118
6,911
Grove Crane YB4409XL Parts Manual 2011
Brand: Grove
Model: Grove YB4409XL Crane
Serial Number: 321022
Publication Date: 2011
Number of Pages: 427 Pages
Boom
Boom Group - 3 Section (Long)
Cylinder Assembly Group - Telescope
(Long Boom)
(Complete Assembly)
Rope, Wire 13mm, 8x25
Socket & Wedge, 1/2 W.R. With Clip
Downhaul Weight Assembly - 105lb
(Complete Assembly)
1114010035 Boom Yb4409/Cd3330f
Boom Extension Group - 6ft Jib
3330f
Hook Block Assembly - 15 Ton
1/2" Rope
(Complete Assembly)
Lmi Installation
(For Reference Only)
Kit - Lmi Single Cylinder Usa
Grp,3330d,Boom,3sect,Long
Load Moment Indicator Installation -
Yb4409
Rain Cap Assembly - Electric Swivel
Valve Assembly - Solenoid
(Complete Assembly)
Hoist Group - Boom 3330f/Fl
Hoist Drive Assembly - 3330f/Fl
(Complete Assembly)
Swing Gear & Boom Mounting Assembly
Cylinder Assembly - Hydraulic
(Boom Hoist)
(Complete Assembly)
Motor Assembly - Hydraulic Swing
(Complete Assembly)
Gearbox Assembly -
Swing
(Complete Assembly)
Mast And Hydraulic Swivel Group -
Long Boom
3330f/Fl
Swivel Assembly - Hydraulic
7 Port
(Complete Assembly)
Hookblock Tie-Down Installation
(All Industrial Cranes)
Superstructure
Steering Circuits Group -
Return To Center Steer
3330f/Fl
Valve Assembly
Steering Mode
(Complete Assembly)
Steering Alignment Group - Switches
(4 Wheel Steering)
Lowerworks/Carrier
Frame Group
(Tier 3 Diesel Engine)
Valve Bank Installation
(Complete Assembly)
Outrigger Assembly - Independent
3330f / Fl - 3339
Valve Assembly - Control
(Independent Outriggers)
Cylinder Assembly - Outrigger
Hydraulic
(Complete Assembly)
Alarm Installation -
3330f
Engine Group - Cummins 3.3l
3339
Engine Assembly - Cummins Qsb 3.3-99
(Tier 3 Diesel)
Filter Assy. Fuel/Water Separ.
Element,Filter Fuel/Water Sep
Air Filter Assy.
Pump Assembly - Hydraulic
(Multiple Gear)
(Complete Assembly)
Exhaust Group - Tier 3 Diesel
Transmission Group, Ref. Info.
Transmission, 2wheel Drive Complete
Drive Transmission - Gear Change
Drive Transmission - Internal Component
Drive Transmission - Reversal Unit
Axle Installation -
3340
Shaft - Drive
Axle Assembly - Drive/Steer
(Complete Assembly)
Axle Housing Group
Axle,Steer Housing & Cyl Group
Axle Ring & Pinion Assy. Group
Axle Differential Assy. Group
Axle Drive Shaft Assy. Group
Axle Wheel Hub Assy. Group
Axle Brake Assy. Group
Axle Assembly - Front
Brake Parts
3330 - 3340
Rear Axle Assembly
Cylinder Assembly - Steering
Hydraulic
(Complete Assembly)
Wheel And Tire Group
Wheel And Tire Assembly - Front
Wheel And Tire Assembly - Rear Alpha
Hitch/Pintel Group - Front/Rear
3330f
Hook Assembly - Pintle
Forged 5 Ton
3330f
Forged 5 Ton
Light Guard Group - 3330/5500
Hydraulics Group
Hydraulic Tank - Suction And Return
Line Parts Assembly - Brake
Caliper, Parking Brake
Axle Steering Assembly - Front
Valve Assembly - Solenoid 12 Volt
(Complete Assembly)
Pressure And Return Line Assembly
Pump And Return Lines Assembly
3330/3339
Valve Assembly - Independent Outrigger
(Complete Assembly)
Valve Assembly - Anti Void/Relief
(Complete Assembly)
Standard Cab Group
3330f / Fl - 3339
Fire Extinguisher Assembly
Orbitrol, Steering
Enclosed Cab Installation
Window Assembly - Slider Door
(Aluminum Frame)
(Complete Assembly)
Air Conditioner And Heating Group
Air Conditioning Unit
(Air And Heat)
3330/3339
(Complete Assembly)
Light Assembly - Strobe
(Enclosed Cab)
Kit - Windshield Washer
Cd3330
Mirror Assembly - 3330f/5540f
Electrical Group - Tier 3 Diesel
Swivel / Control Valve Plumbing
3330 / 4409
Battery Components
3330f / Fl - 3339
Shaft, Drive
Electrical Group - Operator Compartment
(Tier 3 Diesel And Crab Steer)
Harness Assembly - Dash 5560b
(Complete Assembly)
Tank Group - Diesel
Tank, Diesel 4409/4409-2/4411 N
Cooling System - Tier 3 Diesel (3339)
Radiator/Charge Air Cooler/
Transmission Oil Cooler Assembly
(Complete Assembly)
Air Cleaner Installation
(Tier 3 Diesel)
3339
Operator Compartment - Standard Cab
(Tier 3 Diesel Engine Option)
3339
Control Assembly -
Electronic Throttle
Valve - Brake Modulating
Harness Group - Frame (Tier 3 Diesel)
3330
Harness Assembly - Main Frame
(Complete Assembly)
Charge Air Cool Group
Electrical Group - Engine Harness
(Tier 3 Diesel)
(All 4409’s)
Harness Assembly - Engine Cummins Qsb3.3
(Tier 3)
(Complete Assembly)
Loose Ship Items
1114010036 Lshp Yb4409/Cd3330f
Specs/Schematics
Wire Diagram,3330-3339 T3 Dsl
Hydraulic Schematic,3330/4409
1114010037 Spec Yb4409/Cd3330f
Kit - Decals Universal
(English)
Decal Installation - 7755
Yb4409xl Nomenclature Kit
Decal - Load Rating And Range Diagram
3-Section Boom
Yb4409xl
(English)
80003619 Decal Yb4409
Decal Installation - Yb4409/Yb4409xl
(English)
Kit - Decals Universal Carrydeck
(Dutch)
(Spanish)
(French)
