7,392
Grove Crane YB5518 Parts Manual 2011
Brand: Grove
Model: Grove YB5518 Crane
Serial Number: 321637
Publication Date: 2011
Number of Pages: 491 Pages
Boom
Boom Group - 4 Section
18.5 - 54.5 Long
Boom Assembly - 1st Section
(Complete Assembly)
Boom Assembly - 2nd Section
(Complete Assembly)
Boom Assembly - 3rd Section
(Complete Assembly)
Guide Assembly - Cable
(Complete Assembly)
Chain Assembly - Long Boom
Guide Assembly - Roller
(Complete Assembly)
Pivoting Boom Head Group
Load Moment Indicator Installation -
Usa Dual Cylinder
(For Reference Only)
Kit - Lmi Dual Cylinder Usa
Cable Reel Assembly
Jib Group - 15ft
(Ridget, No Offset)
Socket Assembly, Wedge
Work Lights Group - Boom 5560b
Mounting Group - Boom Extension
5560b/5518
Telecylinder/Crowd Group - 5560b
Cylinder Assembly - Hydraulic
(Complete Assembly)
Winch Assembly,5540f,5560b
Mast And Attaching Parts Group
Swivel Assembly - Hydraulic
(Complete Assembly)
Cylinder Assembly - Lift
Yb5518
(Complete Assembly)
Piston Motor Installation
5560b/5515
Hookblock Tie-Down Installation
(All Industrial Cranes)
Swivel Installation And Connectors -
6 Pass
Lowerworks/Carrier
Frame Assembly
Engine Hood Assembly
Diesel Fuel Tank
5560b
Tank Assembly - Fuel
Hydraulic Plumbing Group
Cd5560b / Yb5518
Valve Assembly - Solenoid
(Complete Assembly)
Valve Assembly - Dump
2 Way
(Complete Assembly)
Valve Assembly - Priority Flow Regulator
(Complete Assembly)
Valve Assembly - Relief
(Complete Assembly)
Valve Assembly - Combination
(Complete Assembly)
Valve Assembly
Steering Mode
(Complete Assembly)
Valve Assembly - Control
1 Section
(Complete Assembly)
3 Section
(Complete Assembly)
Tank Assembly - Hydraulic Oil
Engine Installation - Cummins Qsb3.3
Tier 3 Diesel
Engine, Cummins Qsb3.3
Filter Assy. Fuel/Water Separ.
Element,Filter Fuel/Water Sep
Air Filter Assy.
Pump Assembly - Gear
Decal Installation - Yb5518
Kit - Decals Universal
(English)
Decal Installation - 7755
Kit - Decals Universal Carrydeck
(Dutch)
(Spanish)
(French)
(Nomenclature)
Panel-Serial No.-Spanish
Exhaust Group - Tier 3 Diesel
Valve And Plumbing Group - Outrigger
(Standard)
Cylinder, Hydraulic
Cylinder Assembly - Jack
Yb5518
(Complete Assembly)
Valve Assembly - Outrigger
5-Section
Adapter Assembly - Harness
Alarm Installation
Axle Group Front - 5560b
Brake Assembly - Parking
(Complete Assembly)
Drive Line Assembly
(Complete Assembly)
Axle Drive Assembly - Pad Mounted
(Complete Assembly)
Drive Head Group
Wheel Hubs Group
Hub Swivels And Track Rod Group
Wheel & Tire Group 385/65r22.5
Tire And Wheel Assembly -
385/65r22.5 Tubeless
Fire Extinguisher Assembly
Air-Condition And Heater Installation
Air Conditioning Unit
(Air And Heat)
5560b
Windshield Washer Kit Group
5560b
Swing Gear Assembly - 5560
Gearcase, Swing - T Model
Motor Assembly - Hydraulic Swing
(Complete Assembly)
Battery Group - 5560b
Axle Assembly - Rear 2 Wheel Drive
5560
Axle Assembly - Non Drive
Rear Steer
(Complete Assembly)
Axle Housing Group - Non Drive
Rear Steer
(Used On 2-Wheel Drive Units Only)
Planetary Hub Group
(2-Wheel Drive Units)
Hub And Track Group
Brake Group - Wheel Brakes
Cylinder Group - Steer
Cylinder Assembly - Steering
(Complete Assembly)
Cooling System - Tier 3 Diesel
Radiator/Charge Air Cooler/
Transmission Oil Cooler Assembly
(Complete Assembly)
Axle Mounting - 5560b/5540f
Air Cleaner Installation
(Tier 3 Diesel)
5560b
Transmission Group - 2 Wheel Drive
Cd5560b / Yb5518
Transmission Assembly - Complete
(2 Wheel Drive)
Drive Transmission - External Component
Drive Transmission - Pump Drive Shaft
Drive Transmission - Main Shaft &
Components
Drive Transmission - Layshaft &
Components
Drive Transmission - Input Clutch
Drive Transmission - Reverse Clutch
Drive Transmission - Output Flange
Drive Transmission-Piping(2wheel Drive)
Drive Transmission - Solenoid Valves
(2wheel Drive)
Harness Group - Frame 5560b
(Tier 3 Diesel)
Harness Assembly - Main Frame
(Complete Assembly)
Harness And Electrial Group - Engine
(Tier 3 Diesel)
Harness Assembly - Engine
(Complete Assembly)
Kit - Cac Tier 3 Diesel
Kit-90amp Alternator Retrofit
Carrier/Frame Cab
Cab Installation - 5560b Standard
(Tier 3 Diesel)
Valve - Brake Modulating
Valve Assembly - Steering Control Unit
(Complete Assembly)
Valve Assembly - Pilot Control
(Complete Assembly)
Harness Assembly - Outrigger,Dash To Cab
(Complete Assembly)
Harness Assembly - Dash 5560b
(Tier 3)
(Complete Assembly)
Cab - Enclosed
Seat Installation - Adjustable
Seat, Adjustable Cushioned Optional
Dome Light Installation
Strobe Light - Enclosed Cab
Cab Component Installation -T3
Control Assembly -
Electronic Throttle
Door Strap Installation
Split Door Install W/ Strobe
Cab Split Door Assembly With Cup Holder
Window Assembly - Half Door
Loose Ship Items
Downhaul Weight Assembly - 105lbs
Hookblock Assembly -
20ton Working Load Limit
(1/2" Wire Rope)
1114010018 Lshp Yb5518/Cd5560b
Wire Rope, 13mm
Specs/Schematics
Wiring Diagram, 5560b T3 Dsl
Hydraulic Schematic - 5518
1114010019 Spec Yb5518/Cd5560b
(English)
(Nomenclature)
Decal - Load Rating And Range Diagram
Yb5518
(English)
80003613 Yb5518 Decals
