7,392
Grove Crane YB5515-2 Parts Manual 2014
Brand: Grove
Model: Grove YB5515-2 Crane
Serial Number: 322160
Publication Date: 2014
Number of Pages: 561 Pages
Boom
5515-2 41ft Boom
Arctic Tele Cylinder Assembly
Anti Two Block Switch
W/Resistor Assembly
Ds-85 Installation
Kit, Ds85
Kit, Ds85 Lmi/Reel Assy.
Ds85 Lngth Reel Lwg154/35
Guide Assembly - Roller
(Complete Assembly)
W/Resistor Assembly
80040003 Boom Yb5515/Cd5515
5515 Mast Harness Installation
Harness - Boom Yb5515
Pin Installation - Boom Pivot
Hookblock Tie-Down Installation
(All Industrial Cranes)
Superstructure
Mast Installation
Hoist Installation
Hoist - Yb5515-2
Hydraulic Swivel Installation - 7 Pass
Swivel - Hydraulic, 7-Port, O-Ring Ports
Electric Swivel Installation - 13 Pass
Swivel Assembly - Hydraulic
(13 Circuit)
(Complete Assembly)
Turntable Plumbing
Lift Cylinder And Pins Installation
Lift Cylinder
Counterweight Installation
Superstructure Cab
Defroster Switch Installation
Heater Switch Installation
Cover Installation
Lowerworks/Carrier
Frame And Deck Assembly
Fuel/Reservoir Tank Install
Diesel Fuel Tank (40 Gallon)
Reservoir Assembly - Hydraulic
Outriggers Installation
Cylinder, Hydraulic
Cylinder Assembly - Jack
Yb5518
(Complete Assembly)
Lower Hydraulic Buildup
Main Outrigger Valve Manifold
(5-Section)
Valve Assembly - Outrigger Control
5 Section
(Complete Assembly)
Valve,Control,4 Section
Steering And Brakes Manifold
Valve Assembly
Steering Mode
(Complete Assembly)
Dump Valve Assembly
Manifold,Selectable Psi Red'g
Engine Installation -
Tier 4, 2wheel Drive
Engine Assembly T4 - 2wd
Transmission Group - 2 Wheel Drive
(For Reference Only)
Transmission Assembly - Complete
(2 Wheel Drive)
Drive Transmission - External Component
Drive Transmission - Pump Drive Shaft
Drive Transmission - Main Shaft &
Components
Drive Transmission - Layshaft &
Components
Drive Transmission - Input Clutch
Drive Transmission - Reverse Clutch
Drive Transmission - Output Flange
Drive Transmission-Piping(2wheel Drive)
Drive Transmission - Solenoid Valves
(2wheel Drive)
Pump Assembly - Piston
60cc Counter Clockwise Rotation
Harness, Transmission
Electrical System Installation -
Engine Tier 4
Harness - 20 Ton T4 Engine
Element,Filter Fuel/Water Sep
Crankcase Breather Assy. Group
Block Heater Installation - Qsb3.3 120v
Exhaust Install T4 - Ind20ton
Front Axle Installation
Brake Assembly - Parking
(Complete Assembly)
Drive Line Assembly
(Complete Assembly)
Axle Drive Assembly - Pad Mounted
(Complete Assembly)
Drive Head Group
Wheel Hubs Group
Hub Swivels And Track Rod Group
Fire Extinguisher Instl-2.5lb
Rear Axle Installation - 2wd
Axle Assembly - Non Drive
Rear Steer
(Complete Assembly)
Axle Housing Group - Non Drive
Rear Steer
(Used On 2-Wheel Drive Units Only)
Planetary Hub Group
(2-Wheel Drive Units)
Hub And Track Group
Brake Group - Wheel Brakes
Cylinder Group - Steer
Cylinder Assembly - Steering
(Complete Assembly)
Tire/Rim Assembly Installation
Tire And Rim Assembly
Ind20ton Convience Package
Hitch Group - Front Pintle
Hook Assembly - Pintle
Electrical Group
Battery Installation - Yb5520
Relay Panel Assembly
Wiring Harness - Relay Panel
Radiator Installation - Ind 5515/5520 T4
Radiator Assembly - Ind5515/5520 T4
Radiator And Cac Cooler
Fan Shroud Assembly
Surge Tank Assembly
Air Intake Install T4 - Ind20
Air Cleaner
Carrier Harness
Wiring Harness-Carrier 5520/15
Diode (Modified)
Fan Guard Installation W/O A/C
Swing Gear Installation
Gearcase, Swing - T Model
Motor Assembly - Hydraulic Swing
(Complete Assembly)
Proximity Switch Installation -
Outrigger Monitoring System
Ind 5520
Proximity Switch Assembly - 30mm
Engine Hood Install - T4
Engine Hood Assembly
Light Installation
Alarm Installation
Transmission Oil Cooler Installation
Oil Cooler Assembly - 15" 12v
Carrier/Frame Cab
Cab Shell Installation
Yb5520/15 Cab Harness Install
Cab Harness
Cab Assembly & Installation
Control Assembly -
Electronic Throttle
Valve - Brake Modulating
Dash Assembly
Wiring Harness - Dash
Flasher - Electronic Rework
Single Axis Joystick Assembly
Steering Wheel Assembly With Shifter
Seat Assembly - Adjustable Suspension
(Complete Assembly)
Cab - Enclosed
Windshield Wiper Assembly
Door Installation - (Split)
Cab Split Door Assembly With Cup Holder
Window Assembly - Half Door
Heat Or/Defroster Install - T4
Heater Assembly
(Complete Assembly)
Load Chart Binder Installation -
Yard Boss
Swing Lock Switch Installation - 10.5ton
Cab Hydraulic Buildup
Door Strap Installation
Windshield Washer Installation
Lmi Override Switch Install
Hoist Speed Switch Install
Split Door Stop Installation
Loose Ship Items
Ind 9/16 Wire Rope
20t Hookblock-9/16rope,350#4p
Socket Installation (41' Boom)
Socket Assembly - 5/8" Wedge
80040011 Ship Yb5515/Cd5540f
Specs/Schematics
Elec Schematic 5520 T3 & T4
Hydraulic Schematic 5515-2
5520 Pressure Settings
80040004 Spec Yb5515/Cd5540f
Miscellaneous Decals
Decal Install - Ind15ton-2
Decal Install - Ind15ton-2 Cab
Decal Installation - Ind 15ton-2
Carrier/Superstructure
Decal Installation - Yb5515-2
(Nomenclature)
Cca-Yb5515-2 41' 3 Sect Boom
Decal-Fuse Box 2 Id
