118
6,911
Grove Crane YB4415XT Parts Manual 2017
Brand: Grove
Model: Grove YB4415XT Crane
Serial Number: 320100
Publication Date: 2017
Number of Pages: 555 Pages
Boom
Boom Assembly -
52' Long
Cylinder Assembly -
5" Telescope
Shaft Installation -
Boom Pivot
Boom
Socket, Open Wedge
(5/8'' Rope)
(Complete Assembly)
Extension Installation - Boom
Indicator Installation -
Boom Angle
Pointer Assembly
Hook Block Assembly - 15 Ton
Boom Installation - Main
Boom Kit Installation
Sensor Assembly
Box, Junction
Kit Installation - Fixed
Single Axis Boom Extension
Box, Junction
Clip Installation - Wire Rope
Superstructure
Turntable Installation
Cylinder Installation - Lift
Cylinder Assembly - Lift
Hoist Installation
Hoist Assembly- Model Hp12
(Complete Assembly)
Counterweight Installation
Limiter Installation -
Rated Capacity
Binder Installation
Swivel Installation -
Electric And Hydraulic
Elec & Hyd Swivel Assy
Swivel Assy-7 Port Hyd
Slip Ring Assembly - 10
Conductor
Supply, Pressure And Return
Independent Outrigger
Steer
Swing
Hoist
Telescope
Lift
2 Wheel/4 Wheel Drive
Superstructure Cab
Electrical System Installation
Harness Assy, Outrigger Cab To Board
Worklight Installation
System Installation -
Electric
Panel Installation - Fuse And
Relay
Panel Assembly
Harness Assembly - Fuse Panel
Cover Installation -
(Enclosed Cab)
Fan Assembly - 12 Volt Cab
(Complete Assembly)
Door Assembly
Handle Assembly - Paddle Lock
Window Assembly - Right Front
Cab Installation - Lower Area
Panel Assembly -
Instruments And Lights
(With Rated Capacity Limiter Panel)
(Complete Assembly)
Harness Assembly - Console
(Complete Assembly)
Console Assembly -
(Complete Assembly)
Heater Installation - Cummins
Heater Assembly - 12 Volt
Throttle Installation
Accelerator Pedal Assy
Accelerator Pedal Design "B"
Accelerator Pedal Design "A"
Tachometer Installation
Acoustical Installation
Seat Installation
(Deluxe)
Seat Assembly - Deluxe
Light Installation - Flasher
Light Assembly - Strobe
Q00, Mini-Binder Instl
Carrier/Lowerworks
Frame Assembly
With Rotek Bearing
Frame Section
Stud Installation - Weld
(Not Available As Assembly)
Drive Assembly - Swing
Gear Assembly - Worm
Speed Reducer
Motor Assembly - Orbit
Deck Post Installation
Cover Installation - Deck
Mirror Installation
Mirror Head And Loop
Assembly - Stainless Steel
Hookblock Tie-Down
Installation
Outrigger Installation
Cylinder Assembly-3" Outrigger Extension
(Complete Assembly)
Tire And Wheel Installation
Tire And Wheel Assembly
Hook Installation - Pintle
Hook Assembly - Pintle
Kit, Hardware
Engine Installation-Cummins
Engine Assembly
Transmission Assembly
Converter Housing Group
Case And Plate Group
Torque Converter Group
Pump Drive Group
Charge Pump Group
Reverse Idler Group
Forward Reverse Shaft Group
Third And Output Shaft Group
First And Second Shaft Group
Output Shaft Group
Disc Brake Group
Brake Assembly
Control Valve Group
Drive Plate Group
Pump Assembly - P350
(Complete Assembly)
Actuator Assembly -
Hydraulic Spring Brake
(Complete Assembly)
Electrical
Receptacle Assembly
Heater Installation - Block
Start Installation - Ether
(Cummins)
Radiator Installation
Radiator Assembly
Radiator And Oil Cooler
Assembly
Exhaust And Air Cleaner
Installation
Cleaner Assembly - Air
(Complete Assembly)
Hood Installation - Engine
Drive Line Installation -
4 X 4
Slip Assembly - Driveline
Axle Installation - Front
Drive/Steer
Axle Assembly - Front
Drive/Steer
Axle Assembly - Drive/Steer
Drive Steer Assembly
Hub And Components, Steer Axle
Differential Assembly
Crown Wheel And Pinion
Brake Parts, Steering Axle
Cylinder Assembly - 2 1/2" Steer
(Complete Assembly)
Switch Assembly
Axle Installation
Axle Assembly - Rear Drive
Steer
(Complete Assembly)
Tanks
Installation -
Diesel
Filter Assembly - Return
Components Installation -
Hydraulic
Valve Assembly - Hoist Control
Valve Assembly - Control
(Lift/Tele/Swing)
Switch Assembly - Pressure
(Normally Closed)
(Complete Assembly)
Unit Assembly -
Steering Control
Cylinder Assembly - Master
Valve Assembly - Selector
(Steer)
(4-Section Outrigger)
Valve Assembly - Solenoid
Valve Assembly - Park Brake
(Complete Assembly)
Solenoid Valve - 4 Wheel Dr
Pressure Check
Service Brakes
Box Installation -
Tool And Battery
Loose Ship Items
Ball Assembly - Overhaul
(125 Lbs)
(Complete Assembly)
Specs/Schematics
Hydraulic Schematic
Electrical Schematic -
Diesel
Miscellaneous Decals
Decal Installation
Decal Installation
