Grove Crane YB5518 Parts Manual 2013
Brand: Grove
Model: Grove YB5518 Crane
Serial Number: 321891
Publication Date: 2013
Number of Pages: 465 Pages
Boom
Boom Group - 4 Section
18.5 - 54.5 Long
Boom Assembly - 1st Section
(Complete Assembly)
Boom Assembly - 2nd Section
(Complete Assembly)
Boom Assembly - 3rd Section
(Complete Assembly)
Guide Assembly - Cable
(Complete Assembly)
Chain Assembly - Long Boom
Guide Assembly - Roller
(Complete Assembly)
Pivoting Boom Head Group
1114010017 Boom Yb5518/Cd5560b
Load Sense Indicator Installation
18 Ton
Work Lights Group - Boom 5560b
Telecylinder/Crowd Group - 5560b
Cylinder Assembly - Hydraulic
(Complete Assembly)
Anti Two Block Group
Reel Assembly - Cable Anti Two Block
Winch Assembly,5540f,5560b
Mast And Attaching Parts Group
Swivel Assembly - Hydraulic
(Complete Assembly)
Cylinder Assembly - Lift
Yb5518
(Complete Assembly)
Piston Motor Installation
5560b/5515
Hookblock Tie-Down Installation
(All Industrial Cranes)
Swivel Installation And Connectors -
2 Pass
Lowerworks/Carrier
Carrier Frame Installation
Engine Hood Assembly
Diesel Fuel Tank
5560b
(For Reference Only)
Tank Assembly - Fuel
Hydraulic Plumbing Group
Cd5560b / Yb5518
Valve Assembly - Solenoid
(Complete Assembly)
Dump Valve - 2 Way
Valve Assembly - Priority Flow Regulator
(Complete Assembly)
Valve Assembly - Relief
(Complete Assembly)
Valve Assembly - Combination
(Complete Assembly)
Valve Assembly
Steering Mode
(Complete Assembly)
Valve Assembly - Control
1 Section
(Complete Assembly)
3 Section
(Complete Assembly)
Tank Assembly - Hydraulic Oil
Engine Installation - Cummins Qsb3.3
Tier 3 Diesel
Engine, Cummins Qsb3.3
Filter Assy. Fuel/Water Separ.
Element,Filter Fuel/Water Sep
Air Filter Assy.
Pump Assembly - Gear
Exhaust Group - Tier 3 Diesel
Standard Outrigger Valve & Plumbing
Cylinder, Hydraulic
Cylinder Assembly - Jack
Yb5518
(Complete Assembly)
Valve Assembly - Outrigger
5-Section
Adapter Assembly - Harness
Alarm Installation
Axle Group Front - 5560b
Brake Assembly - Parking
(Complete Assembly)
Drive Line Assembly
(Complete Assembly)
Axle Drive Assembly - Pad Mounted
(Complete Assembly)
Drive Head Group
Wheel Hubs Group
Hub Swivels And Track Rod Group
Switch Assembly - Proximity
(Normally Open)
(Rework)
Wheel & Tire Group 385/65r22.5
Tire And Wheel Assembly -
385/65r22.5 Tubeless
Hitch Group - Front Pintle
Hook Assembly - Pintle
Hitch Group - Pintle Rear
Light Guard Installation
Fire Extinguisher Assembly
Air-Condition And Heater Installation
Air Conditioning Unit
(Air And Heat)
5560b
A/C & Heater Assy. 12v. Blower
Mirror Group - Dual Rear View
5550
Windshield Washer Installation
Swing Gear Assembly - 5560
Gearcase, Swing - T Model
Motor Assembly - Hydraulic Swing
(Complete Assembly)
Battery Group - 5560b
Axle Assembly - Rear 2 Wheel Drive
5560
Axle Assembly - Non Drive
Rear Steer
(Complete Assembly)
Axle Housing Group - Non Drive
Rear Steer
(Used On 2-Wheel Drive Units Only)
Planetary Hub Group
(2-Wheel Drive Units)
Hub And Track Group
Brake Group - Wheel Brakes
Cylinder Group - Steer
Cylinder Assembly - Steering
(Complete Assembly)
(Normally Open)
(Rework)
Cooling System - Tier 3 Diesel
Radiator/Charge Air Cooler/
Transmission Oil Cooler Assembly
(Complete Assembly)
Axle Mounting - 5560b/5540f
Air Cleaner Installation
(Tier 3 Diesel)
5560b
Transmission Group - 2 Wheel Drive
Cd5560b / Yb5518
Transmission Assembly - Complete
(2 Wheel Drive)
Drive Transmission - External Component
Drive Transmission - Pump Drive Shaft
Drive Transmission - Main Shaft &
Components
Drive Transmission - Layshaft &
Components
Drive Transmission - Input Clutch
Drive Transmission - Reverse Clutch
Drive Transmission - Output Flange
Drive Transmission-Piping(2wheel Drive)
Drive Transmission - Solenoid Valves
(2wheel Drive)
Harness, Transmission
Harness Group - Frame 5560b
(Tier 3 Diesel)
Harness Assembly - Main Frame
(Complete Assembly)
Harness And Electrial Group - Engine
(Tier 3 Diesel)
Harness Assembly - Engine
(Complete Assembly)
Kit - Cac Tier 3 Diesel
Kit-90amp Alternator Retrofit
Operator Compartment Electric
Without Outrigger Monitor
Carrier/Frame Cab
Standard Cab Installation - 5560b
(Tier 3 Diesel)
Valve - Brake Modulating
Valve Assembly - Steering Control Unit
(Complete Assembly)
Valve Assembly - Pilot Control
(Complete Assembly)
Harness Assembly - Outrigger,Dash To Cab
(Complete Assembly)
Harness Assembly - Dash 5560b
(Tier 3)
(Complete Assembly)
Cab - Enclosed
Seat Installation - Adjustable
Seat, Adjustable Cushioned Optional
Dome Light Installation
Strobe Light - Enclosed Cab
Cab Component Installation -T3
Control Assembly -
Electronic Throttle
Door Strap Installation
Split Door Install W/ Strobe
Cab Split Door Assembly With Cup Holder
Window Assembly - Half Door
Loose Ship Items
Hookblock Assembly -
20ton Working Load Limit
(1/2" Wire Rope)
1114010018 Lshp Yb5518/Cd5560b
Wire Rope, 13mm
Socket Assembly, Wedge
Specs/Schematics
Wiring Diagram, 5560b T3 Dsl
Hydraulic Schematic - 5518
1114010019specs Yb5518/Cd5560b
Miscellaneous Decals
Kit - Decals Universal
(English)
Decal Installation - 7755
Decal Installation - Yb5518
(Nomenclature)
Decal - Load Rating And Range Diagram
Yb5518
(Metric)
(English)
Brand: Grove
Boom
18.5 - 54.5 Long
(Complete Assembly)
(Complete Assembly)
(Complete Assembly)
(Complete Assembly)
(Complete Assembly)
18 Ton
(Complete Assembly)
(Complete Assembly)
Yb5518
(Complete Assembly)
5560b/5515
2 Pass
Lowerworks/Carrier
Diesel Fuel Tank
5560b
Cd5560b / Yb5518
(Complete Assembly)
Dump Valve - 2 Way
(Complete Assembly)
(Complete Assembly)
(Complete Assembly)
Valve Assembly
Steering Mode
(Complete Assembly)
1 Section
(Complete Assembly)
3 Section
(Complete Assembly)
Tier 3 Diesel
Air Filter Assy.
Cylinder, Hydraulic
Yb5518
(Complete Assembly)
5-Section
Alarm Installation
(Complete Assembly)
Drive Line Assembly
(Complete Assembly)
(Complete Assembly)
Drive Head Group
Wheel Hubs Group
(Normally Open)
(Rework)
(Air And Heat)
5560b
5550
(Complete Assembly)
5560
Rear Steer
(Complete Assembly)
Rear Steer
Planetary Hub Group
Hub And Track Group
(Complete Assembly)
(Normally Open)
(Rework)
(Complete Assembly)
(Tier 3 Diesel)
5560b
Cd5560b / Yb5518
(2 Wheel Drive)
Components
Components
(2wheel Drive)
(Tier 3 Diesel)
(Complete Assembly)
(Tier 3 Diesel)
(Complete Assembly)
Carrier/Frame Cab
(Tier 3 Diesel)
(Complete Assembly)
(Complete Assembly)
(Complete Assembly)
(Tier 3)
(Complete Assembly)
Cab - Enclosed
Control Assembly -
Electronic Throttle
Loose Ship Items
(1/2" Wire Rope)
Wire Rope, 13mm
Specs/Schematics
(English)
(Nomenclature)
Yb5518
(Metric)
(English)
