Grove Crane YB5515 Parts Manual 2022
Brand: Grove
Model: Grove YB5515 Crane
Serial Number: 320777
Publication Date: 2022
Number of Pages: 347 Pages
Boom
Mast Group - 5540f
Cylinder Assembly - Lift
(Complete Assembly)
Swivel Assembly - Hydraulic
(7 Circuit)
Swing Gear And Mast Mounting Group
5540f/5515
Gearcase, Swing- B Model
Winch Assembly,5540f,5560b
Swivel Hook Up Group - 5540f
Boom Assy. Grp.3 Section 5540f
Boom Assembly - 1st And 2nd Section
5540f
(Complete Assembly)
Cylinder Assembly Group - Telescope
(3 Section Boom)
5540f
Cylinder Assembly - Telescope Upper
(Complete Assembly)
Cylinder Assembly - Telescope Lower
(Complete Assembly)
Manifold Check Valve Assembly
(Complete Assembly)
Boom Assembly - 3rd Section
5540f
(Complete Assembly)
Anti Two Block Group - 5540f
Reel Assembly - Cable Modified
14 Gauge With 2 Way Connector
Switch Assembly - Anti Two Block Boom
5540f
Grp,5540f,Lmi,Wylie,3 Sec Boom
Indicator,Load Mom,Wylie,3 Sec
Cable Reel Assy. 65 Ft
Rain Cap Assembly - Electric Swivel
Block Assembly - Drop 15 Ton
5540f/5515
Circuit Group - Telescope Boom
5540f/5515
Superstructure
Hydraulic Supply And Return Group
5540f
Steering Circuits Group -
Standard
5540f
Valve Assembly - Solenoid 12 Volt
(Complete Assembly)
Valve Bank Group - 5540f
Valve Assembly - Combination
(Complete Assembly)
Carrier/Lowerworks
Frame Group
5540f
Engine Hood Assembly
Brake Circuit Group - 5540f
(Complete Assembly)
Tire & Wheel Group 385/65r22.5
(For Reference Only)
Tire & Wheel Assembly
Engine Group - Diesel 5540f
Engine Assembly - Cummins B3.3-85
(Tier 2 Diesel)
Pump Assembly - Hydraulic Gear
(Complete Assembly)
Radiator & Cooling System Diesel
5540f
Radiator Assembly - Diesel
Exhaust Group - Diesel 5540f
Air Cleaner Group - Diesel
5540f
Air Cleaner Assembly - Diesel Engine
(Complete Assembly)
Tank Arrangement Group - Diesel Fuel
5540f/5515
Tank Assembly - Fuel
Tank Assembly - Hydraulic Oil
Operator Compartment - Tier 2 Diesel
5540f/5515
Valve - Brake Modulating
Engine Parts Group - Tier 2 Diesel
5540f/5515
Harness Assembly - Carrydeck 3330f
Cummins Engine With Shutdowns
(Complete Assembly)
Outrigger Group - Non Independent
5540f
Valve, Control - Standard O/Rs
(Complete Assembly)
Cylinder Assembly - Outrigger
(Complete Assembly)
Alarm Group - Standard Outriggers
5540f
Cab Group - Enclosed 5540f
Grp,5540f Cab Top & Components
Window Assembly - Slider Door
(Aluminum Frame)
(Complete Assembly)
Heat/Defrost Group - Tier 2 Diesel
5540f
Heater Assembly
(Complete Assembly)
Heater/Defroster Parts - Engine
5540f
Seat Assembly - Standard
Harness Group - Main Frame
5540f
Light, 12vdc, Wk, W/ Leads
Wiring Harness, Dt W/ Leads
Harness Assembly - Main Frame
(Complete Assembly)
Drive Train Group - 2wheel Drive
(Diesel)
5540f
Transmission Group - 2wheel Drive
Transmission Assembly - 2 Wheel Drive
(Complete Assembly)
Drive Transmission, External Components
Drive Transmission, Internal Components
Drive Transmission, Reversal Unit
Drive Transmission, Pump And Pump Drive
Drive Transmission, Gear Change
Transmission Cooling Circuit
Axle Mounting Group - Rear
(2wheel Drive)
5540f
Axle Assembly - Non Drive
Rear Steer
(Complete Assembly)
Axle Housing Group - Non Drive
Rear Steer
(Used On 2-Wheel Drive Units Only)
Planetary Hub Group
(2-Wheel Drive Units)
Hub And Track Group
Brake Group - Wheel Brakes
Cylinder Group - Steer
Cylinder Assembly - Steering
(Complete Assembly)
Axle Mounting Group - Front
(2 Wheel Drive)
5540f
Brake Assembly - Parking
(Complete Assembly)
Shaft Drive - Front 1480 Series
5540f
Axle Drive Assembly - Pad Mounted
(Complete Assembly)
Drive Head Group
Differential Assy. Parts Group
Wheel Hubs Group
Hub Swivels And Track Rod Group
Battery Group - 5540f
Control Valve Group - Hydraulic
(Independent Outriggers)
5540f
Carrier/Frame Cab
Fire Extinguisher Assembly
Kit - Windshield Washer
Cd3330
Grp,5540f Electrical
Harness Assembly - Dash 5560b
3330f/5540f
(Complete Assembly)
Cab Comaprtment Group
5540f
Orbitrol, Steering
Loose Ship Items
Weight, Down Haul, W/O Li System
System)
Miscellaneous Decals
Kit - Decals Universal
(English)
Kit - Graphics - Cab - English
Kit - Graphics - C/S - English
Decal - Warning Pinch Point
(English)
Decal Kit Yb5515
Brand: Grove
Boom
Mast Group - 5540f
(Complete Assembly)
(7 Circuit)
5540f/5515
5540f
(Complete Assembly)
(3 Section Boom)
5540f
(Complete Assembly)
(Complete Assembly)
(Complete Assembly)
5540f
(Complete Assembly)
5540f
5540f/5515
5540f/5515
Superstructure
5540f
Standard
5540f
(Complete Assembly)
(Complete Assembly)
Carrier/Lowerworks
Frame Group
5540f
(Complete Assembly)
(Tier 2 Diesel)
(Complete Assembly)
5540f
5540f
(Complete Assembly)
5540f/5515
5540f/5515
5540f/5515
(Complete Assembly)
5540f
(Complete Assembly)
(Complete Assembly)
5540f
(Aluminum Frame)
(Complete Assembly)
5540f
Heater Assembly
(Complete Assembly)
5540f
5540f
(Complete Assembly)
(Diesel)
5540f
(Complete Assembly)
(2wheel Drive)
5540f
Rear Steer
(Complete Assembly)
Rear Steer
Planetary Hub Group
Hub And Track Group
(Complete Assembly)
(2 Wheel Drive)
5540f
(Complete Assembly)
5540f
(Complete Assembly)
Drive Head Group
Wheel Hubs Group
5540f
Carrier/Frame Cab
Cd3330
3330f/5540f
(Complete Assembly)
5540f
Orbitrol, Steering
Loose Ship Items
System)
(English)
(English)
Decal Kit Yb5515
