118
6,911
Grove Crane YB4415XT Parts Manual 2018
Brand: Grove
Model: Grove YB4415XT Crane
Serial Number: 320290
Publication Date: 2018
Number of Pages: 545 Pages
Boom
Boom Assy 40 Ft
Cylinder Assembly - 5"
Tele
Shaft Installation -
Boom Pivot
Boom
Socket, Open Wedge
(5/8'' Rope)
(Complete Assembly)
Indicator Installation -
Boom Angle
Pointer Assembly
Hook Block Assembly - 15 Ton
Boom Installation - Main
Boom Kit Installation
Sensor Assembly
Box, Junction
Clip Installation - Wire Rope
Superstructure
Turntable Installation
Cylinder Installation - Lift
Cylinder Assembly - 5 1/2"
Lift
(Complete Assembly)
Lift
(Complete Assembly)
Hoist Installation
Hoist Assembly- Model Hp12
(Complete Assembly)
Counterweight Installation
Limiter Installation -
Rated Capacity
Binder Installation
Follower Kit Installation
Swivel Installation
Electric And Hydraulic
Elec & Hyd Swivel Assy
Swivel Assy-7 Port Hyd
Slip Ring Assembly - 10
Conductor
Hyd Comp Instl W/4 Wheel & S
Valve Assembly - Hoist Control
Valve Assembly - Control
(Lift/Tele/Swing)
Switch Assembly - Pressure
(Normally Closed)
(Complete Assembly)
Unit Assembly -
Steering Control
Cylinder Assembly - Master
Valve Assembly - Selector
O/R Selector Valve
Valve Assembly - Solenoid
Valve Assembly - Park Brake
(Complete Assembly)
Solenoid Valve - 4 Wheel Dr
Supply, Pressure And Return
Outrigger
Hydraulic Lines Installation Group -
4 Wheel Drive
Swing
Hoist
Telescope
Lift Hyd Lines Instl - Rcl
2 Whl/4 Whl Hyd Lines Instl
Superstructure Cab
Electrical System Installation
Harness Assy, Outrigger Cab To Board
Worklight Installation
Fuse & Relay Panel Instl
Panel Assy-Fuse & Relays
Harness Assembly - Fuse Panel
(Complete Assembly)
Cover Installation -
(Enclosed Cab)
Fan Assembly - 12 Volt Cab
(Complete Assembly)
Door Assembly
Handle Assembly - Paddle Lock
Window Assembly - Right Front
Heater Installation - Cummins
Heater Assembly - 12 Volt
Throttle Installation
Accelerator Pedal Assy
Accelerator Pedal Design "B"
Accelerator Pedal Design "A"
Tachometer Installation
Seat Installation
(Deluxe)
Seat Assembly - Deluxe
Light Installation - Flasher
Light Assembly - Strobe
Q00, Mini-Binder Instl
Carrier/Lowerworks
Frame Ass'y (W/Rotek Bearing)
Drive Assembly - Swing
Gear Assembly - Worm
Speed Reducer
Motor Assembly - Orbit
Deck Post Installation
Cover Installation - Deck
Mirror Installation
Mirror Head And Loop
Assembly - Stainless Steel
Hookblock Tie-Down
Installation
Outrigger Installation
Cylinder Assembly - 3"
Outrigger Extension
Tire And Wheel Installation
Tire And Wheel Assembly
Hook Installation - Pintle
Hook Assembly - Pintle
Kit, Hardware
Engine Installation
Engine Assembly
Transmission Assembly
(Complete Assembly)
Converter Housing Group
Transmission Case And
Plate Group
Torque Converter Group
Gear Group
Pump Drive Group
Charging Pump Group
Reverse Idler Group
Forward And Reverse
Shaft Group
Third Shaft Group
First And Second Shaft Group
Outer Shaft Group
Disc Brake Group
Caliper Assembly Group
Electric Control Group
Drive Plate Group
Pump Assembly - P350
(Complete Assembly)
Actuator Assembly -
Hydraulic Spring Brake
(Complete Assembly)
Electrical System Installation -
Engine,Diesel
(Not Available As Assembly)
Harness Assembly - Diesel
Receptacle Assembly
Heater Installation - Block
Start Installation - Ether
(Cummins)
Radiator Installation
Radiator Assembly
Radiator And Oil Cooler
Assembly
Exhaust And Air Cleaner
Installation
Cleaner Assembly - Air
(Complete Assembly)
Hood Installation - Engine
Drive Line Installation -
4 X 4
Slip Assembly - Driveline
Axle Installation - Front
Drive/Steer
Axle Assembly - Front
Drive/Steer
Axle Assembly - Drive/Steer
Drive Steer Assembly
Hub And Components, Steer Axle
Differential Assembly
Crown Wheel And Pinion
Brake Parts, Steering Axle
Cylinder Assembly - 2 1/2" Steer
(Complete Assembly)
Switch Assembly
Axle Installation
Axle Assembly - Rear Drive
Steer
(Complete Assembly)
Hyd/Fuel Tanks Instl-Diesel
Filter Assembly - Return
Pressure Check
Service Brakes
Electrical System Instl
Harness Assy-Carrier
Box Installation -
Tool And Battery
Counter Weight Instl
Pinion And Bearing Guard Instl
Carrier/Frame Cab
Acoustic Instl
Loose Ship Items
Ball Assembly - Overhaul
(125 Lbs)
(Complete Assembly)
Miscellaneous Decals
Decal Installation - Yb4415
(Standard)
(Standard)
(Standard)
Decal Installation
