Grove Crane YB4411 Parts Manual 2012
Brand: Grove
Model: Grove YB4411 Crane
Serial Number: 321870
Publication Date: 2012
Number of Pages: 449 Pages
Boom
3 Section Boom
Boom Assembly - Section 1 Of 3
Boom Assembly - Section 2 Of 3
Boom Assembly - Section 3 Of 3
Crowd Assembly-3 Section Boom
Cylinder Assembly - Hydraulic
(Complete Assembly)
Chain Assembly - 3340
Pivioting Boom Head Assembly
Roller Guide Installation
Guide Assembly - Roller
(Complete Assembly)
1114010029 Boom Yb4411/Cd3340b
Jib Group 12ft - W/6ft Stinger
Sheave Assembly - Deflector
(Complete Assembly)
Load Moment Indicator Installation -
International Single Cylinder
(For Reference Only)
Kit - Lmi Single Cylinder International
Cable Reel Assembly
Yb4411 Wylie I3500 Comn Prts
Boom Installation
Winch, Main, Type T -W/O Drum Rotation
Indicator
Roller Assembly - Cable Packer
Mast & Attaching Parts Group
Swivel Assembly - Hydraulic
7 Port
(Complete Assembly)
(Complete Assembly)
Plumbing And Roller Group - Hoist
3340b
Hookblock Tie-Down Installation
(All Industrial Cranes)
Electric Swivel Installation
And Connectors
Superstructure
Valve Group - Independent Outriggers
(4 Section)
Dump Valve - 2 Way
Valve Assembly - Outrigger
4-Section
Adapter Assembly - Harness
Valve Assembly - Combination
(Complete Assembly)
Control Valve Assembly - Main
(Complete Assembly)
Valve Assembly - Solenoid
(Complete Assembly)
Hydraulic Circuit Group -
(2nd Valve Without Swing Lock)
4-Section
Swivel Hook Up Group - 3340b
Pressure And Return Group
3340
Lowerworks/Carrier
Frame Kit Group - Tier 3 Diesel
Engine Hood Assembly
Outrigger Installation
(Complete Assembly)
(Complete Assembly)
Alarm Installation - Outrigger
Power Unit Installation
Engine Assembly - Cummins Qsb 3.3-99
(Tier 3 Diesel)
Filter Assy. Fuel/Water Separ.
Element,Filter Fuel/Water Sep
Air Filter Assy.
Pump Assembly - 45cc
Pump Assembly - Hydraulic
(Multiple Gear)
(Complete Assembly)
Exhaust Group - Tier 3 Diesel
(Without Spark Arrest)
Transmission Group
Transmission, 2wd Powershift
Trans. Ext. Components Group
Trans. Input Clutch Group
Trans. Mainshaft Group
Trans. Layshaft Clutch Group
Trans. Forward Clutch Group
Trans. Ext. Tube Assy. Group
Solenoid Valves - Transmission
Front Axle Installation -
Return To Center Steering
Axle Assembly - Drive/Steer
(Complete Assembly)
Axle Housing Group
Axle,Steer Housing & Cyl Group
Axle Ring & Pinion Assy. Group
Axle Differential Assy. Group
Axle Drive Shaft Assy. Group
Axle Wheel Hub Assy. Group
Axle Brake Assy. Group
Shaft - Drive
Valve Assembly
Steering Mode
(Complete Assembly)
Rear Axle Installation
Cylinder Assembly - Steering
Hydraulic
(Complete Assembly)
Wheel And Tire Group - Bias
(Front)
(Rear)
Hitch Mounting Group - Rear
3330d
Hook Assembly - Pintle
Forged 5 Ton
Hitch Mounting Group - Front
3330d
Forged 5 Ton
Light Guards Installation
Brake Hook Up Group - 3340
Caliper, Parking Brake
Fire Extinguisher Assembly
Windshield Washer Installation
Mirror Group - 3340
Electrical Group - Tier 3 Diesel
3340b
Battery Group - 3340b
Operator Compartment Installation -
Electric - Tier 3 Diesel
Valve Assembly - Pilot Control
(Complete Assembly)
Harness Assembly - Dash 5560b
3340b
(Complete Assembly)
Harness Assembly - Outrigger,Dash To Cab
(Complete Assembly)
Harness Group - Main Frame
(Tier 3 Diesel)
3340b
Harness Assembly - Main Frame
Carrydeck 3340b
(Complete Assembly)
Fuel Tank Group With Fuel Filter Lines
(Tier 3 Diesel)
Cooling System - Tier 3 Diesel (3339)
Radiator/Charge Air Cooler/
Transmission Oil Cooler Assembly
(Complete Assembly)
Air Cleaner Group - Tier 3 Diesel
3340b
Suction And Return Lines
3340
Hose Installation -
Charge Air Cool Group
(Tier 3 Diesel Engine)
Electrical Installation - Engine Tier 3
3340/4411
Harness Assembly - Engine
(Complete Assembly)
Bearing/Swing Drive Install
Motor Assembly - Hydraulic Swing
(Complete Assembly)
Gearbox Assembly -
Swing
(Complete Assembly)
Fan Guard - Installation
Without Air Conditioner
Yb4409
Heater/Defroster Engine Parts Group - T3
Axle Mounting Installation
Door Installation - Split Without Strobe
Cab Split Door Assembly With Cup Holder
Window Assembly - Half Door
Kit-90amp Alternator Retrofit
Operator Compartment Electric
Without Outrigger Monitor
Carrier/Frame Cab
Cab Installation - Standard
Valve - Brake Modulating
Orbitrol - Steer
Cab - Enclosed
Seat Installation - Adjustable
Seat, Adjustable Cushioned Optional
Heater/Defroster Installation
Heater Assembly
(Complete Assembly)
Dome Light Installation
Cab Component Installation -T3
Control Assembly -
Electronic Throttle
Door Strap Installation
Cab Shell & Top Glass - Non Ce
Loose Ship Items
Downhaul Weight Assembly - 105lbs
Hookblock Assembly -
10.5ton Working Load Limit
(9/16" Wire Rope)
(Complete Assembly)
1114010030 Ls Yb4411/Cd3340b
Socket Assembly - 5/8" Wedge
(Complete Assembly)
Rope, Wire 9/16"
Specs/Schematics
Electrical Schematic, 3340b
Hydraulic Schematic,3340/4411
1114010031 Spec Yb4411/Cd3340b
Miscellaneous Decals
Kit - Decals Universal
(English)
Decal Installation - 7755
Decal Installation - Yb4411
(Nomenclature)
Decal - Grove 5" Gray
Decal - Capacity Chart - Yb4411
Brand: Grove
Boom
3 Section Boom
(Complete Assembly)
(Complete Assembly)
(Complete Assembly)
Cable Reel Assembly
Boom Installation
Indicator
7 Port
(Complete Assembly)
(Complete Assembly)
3340b
And Connectors
Superstructure
(4 Section)
Dump Valve - 2 Way
4-Section
(Complete Assembly)
(Complete Assembly)
(Complete Assembly)
4-Section
3340
Lowerworks/Carrier
(Complete Assembly)
(Complete Assembly)
(Tier 3 Diesel)
Air Filter Assy.
(Multiple Gear)
(Complete Assembly)
Transmission Group
(Complete Assembly)
Axle Housing Group
Shaft - Drive
Valve Assembly
Steering Mode
(Complete Assembly)
Hydraulic
(Complete Assembly)
(Front)
(Rear)
3330d
Forged 5 Ton
3330d
Forged 5 Ton
Mirror Group - 3340
3340b
(Complete Assembly)
3340b
(Complete Assembly)
(Complete Assembly)
(Tier 3 Diesel)
3340b
Carrydeck 3340b
(Complete Assembly)
(Tier 3 Diesel)
(Complete Assembly)
3340b
3340
Hose Installation -
3340/4411
(Complete Assembly)
(Complete Assembly)
Gearbox Assembly -
Swing
(Complete Assembly)
Yb4409
Carrier/Frame Cab
Orbitrol - Steer
Cab - Enclosed
Heater Assembly
(Complete Assembly)
Control Assembly -
Electronic Throttle
Loose Ship Items
(9/16" Wire Rope)
(Complete Assembly)
(Complete Assembly)
Rope, Wire 9/16"
Specs/Schematics
(English)
(Nomenclature)
