complete Assembly)
Radiator Group With Dual Fuel
5560b
Axle Mounting - 5560b/5540f
L.P.G. Tank And Hoses Group
Kit - L.P.G. Hose 4.3l
Air Cleaner Group - Dual Fuel
5560b
Air Cleaner Assembly - Diesel Engine
(Complete Assembly)
Heater/Defroster Engine Parts Group
(Dual Fuel)
Transmission Group - 4 Wheel Drive
Cd5560b / Yb5518
Transmission Assembly - Complete
(4 Wheel Drive)
Drive Transmission - External Component
Drive Transmission - Pump Drive Shaft
Drive Transmission - Main Shaft &
Components
Drive Transmission - Layshaft &
Components
Drive Transmission - Input Clutch
Drive Transmission - Reverse Clutch
Drive Transmission - Output Assembly
Clutch Assembly - 4wheel Drive
(Complete Assembly)
Drive Transmission-4-Wd Clutch
(Complete Assembly)
Drive Transmission - Pump & Components
Pump, Transmission (Used On 2wd
Transmissions With Transmission S/N
460/80220-2 And After And 4wd
460/80210-21 And After).
Drive Transmission-Piping(4weel Drive)
Drive Transmission - Solenoid Valves
(4wheel Drive)
Valve Assembly
Steering Mode
(Complete Assembly)
Harness, Transmission
Harness Group - Frame 5560b
(Tier 3 Diesel)
Harness Assembly - Main Frame
(Complete Assembly)
Carrier/Frame Cab
Cab Group - Standard 5560b
Valve - Brake Modulating
Valve Assembly - Steering Control Unit
(Complete Assembly)
Decal - Identification Plate
Valve Assembly - Pilot Control
(Complete Assembly)
Harness Assembly - Outrigger,Dash To Cab
(Complete Assembly)
(Tier 3)
(Complete Assembly)
Cab Group - Enclosed
Seat Installation - Adjustable
Seat, Adjustable Cushioned Optional
Fire Extinguisher Assembly
Heater/Defroster Installation
Heater Assembly
(Complete Assembly)
Dome Light Installation
Strobe Light - Enclosed Cab
Cab Component Installation - Dual Fuel
Door Strap Installation
Door Installation With Strobe Light
Window Assembly - Slider Door
(Aluminum Frame)
(Complete Assembly)
Loose Ship Items
Downhaul Weight Assembly - 105lbs
Hookblock Assembly -
20ton Working Load Limit
(1/2" Wire Rope)
Wire Rope, 13mm 310'
Socket & Wedge, 1/2 W.R. With Clip
Decal Instl-Nomen Yb5518
Specs/Schematics
Wiring Diagram, 5560 Dual Fuel
Miscellaneous Decals
Kit - Decals Universal
(English)
Kit - Graphics - Cab - English
Kit - Graphics - C/S - English
Decal - Warning Pinch Point
(English)
Chevron Decal Instl Yb5518
Decal - Load Rating And Range Diagram
Yb5518
(English)
Decal - Danger Backward Stability
(English)
(English)
Decal - Dash Right Console
Decal - Dash Left Console
Panel-Serial No.
Decal - P.C.S.A. Shield
(English)
Decal - Angle Indicator Left
Decal - Angle Indicator Right
Decal-Shift Pattern
(English)
Panel - Yardboss Serial Number
