118
7,392
Grove Crane YB4409XL Parts Manual 2020
Brand: Grove
Model: Grove YB4409XL Crane
Serial Number: 320939
Publication Date: 2020
Number of Pages: 311 Pages
Boom
Hoist Group - Boom 3330f/Fl
Hoist Drive Assembly - 3330f/Fl
(Complete Assembly)
Mast And Hydraulic Swivel Group -
Long Boom
3330f/Fl
Swivel Assembly - Hydraulic
7 Port
(Complete Assembly)
Boom Group - 3 Section (Long)
Cylinder Assembly Group - Telescope
(Long Boom)
(Complete Assembly)
Socket & Wedge, 1/2 W.R. With Clip
Boom Extension Group - 6ft Jib
3330f
Block Assembly - Drop 2 Part 1/2"
3330f/Fl
Load Sense Indicator Group
3330f/Fl
(For Reference Only)
Kit - Load Sense Indicator
Anti Two Block Line Parts
3330 / 4409
Reel Assembly - Cable Modified
14 Gauge With 2 Way Connector
Superstructure
Steering Circuits Group -
Return To Center Steer
3330f/Fl
Valve Assembly
Steering Mode
(Complete Assembly)
Steering Alignment Group - Switches
(4 Wheel Steering)
Carrier/Lowerworks
Frame Kit Assembly
Valve Bank Installation
Valve Assembly - Solenoid
(Complete Assembly)
Outrigger Assembly - Standard
Valve Assembly - Control
Outriggers - Standard
(Complete Assembly)
Cylinder Assembly - Outrigger
Hydraulic
(Complete Assembly)
Alarm Group - Outrigger Down
(Standard)
3330f
Engine Group - Cummins Tier 2
Pump Assembly - Hydraulic
(Multiple Gear)
(Complete Assembly)
Engine, Cummins 3.3 L Turbo Units With
S/N 190104-04 & After
Cleaner Assembly - Air
(Complete Assembly)
Harness Assembly - Carrydeck 3330f
Cummins Engine With Shutdowns
(Complete Assembly)
Radiator Installation - Diesel
3330/3340/3339
Radiator/Oil Cooler Assembly
(Complete Assembly)
Air Cleaner Installation - Diesel
3330/3340/3339
Filter Assembly - Air Cleaner
(Complete Assembly)
(Complete Assembly)
Exhaust Assembly - Diesel (Cummins)
3330f/3339
Operator Compartment Parts - Optional
(Diesel Engine Tier 2)
Valve - Brake Modulating
Harness Group - Mainframe (Diesel)
3330f/3339
Harness Assembly - Main Frame
3330f
(Complete Assembly)
Harness Assembly - Dash 5560b
3330f/5540f
(Complete Assembly)
Transmission Group, Ref. Info.
Transmission, 2wheel Drive Complete
Drive Transmission - Gear Change
Drive Transmission - Internal Components
Drive Transmission - Reversal Unit
Axle Installation -
3340
Shaft - Drive
Axle Assembly - Drive/Steer
(Complete Assembly)
Axle Housing Group
Axle,Steer Housing & Cyl Group
Axle Ring & Pinion Assy. Group
Axle Differential Assy. Group
Axle Drive Shaft Assy. Group
Axle Wheel Hub Assy. Group
Axle Brake Assy. Group
Axle Assembly - Front
Brake Parts
3330 - 3340
Rear Axle Assembly
Cylinder Assembly - Steering
Hydraulic
(Complete Assembly)
Grp,3340,Whl&Tire
Grp, Tire&Wheel, Frt, Carraro
Assy, Tire & Whl(Ref 80001632)
Grp, Tire&Wheel, Rear, Carraro
Assy, Tire&Wheel(Ref 80001634)
Hydraulics Group
Hydraulic Tank - Suction And Return
Line Parts Assembly - Brake
Caliper, Parking Brake
Axle Steering Assembly - Front
Valve Assembly - Solenoid 12 Volt
(Complete Assembly)
Pressure And Return Line Assembly
Pump And Return Lines Assembly
3330/3339
Valve Assembly - Independent Outrigger
(Complete Assembly)
Valve Assembly - Anti Void/Relief
(Complete Assembly)
Standard Cab Group
3330f / Fl - 3339
Fire Extinguisher Assembly
Orbitrol, Steering
Seat Assembly - Standard
Swing Gear & Boom Mounting Assembly
Cylinder Assembly - Hydraulic
(Boom Hoist)
(Complete Assembly)
Motor Assembly - Hydraulic Swing
(Complete Assembly)
Gearbox Assembly -
Swing
(Complete Assembly)
Electrical Group
Swivel / Control Valve Plumbing
3330 / 4409
Battery And Cables Group
3330f/Fl-3339
Shaft, Drive
Guard Installation - Fan (Tier 3)
Without Air Conditioner
Decal Kit Yb4409xl
Loose Ship Items
Weight, Down Haul, With Li System
System)
Decal - Load Indicator Transmitter
(English)
Miscellaneous Decals
Kit - Decals Universal
(English)
Kit - Graphics - Cab - English
Kit - Graphics - C/S - English
Decal - Warning Pinch Point
(English)
