Grove Crane YB4411 Parts Manual 2020
Brand: Grove
Model: Grove YB4411 Crane
Serial Number: 321418
Publication Date: 2020
Number of Pages: 415 Pages
Boom
Boom Group - 3 Section
Ce
(For Reference Only)
Boom Assembly - 1st Section
Boom Assembly - 2nd Section
3340
Boom Assembly - 3rd Section
3340
Crowd Assembly - 3340
Cylinder Assembly - Hydraulic
(Complete Assembly)
Chain Assembly - 3340
Boom Head Assembly - Pivoting
(Complete Assembly)
Socket & Wedge With Clip 5/8"
Socket Assembly - 5/8" Wedge
(Complete Assembly)
Hook Block Assembly - 15 Ton
9/16" Rope
(Complete Assembly)
Load Moment Indicator Installation -
Ce Single Cylinder
Kit - Lmi Single Cylinder Ce
Cable Reel Assy, W/ 75'cable
Load Momentt Indicator - Common Parts
Rain Cap Assembly - Electric Swivel
Guide Assembly - Cable
(Complete Assembly)
Hoist Group With Drum Rotation Indicator
Swivel Assembly - 6 Pass Electric
(Modified)
Hoist Assembly -
With Drum Rotation Indicator And Packer
(Complete Assembly)
Output Gear Set
Roller Assembly - Cable Packer
Mast & Attaching Parts Group
Swivel Assembly - Hydraulic
7 Port
(Complete Assembly)
(Complete Assembly)
Plumbing And Roller Group - Hoist
3340b
Hookblock Tie-Down Installation
(All Industrial Cranes)
3rd Wrap Cutout Group
Solenoid Valve - 4 Wheel Dr
Bearing/Swing Drive Group
Motor Assembly - Hydraulic Swing
(Complete Assembly)
Gearbox Assembly -
Swing
(Complete Assembly)
Superstructure
Valve Group - Independent Outriggers
(4 Section)
Valve Assembly - Dump 2 Way
Valve Assembly - Outrigger
4-Section
Adapter Assembly - Harness
Valve Assembly - Combination
(Complete Assembly)
Control Valve Assembly - Main
(Complete Assembly)
Valve Assembly - Solenoid
(Complete Assembly)
Hydraulic Circuit Group -
(2nd Valve Without Swing Lock)
4-Section
Swivel Hook Up Group - 3340b
Circuit Group - Steering Hook Up
3340
Valve Assembly
Steering Mode
(Complete Assembly)
Pressure And Return Group
3340
Carrier/Lowerworks
Frame Kit Group - Tier 3 Diesel
Kit - Decals Universal Carrydeck
(Dutch)
Outrigger Beam Assembly
3340b
(Complete Assembly)
(Complete Assembly)
Engine Group - Cummins Qsb 3.3-99
(Tier 3 Diesel)
3340b
Engine Assembly - Cummins Qsb 3.3-99
(Tier 3 Diesel)
Fuel Filter Assy. W/Wif Sensor
Element,Filter Fuel/Water Sep
Air Filter Assy.
Pump Assembly - Hydraulic
(Multiple Gear)
(Complete Assembly)
Harness, Transmission
Decal Installation - Chevron
3340b
Exhaust Group - Tier 3 Diesel
(Without Spark Arrest)
Transmission Group
Transmission, 2wd Powershift
Trans. Ext. Components Group
Trans. Input Clutch Group
Trans. Mainshaft Group
Trans. Layshaft Clutch Group
Trans. Forward Clutch Group
Clutch Assy, Reverse
Trans. Ext. Tube Assy. Group
Solenoid Valves - Transmission
Axle Installation -
3340
Shaft - Drive
Axle Assembly - Drive/Steer
(Complete Assembly)
Axle Housing Group
Axle,Steer Housing & Cyl Group
Axle Ring & Pinion Assy. Group
Axle Differential Assy. Group
Axle Drive Shaft Assy. Group
Axle Wheel Hub Assy. Group
Axle Brake Assy. Group
Axle Assembly - Front
Brake Parts
3330 - 3340
Rear Axle Assembly
Cylinder Assembly - Steering
Hydraulic
(Complete Assembly)
Self Align 4wheel Steer Mounting Group
Shaft - Drive
Wheel And Tire Group
Wheel And Tire Assembly - Front
Wheel And Tire Assembly - Rear Alpha
Brake Hook Up Group - 3340
Caliper, Parking Brake
Cab Group - Ce 3340b/Yb4411
Seat Assembly Ce With Microswitch
(Complete Assembly)
Valve - Brake Modulating
Orbitrol - Steer
Decal - Identification Plate
Enclosed Cab Installation
3340b
Window Assembly - Slider Door
(Aluminum Frame)
(Complete Assembly)
Heater/Defroster Group
Heater Assembly
(Complete Assembly)
Heater Valve Sub Group - 3340b
Door Assembly - Slide Window
(Complete Assembly)
(Aluminum Frame)
(Complete Assembly)
Heater And Defroster Group
Heater Assembly
(Complete Assembly)
Electrical Group - Tier 3 Diesel
3340b
Battery Group - 3340b
Operator Compartment - Pedal
(Tier 3 Diesel Option)
3340b
Control Assembly -
Electronic Throttle
Operator Compartment Group - Electric
(Tier 3 Diesel)
Valve Assembly - Pilot Control
(Complete Assembly)
Harness Assembly - Dash 5560b
3340b
(Complete Assembly)
Harness Group - Main Frame
(Tier 3 Diesel)
3340b
Harness Assembly - Main Frame
Carrydeck 3340b
(Complete Assembly)
Fuel Tank Group With Fuel Filter Lines
(Tier 3 Diesel)
Tank, Diesel 4409/4409-2/4411
Cooling System - Tier 3 Diesel (3339)
Radiator/Charge Air Cooler/
Transmission Oil Cooler Assembly
(Complete Assembly)
Air Cleaner Group - Tier 3 Diesel
3340b
Sound Suppression Package -
3340b
Kit - Sound Insulation 3340b
Suction And Return Lines
3340
Charge Air Cool Group
(Tier 3 Diesel Engine)
Electrical Group - Engine Harness
(Tier 3 Diesel)
3340/4411
Harness Assembly - Engine
(Complete Assembly)
Fan Guard - Installation
Without Air Conditioner
Yb4409
Carrier/Frame Cab
Kit, Dome Light
Kit - Windshield Washer
Cd3330
Door Strap Installation
Miscellaneous Decals
Yb4411 Nomenclature Kit
Decal - Dash Right Console
Decal - P.C.S.A. Shield
(English)
Decal - Angle Indicator Left
(English)
Decal - Angle Indicator Right
(English)
Decal - Dash Left Console
Brand: Grove
Boom
Ce
3340
3340
(Complete Assembly)
(Complete Assembly)
(Complete Assembly)
9/16" Rope
(Complete Assembly)
Ce Single Cylinder
(Complete Assembly)
(Modified)
Hoist Assembly -
(Complete Assembly)
Output Gear Set
7 Port
(Complete Assembly)
(Complete Assembly)
3340b
(Complete Assembly)
Gearbox Assembly -
Swing
(Complete Assembly)
Superstructure
(4 Section)
4-Section
(Complete Assembly)
(Complete Assembly)
(Complete Assembly)
4-Section
3340
Valve Assembly
Steering Mode
(Complete Assembly)
3340
Carrier/Lowerworks
(Dutch)
3340b
(Complete Assembly)
(Complete Assembly)
(Tier 3 Diesel)
3340b
(Tier 3 Diesel)
Air Filter Assy.
(Multiple Gear)
(Complete Assembly)
3340b
Transmission Group
Axle Installation -
3340
Shaft - Drive
(Complete Assembly)
Axle Housing Group
Brake Parts
3330 - 3340
Rear Axle Assembly
Hydraulic
(Complete Assembly)
Shaft - Drive
(Complete Assembly)
Orbitrol - Steer
3340b
(Aluminum Frame)
(Complete Assembly)
Heater Assembly
(Complete Assembly)
(Complete Assembly)
(Aluminum Frame)
(Complete Assembly)
Heater Assembly
(Complete Assembly)
3340b
3340b
Control Assembly -
Electronic Throttle
(Tier 3 Diesel)
(Complete Assembly)
3340b
(Complete Assembly)
(Tier 3 Diesel)
3340b
Carrydeck 3340b
(Complete Assembly)
(Tier 3 Diesel)
(Complete Assembly)
3340b
3340b
3340
(Tier 3 Diesel)
3340/4411
(Complete Assembly)
Yb4409
Carrier/Frame Cab
Kit, Dome Light
Cd3330
(English)
(English)
(English)
