118
6,911
Grove Crane YB4409XL Parts Manual 2015
Brand: Grove
Model: Grove YB4409XL Crane
Serial Number: 322088
Publication Date: 2015
Number of Pages: 478 Pages
Boom
Boom Group - 3 Section, Long - 3330fl
Cylinder Assembly Group - Telescope
(Long Boom)
(Complete Assembly)
Swivel Installation And Connectors -
2 Pass
Counter Weight Kit - 4 Section
Yb4409xl
Hookblock Assembly -
8.5ton Working Load Limit
(1/2" Wire Rope)
(Complete Assembly)
Load Sense Indicator Installation
8.5 Ton
Anti Two Block Installation
Anti Two Block Group
Reel Assembly - Cable Anti Two Block
Hoist Group - Boom 3330f/Fl
Hoist Drive Assembly - 3330f/Fl
(Complete Assembly)
Hookblock Tie-Down Installation
(All Industrial Cranes)
Superstructure
Mast Installation
Hydraulic Swivel - 7 Circuit
Cylinder Assembly - Hydraulic
(Boom Hoist)
(Complete Assembly)
Lowerworks/Carrier
Frame Covers Installation
Axles Installation
Axle - Front
Axle Assembly - Drive/Steer
(Complete Assembly)
Axle Housing Group
Axle,Steer Housing & Cyl Group
Axle Ring & Pinion Assy. Group
Axle Differential Assy. Group
Axle Drive Shaft Assy. Group
Axle Wheel Hub Assy. Group
Axle Brake Assy. Group
Shaft, Drive
Rear Axle Assembly-Steer Only
Cylinder Assembly - Steering
Hydraulic
(Complete Assembly)
Engine Hood Installation
Door Assembly
Diesel Tank Installation
Brake Circuit Plumbing
Caliper, Parking Brake
Steer Hose Installation
Valve Assembly
Steering Mode
(Complete Assembly)
Swing Gear And Bearing Install
Gearbox Assembly -
Swing
(Complete Assembly)
Motor Assembly - Hydraulic Swing
(Complete Assembly)
Outrigger Installation - Standard
Valve Assembly - Control
Outriggers - Standard
(Complete Assembly)
Cylinder Assembly - Outrigger
Hydraulic
(Complete Assembly)
Valve Assembly - Standard Outriggers
Valve Assembly - Combination
(Complete Assembly)
Relief Valve (2500psi)
Alarm Installation - Outrigger Standard
Harness - Outrigger Alarm Switches
Hydraulic Reservoir Install
Hydraulic Reservoir Assembly
Hydraulic Return Plumbing Installation
Carrier Valve Plumbing
Solenoid Valve
Swivel-Control Valve Plumbing
Electrical System Installation -
Battery & Relay Box
Electrical Box Assembly
Relay Panel Rework Assembly - Ind 8.5ton
Wiring Harness
Ind 8.5ton
Harness Assembly - Carrier
Ind 8.5ton
Harness Assembly - Maf Qsb45
Engine Installation - Cummins Qsb3.3
(Tier 4)
Engine Assembly - Cummins Qsb3.3
(Tier 4)
Pump Assembly - 45cc
Transmission Group, Ref. Info.
Transmission, 2wheel Drive Complete
Drive Transmission - Gear Change
Drive Transmission - Internal Components
Drive Transmission - Reversal Unit
(Tier 4)
Harness Assembly - Engine
Ecm Cover Installation
Element,Filter Fuel/Water Sep
Crankcase Breather Assy. Group
Pump Assembly - Hydraulic
(Multiple Gear)
(Complete Assembly)
Radiator Installation - Ind 8.5ton T4
Radiator Assembly - Ind8.5t-4
Radiator And Cac Cooler
Fan Shroud Assembly
Surge Tank Assembly
Transmission Oil Cooler Installation
Transmission Oil Cooler Assembly
Oil Cooler - Transmission
Toc Valve & Hose Installation
Transmission Oil Cooler Control Valve
Exhaust Installation T4-Yb4409
Air Intake Intake Installation Tier 4
Yb4409
Air Cleaner
Block Heater Installation - Qsb3.3 120v
Fan Guard Installation W/O A/C
Tire & Wheel Install - Alpha
Wheel And Tire Group - Bias
(Front)
Hitch/Pintel Group - Front/Rear
3330f
Hook Assembly - Pintle
Forged 5 Ton
Guard Installation - Light
Cab Component Installation-T3
Control Assembly -
Electronic Throttle
Valve - Brake Modulating
Seat Installation-Adjustable
Seat, Adjustable Cushioned Optional
Dome Light Installation
Heater/Defroster Installation
Heater Assembly
(Complete Assembly)
Return To Center Steering
Module & Wiring Installation
Fire Extinguisher Assembly
Outrigger Monitoring System Installation
Proximity Switch
Proximity Switch Assembly - 30mm
Mirror Installation
Pump & Return Lines Installation
Return To Center Installation
Blocking Valve Rework
Valve, Blocking
Carrier/Frame Cab
Cab Shell & Top Glass Installation
Cab Components Installation
Orbitrol, Steering
Turn Signal Switch Rework
Dash Installation
Dash Assembly
Wiper & Side Glass Install
Windshield Wiper Motor Rework Install
Windshield Wiper Motor Harness
Door Strap Installation
Windshield Washer Installation
Door Installation - Split
Cab Split Door Assembly With Cup Holder
Window Assembly - Half Door
Door (Split) Stop Installation
Cab Rework
Loose Ship Items
Rope, Wire 13mm, 8x25 110'
Socket Assembly - 1/2" W.R.
Specs/Schematics
Electric Schematic
Hydraulic Schematic
Pressure Setting Procedure
Miscellaneous Decals
Decal Installation - 8.5 Ton
Decal Installation - Cab
Decal-Shift Pattern
Decal Install - Carrier/ Super
Panel - Yardboss Serial Number
Decal Installation - Nomenclature
Yb4409xl
Decal-Capacity Chart-Yb4409xl 3 Section
Decal-Patent-Crane
