Grove Crane YB4415 Parts Manual 2020
Brand: Grove
Model: Grove YB4415 Crane
Serial Number: 320134
Publication Date: 2020
Number of Pages: 501 Pages
Boom
Socket, Open Wedge
(5/8'' Rope)
(Complete Assembly)
Boom Assembly
Cylinder Assembly - 5"
Tele
Shaft Installation -
Boom Pivot
Boom
Extension Installation - Boom
Indicator Installation -
Boom Angle
Pointer Assembly
Hook Block Assembly - 15 Ton
Boom Installation - Main
Boom Kit Installation
Sensor Assembly
Box, Junction
Kit Installation - Fixed
Single Axis Boom Extension
Box, Junction
Clip Installation - Wire Rope
Superstructure
Swivel Installation -
Electric And Hydraulic
Elec & Hyd Swivel Assy
Swivel Assy-7 Port Hyd
Slip Ring Assembly - 10
Conductor
Supply, Pressure And Return
Outrigger
Steer
Swing
Hoist
Telescope
Lift
Turntable Installation
Cylinder Installation - Lift
Cylinder Assembly - 5 1/2"
Lift
(Complete Assembly)
Lift
(Complete Assembly)
Hoist Installation
Hoist Assembly- Model Hp12
(Complete Assembly)
Counterweight Installation
Limiter Installation -
Rated Capacity
Follower Kit Installation
Binder Installation
Superstructure Cab
Worklight Installation
Harness Assy, Outrigger Cab To Board
System Installation -
Electric
Panel Installation -
Fuse And Relay
Panel Assembly -
Fuse And Relay
Harness Assembly - Fuse Panel
Cover Installation -
(Enclosed Cab)
Fan Assembly - 12 Volt Cab
(Complete Assembly)
Door Assembly
Handle Assembly - Paddle Lock
Window Assembly - Right Front
Cab Installation - Lower Area
Panel Assembly -
Instruments And Lights
(With Rated Capacity Limiter Panel)
(Complete Assembly)
Harness Assembly - Console
(Complete Assembly)
Console Assembly -
(Complete Assembly)
Throttle Installation
Pedal Assembly - Suspended
Electronic
Acoustical Installation
Seat Installation
Light Installation - Flasher
Light Assembly - Strobe
Q00, Mini-Binder Instl
Electrical System Installation
Carrier/Lowerworks
Frame Assembly
With Rotek Bearing
Frame Section
Stud Installation - Weld
(Not Available As Assembly)
Drive Assembly - Swing
Gear Assembly - Worm
Speed Reducer
Motor Assembly - Orbit
Cover Installation - Deck
Mirror Installation
Mirror Head And Loop
Assembly - Stainless Steel
Hookblock Tie-Down
Installation
Outrigger Installation
Cylinder Assembly-3" Outrigger Extension
(Complete Assembly)
Tire And Wheel Installation
Tire And Wheel Assembly
Hook Installation - Pintle
Hook Assembly - Pintle
Engine Installation - Gm 2wd
Engine Assembly
Transmission Assembly
(Complete Assembly)
(Complete Assembly)
Converter Housing Group
(Complete Assembly)
Transmission Case And
Plate Group
(Complete Assembly)
Torque Converter Group
(Complete Assembly)
Gear Group
Gear Group
(Complete Assembly)
Pump Drive Group
Pump Drive Group
(Complete Assembly)
Charging Pump Group
Charging Pump Drive Group
(Complete Assembly)
Reverse Idler Group
Reverse Idler Group
(Complete Assembly)
Forward And Reverse
Shaft Group
(Complete Assembly)
Third Shaft Group
Third Shaft Group
(Complete Assembly)
First And Second Shaft Group
(Complete Assembly)
Output Shaft Group
(Complete Assembly)
Disc Brake Group
Disc Brake Group
(Complete Assembly)
Caliper Assembly Group
(Complete Assembly)
Electric Control Group
(Complete Assembly)
Drive Plate Group
Drive Plate Group
Pump Assembly - P350
(Complete Assembly)
Receptacle Assembly
Harness Assy, Dual Fuel Engine
Actuator Assembly -
Hydraulic Spring Brake
(Complete Assembly)
Heater Installation -
Engine Block
Radiator Installation
Radiator Assembly
Radiator And Oil Cooler
Assembly
Exhaust And Air Cleaner
Installation
Cleaner Assembly - Air
(Complete Assembly)
Hood Installation - Engine
Drive Line Installation -
4 X 4
Slip Assembly - Driveline
Axle Installation - Front
Drive/Steer
Axle Assembly - Front
Drive/Steer
Axle Assembly - Drive/Steer
Drive Steer Assembly
Hub And Components, Steer Axle
Differential Assembly
Crown Wheel And Pinion
Brake Parts, Steering Axle
Cylinder Assembly - 2 1/2" Steer
(Complete Assembly)
Switch Assembly
Axle Installation - Rear
Axle Assembly - Rear Steer
(Complete Assembly)
Lh Hub/Swivel Assy
Rh Hub/Swivel Assy
Hydraulic/Fuel
Tank Installation - Dual Fuel
Filter Assembly - Return
Components Installation -
Hydraulic
Valve Assembly - Hoist Control
Valve Assembly - Control
(Lift/Tele/Swing)
Switch Assembly - Pressure
(Normally Closed)
(Complete Assembly)
Unit Assembly -
Steering Control
Cylinder Assembly - Master
Valve Assembly - Selector
(Steer)
(Outrigger)
Valve Assembly - Solenoid
Valve Assembly - Park Brake
(Complete Assembly)
Pressure Check
Service Brakes
Box Installation -
Tool And Battery
Miscellaneous Decals
Decal Installation - Yb4415
(Standard)
Decal Installation
Brand: Grove
Boom
Socket, Open Wedge
(5/8'' Rope)
(Complete Assembly)
Boom Assembly
Tele
Boom Pivot
Boom
Boom Angle
Pointer Assembly
Sensor Assembly
Box, Junction
Box, Junction
Superstructure
Conductor
Outrigger
Steer
Swing
Hoist
Telescope
Lift
Lift
(Complete Assembly)
Lift
(Complete Assembly)
Hoist Installation
(Complete Assembly)
Rated Capacity
Binder Installation
Superstructure Cab
Electric
Fuse And Relay
Panel Assembly -
Fuse And Relay
(Enclosed Cab)
(Complete Assembly)
Door Assembly
Panel Assembly -
(Complete Assembly)
(Complete Assembly)
Console Assembly -
(Complete Assembly)
Electronic
Seat Installation
Carrier/Lowerworks
Frame Assembly
With Rotek Bearing
Frame Section
Speed Reducer
Mirror Installation
Hookblock Tie-Down
Installation
(Complete Assembly)
Engine Assembly
(Complete Assembly)
(Complete Assembly)
(Complete Assembly)
Plate Group
(Complete Assembly)
(Complete Assembly)
Gear Group
Gear Group
(Complete Assembly)
Pump Drive Group
Pump Drive Group
(Complete Assembly)
Charging Pump Group
(Complete Assembly)
Reverse Idler Group
Reverse Idler Group
(Complete Assembly)
Forward And Reverse
Shaft Group
(Complete Assembly)
Third Shaft Group
Third Shaft Group
(Complete Assembly)
(Complete Assembly)
Output Shaft Group
(Complete Assembly)
Disc Brake Group
Disc Brake Group
(Complete Assembly)
(Complete Assembly)
(Complete Assembly)
Drive Plate Group
Drive Plate Group
(Complete Assembly)
Receptacle Assembly
Actuator Assembly -
(Complete Assembly)
Engine Block
Radiator Assembly
Assembly
Installation
(Complete Assembly)
4 X 4
Drive/Steer
Drive/Steer
(Complete Assembly)
Switch Assembly
(Complete Assembly)
Lh Hub/Swivel Assy
Rh Hub/Swivel Assy
Hydraulic/Fuel
Hydraulic
(Lift/Tele/Swing)
(Normally Closed)
(Complete Assembly)
Unit Assembly -
Steering Control
(Steer)
(Outrigger)
(Complete Assembly)
Pressure Check
Service Brakes
Box Installation -
Tool And Battery
(Standard)
Decal Installation
