118
6,911
Grove Crane YB5515-2 Parts Manual 2018
Brand: Grove
Model: Grove YB5515-2 Crane
Serial Number: 322628
Publication Date: 2018
Number of Pages: 599 Pages
Boom
Instl, Ind15-2 41'' Boom
Cyl Hyd, Tele 110/90 X 3575
Instl, Wylie Boom
Harness W/ Resistor Assembly
Resistor Assembly
Ind 9/16 Wire Rope
Boom Work Light Installation
Boom Light - Rework
Roller Guide Installation
Guide Assembly - Roller
(Complete Assembly)
5515 Mast Harness Installation
Harness - Boom Yb5515
Hookblock Tie-Down Installation
(All Industrial Cranes)
Superstructure
Mast Instl
Hoist Installation
Hoist Assy. W/ Dl2 Sensor
Gear Set, Output
Kit, Seal Hoist Group
Input Gear Set
Roller Assembly - Cable Packer
Wedge, Cable
Cordset - Dri/Lli
Hydraulic Swivel Installation - 7 Pass
Swivel - Hydraulic, 7-Port, O-Ring Ports
Electric Swivel Install - Ce
Slip Ring - 13 Circuit W/Pot
Turntable Plumbing
Lift Cylinder And Pins Installation
Lift Cylinder
Pin Installation - Boom Pivot
Counterweight Installation
Wylie Mast 4500 Install
Wylie I4500 Mast Kit
Superstructure Cab
Electrical System Installation - Cab
Harness Assembly - Cab
Carrier/Lowerworks
Assy, Frame And Deck
Instl, Outrigger
Cylinder, Hydraulic
Jack Cyl, O/R
Lower Hydraulic Buildup
Main Outrigger Valve Manifold
(5-Section)
Valve Assembly - Outrigger Control
5 Section
(Complete Assembly)
Valve,Control,4 Section
Valve Assy. Inlet Section
Steering And Brakes Manifold
Valve Assembly
Steering Mode
(Complete Assembly)
Dump Valve Assembly
Manifold,Selectable Psi Red''G
Engine Install - Tier 3 4wd
Engine Assembly - 4wd
Engine, Cummins Qsb3.3
Fuel Filter Assy. W/Wif Sensor
Element,Filter Fuel/Water Sep
Air Filter Assy.
Transmission Group - 4 Wheel Drive
(For Reference Only)
Transmission Assembly - Complete
(4 Wheel Drive)
Drive Transmission - External Component
Drive Transmission - Pump Drive Shaft
Drive Transmission - Main Shaft &
Components
Drive Transmission - Layshaft &
Components
Drive Transmission - Input Clutch
Drive Transmission - Reverse Clutch
Drive Transmission - Output Assembly
Clutch Assembly - 4wheel Drive
(Complete Assembly)
Drive Transmission-4-Wd Clutch
(Complete Assembly)
Drive Transmission - Pump & Components
Drive Transmission-Piping(4weel Drive)
Drive Transmission - Solenoid Valves
(4wheel Drive)
Valve Assembly
Steering Mode
(Complete Assembly)
Pump Assembly - Piston
60cc Counter Clockwise Rotation
Harness, Transmission
Tier 3 Engine -
Harness - Tier_3_Engine_
Block Heater Installation - Qsb3.3 120v
Front Axle Installation
Brake Assembly - Parking
(Complete Assembly)
Drive Line Assembly
(Complete Assembly)
Axle Drive Assembly - Pad Mounted
(Complete Assembly)
Drive Head Group
Differential Assy. Parts Group
Wheel Hubs Group
Hub Swivels And Track Rod Group
Fire Extinguisher Instl-2.5lb
Instl Rear Axle 4wd
Axle Assembly - Rear Drive
(Complete Assembly)
Axle Housing Group - Rear Drive
(4 Wheel Drive Units Only)
Differential Carrier Group
Hub And Track Group
Planetary Hub Group
Brake Group - Wheel Brakes
Shaft Group - Drive
Cylinder Group - Steer
Cylinder Assembly - Steering
(Complete Assembly)
Driveline Assembly - Rear
(Complete Assembly)
Tire/Rim Assembly Installation
Tire And Rim Assembly
Instl Convience Package
Pintle Hook Assy.Chain & Cable
Pintle Hook.W/Chain Safety Pin
Pintle Hook.W/Cable Safety Pin
Jaw Assy.
Electrical Group
Battery Installation - Yb5520
Relay Panel Assembly
Wiring Harness - Relay Panel
Cooling System Group - 5520 T3
Radiator/Charge Air Cooler/
Transmission Oil Cooler Assembly
(Complete Assembly)
Air Cleaner - T3 Diesel
Carrier Harness
Wiring Harness-Carrier 5520/15
Diode (Modified)
Cac Kit - T3 Diesel
T3 Fan Guard W/ A/C
Swing Gear Installation
Gearcase, Swing - T Model
Motor Assembly - Hydraulic Swing
(Complete Assembly)
Proximity Switch Installation -
Outrigger Monitoring System
Ind 5520
Proximity Switch Assembly - 30mm
T3 Engine Hood Instl
Engine Hood Assembly
Light Installation
Kit-90amp Alternator Retrofit
Alarm Installation
Tool Tray Installation
Fuel/Reservoir Tank Install
Diesel Fuel Tank (40 Gallon)
Reservoir Assembly - Hydraulic
Carrier Rework - Drum Rotation Indicator
Ha-Hdri Supp Carrier Ind15-2
Instl Mirror
Carrier/Frame Cab
Instl, Std Cab Shell
Instl, Cab Parts
Control Assembly -
Electronic Throttle
Valve - Brake Modulating
Assy, Dash
Wiring Harness - Dash
Flasher - Electronic Rework
Single Axis Joystick Assembly
Steering Wheel Assembly With Shifter
Seat Assembly - Adjustable Suspension
(Complete Assembly)
Ha-Hdri Supp Cab Ind15-2
Sngle Axis Joystck W/ Thumper
Handle Assy. W/Solenoid
Cab - Enclosed
Windshield Wiper Assembly
Door Installation - (Split)
Cab Split Door Assembly With Cup Holder
Window Assembly - Half Door
Light Installation - Strobe
A/C And Heat Installation
Air Conditioning Kit W/Heater - Tier 3
Heater & A/C Blower Assy. 12v.
Defroster Switch Installation
Instl, Yb Load Chart Binder
Swing Lock Switch Installation
2/4 Wheel Drive Switch Install
Instl, Cab Hyd
Door Strap Installation
Instl, Windshield Washer
Washer Bottle Harness
Hoist Speed Switch Install
Split Door Stop Installation
Instl, I4500 (Cab)
I4500 Display
Loose Ship Items
Hookblock, 20t Capacity
Socket Installation (41'' Boom)
Socket Assembly - 5/8" Wedge
Miscellaneous Decals
Decal Install - Ind15ton-2
Decal Install - Ind15ton-2 Cab
Decal Installation - Ind 15ton-2
Carrier/Superstructure
Decal Installation - Yb5515-2
(Nomenclature)
Cca-Yb5515-2 3 Section Met
Panel-Serial No.
Decal-Shift Pattern
Panel - Yardboss Serial Number
Decal-Relay Fuse Box 2
Decal-Relay Fuse Box 1
Decal-Relay Identification
