118
6,911
Grove Crane YB5515 Parts Manual 2015
Brand: Grove
Model: Grove YB5515 Crane
Serial Number: 321062
Publication Date: 2015
Number of Pages: 391 Pages
Boom
Boom Group - 3 Section Boom
(For Reference Only)
Rope, Wire 1/2" 6x19 240ft
Boom Assembly - 1st And 2nd Section
5540f
(Complete Assembly)
Cylinder Assembly Group - Telescope
(3 Section Boom)
5540f
Cylinder Assembly - Telescope Upper
(Complete Assembly)
Cylinder Assembly - Telescope Lower
(Complete Assembly)
Manifold Check Valve Assembly
(Complete Assembly)
Boom Assembly - 3rd Section
5540f
(Complete Assembly)
Socket & Wedge, 1/2 W.R. With Clip
Anti Two Block Group - 5540f
Reel Assembly - Cable Modified
14 Gauge With 2 Way Connector
Switch Assembly - Anti Two Block Boom
5540f
Lsi Load Indicator Group
5540f / 5515
Kit - Load Sense Indicator
Block Assembly - Drop 15 Ton
5540f/5515
Jib Group - Offsettable 5540f
Switch Assembly W/ Wire Harness
Anti Double-Blocking
(3340b Jib With Stinger)
Mast Group - 5540f
Cylinder Assembly - Lift
(Complete Assembly)
Swivel Assembly - Hydraulic
(7 Circuit)
Winch Assembly,5540f,5560b
Swivel Hook Up Group - 5540f
Hoist Group - Standard 5540f
Superstructure
Hydraulic Supply And Return Group
5540f
Steering Circuit Group - 4 Wheel Drive
(Standard Steering)
5540f
Valve Assembly - Solenoid 12 Volt
(Complete Assembly)
Valve Bank Group - 5540f
Valve Assembly - Combination
(Complete Assembly)
Lowerworks/Carrier
Frame Kit - 5540f (Tier 3 Diesel)
Brake Circuit Group - 5540f
(Complete Assembly)
Tire & Wheel Group 385/65r22.5
Tire & Wheel Assembly
Engine Group - Cummins Qsb3.3-99
(Tier 3 Diesel)
5540f
Engine Assembly - Cummins Qsb3.3-99
(Tier 3 Diesel)
Pump Assembly - Hydraulic Gear
(Complete Assembly)
Cooling System - Tier 3 Diesel
5540f
Radiator/Charge Air Cooler/
Transmission Oil Cooler Assembly
(Complete Assembly)
Exhaust Group - Tier 3 Diesel
5540f
Air Cleaner Assembly - Tier 3 Diesel
5540f
Hydraulic Tank Arrangement Assembly -
Tier 3 Diesel
5540f
Tank Assembly - Fuel
Tank Assembly - Hydraulic Oil
Control Pedal Assembly -
Tier 3 Diesel And Dual Fuel
Valve - Brake Modulating
Control Assembly -
Electronic Throttle
Harness And Electrial Group - Engine
(Tier 3 Diesel)
5540f/5515
Harness Assembly - Engine Cummins Qsb3.3
(Tier 3)
(Complete Assembly)
Charge Air Cooler Kit - Tier 3 Diesel
5540f
Outrigger Group - Non Independent
5540f
Valve, Control - Standard O/Rs
(Complete Assembly)
Cylinder Assembly - Outrigger
(Complete Assembly)
Alarm Group - Standard Outriggers
5540f
Cab Group - Enclosed 5540f
Window Assembly - Slider Door
(Aluminum Frame)
(Complete Assembly)
Fire Extinguisher Assembly
Air Conditioner And Heat Group
(Tier 3 Diesel)
5540f
Air Conditioning Unit
(Air And Heat)
5540f
(Complete Assembly)
A/C & Heater Assy. 12v. Blower
Mirror Assembly - 3330f/5540f
Swing Gear And Mast Mounting Group
15 Ton Industrial
Gearcase, Swing- B Model
Electrical Group - 5540f
Harness Group - Main Frame
(Tier 3 Diesel)
5540f
Harness Assembly - Main Frame
(Complete Assembly)
Drive Train Group - 2wheel
(Tier 3 Diesel)
5540f
Transmission Group - 2wheel Drive
Transmission Assembly - 2 Wheel Drive
(Complete Assembly)
Drive Transmission, External Components
Drive Transmission, Internal Components
Drive Transmission, Reversal Unit
Drive Transmission, Pump And Pump Drive
Drive Transmission, Gear Change
Transmission Cooling Circuit Group - T3
Axle Mounting Group - Rear
(2wheel Drive)
5540f
Axle Assembly - Non Drive
Rear Steer
(Complete Assembly)
Axle Housing Group - Non Drive
Rear Steer
(Used On 2-Wheel Drive Units Only)
Planetary Hub Group
(2-Wheel Drive Units)
Hub And Track Group
Brake Group - Wheel Brakes
Cylinder Group - Steer
Cylinder Assembly - Steering
(Complete Assembly)
Axle Mounting Group - Front
(2 Wheel Drive)
5540f
Brake Assembly - Parking
(Complete Assembly)
Shaft Drive - Front 1480 Series
5540f
Axle Drive Assembly - Pad Mounted
(Complete Assembly)
Drive Head Group
Wheel Hubs Group
Hub Swivels And Track Rod Group
Battery Group-T3 Diesel 5540f
Guard Installation - Fan (Tier 3)
With Air Conditioner
(4 Wheel Drive)
5540f
(Complete Assembly)
5540f
(Complete Assembly)
Drive Head Group
Wheel Hubs Group
(2wheel Drive)
5540f
Rear Steer
(Complete Assembly)
Rear Steer
Planetary Hub Group
Hub And Track Group
(Complete Assembly)
Carrier/Frame Cab
Cab Comaprtment Group
5540f
Orbitrol, Steering
Electrical Group - Operator Compartment
(Tier 3 Diesel)
Harness Assembly - Dash 5560b
(Complete Assembly)
Loose Ship Items
Weight, Down Haul, With Li System
System)
Decal - Load Indicator Transmitter
(English)
Specs/Schematics
Wiring Diagram, 5540f T3 Dsl
Miscellaneous Decals
Kit - Decals Universal
(English)
Kit - Graphics - Cab - English
Kit - Graphics - C/S - English
Yb5515 Nomenclature Kit
Decal - Load Rating And Range Diagram
3-Section Boom
Yb5515
(English)
(English)
Decal - P.C.S.A. Shield
(English)
Decal - Angle Indicator Left
(English)
Decal - Angle Indicator Right
(English)
