Grove Crane YB4409 Parts Manual 2013
Brand: Grove
Model: Grove YB4409 Crane
Serial Number: 322219
Publication Date: 2013
Number of Pages: 379 Pages
Boom
Boom Group - 3 Section, Standard, Short
3330f
Cylinder Assembly - Telescope
(Complete Assembly)
1114010035 Boom Yb4409/Cd3330f
Hookblock Assembly -
8.5ton Working Load Limit
(1/2" Wire Rope)
(Complete Assembly)
Load Sense Indicator Installation
8.5 Ton
Anti Two Block Installation
Anti Two Block Group
Reel Assembly - Cable Anti Two Block
Hoist Group - Boom 3330f/Fl
Hoist Drive Assembly - 3330f/Fl
(Complete Assembly)
Hookblock Tie-Down Installation
(All Industrial Cranes)
Swivel Installation And Connectors -
2 Pass
Superstructure
Mast & Hydraulic Swivel Group
Hydraulic Swivel - 7 Circuit
Lowerworks/Carrier
Frame Kit - Dual Fuel
Engine Hood Assembly
Valve Bank Group
Valve Assembly - Solenoid
(Complete Assembly)
Outrigger Assembly - Standard
Valve Assembly - Control
Outriggers - Standard
(Complete Assembly)
Cylinder Assembly - Outrigger
Hydraulic
(Complete Assembly)
Alarm Group - Outrigger Down
(Standard)
3330f
Engine Installation - Gm 3.0l
Pump Assembly - Hydraulic
(Multiple Gear)
(Complete Assembly)
Pump Assembly - 45cc
Engine Assembly - 3.0l Epa 2007
(Dual Fuel)
Exhaust Group
Without Spark Arrestor
Transmission Group, Ref. Info.
Transmission, 2wheel Drive Complete
Drive Transmission - Gear Change
Drive Transmission - Internal Components
Drive Transmission - Reversal Unit
Steer Hose Installation
Valve Assembly
Steering Mode
(Complete Assembly)
Tire & Wheel Install - Alpha
Wheel And Tire Group - Bias
(Front)
Hitch/Pintel Group - Front/Rear
3330f
Hook Assembly - Pintle
Forged 5 Ton
3330f
Forged 5 Ton
Guard Installation - Light
Cab Mounting & Component Installation
Orbitrol, Steering
Fire Extinguisher Assembly
Door Install (No Heat Or A/C)
Door Assembly
Mirror Installation
Swing Gear And Bearing Install
Cylinder Assembly - Hydraulic
(Boom Hoist)
(Complete Assembly)
Gearbox Assembly -
Swing
(Complete Assembly)
Motor Assembly - Hydraulic Swing
(Complete Assembly)
Electrical Group - Tier 3 Diesel
(For Reference Only)
Swivel/Control Valve Plumbing
Battery And Cables Group
3330f/Fl-3339
Tank & Lines Group - Dual Fuel
Cooling System - Dual Fuel
Radiator/Oil Cooler Assembly
(Complete Assembly)
Air Cleaner Installation
Air Cleaner Assembly - Filter
Harness Group - Main Frame
(Dual Fuel)
3330/3339
Harness Assembly - Main Frame
(Complete Assembly)
Fan Guard - Installation
Without Air Conditioner
Yb4409
Hydraulic Tank - Suction And Return
Line Parts Assembly - Brake
Caliper, Parking Brake
Pressure And Return Lines Group
Pump & Return Lines
Valve Assembly Group -
Standard Outriggers
3330f/Fl
Valve Assembly - Combination
(Complete Assembly)
Relief Valve (2500psi)
Tank And Hoses - L.P.G. 3340
Kit - L.P.G. Hose 4.3l
Axles Installation
Front Axle Assembly
Axle Assembly - Drive/Steer
(Complete Assembly)
Axle Housing Group
Axle,Steer Housing & Cyl Group
Axle Ring & Pinion Assy. Group
Axle Differential Assy. Group
Axle Drive Shaft Assy. Group
Axle Wheel Hub Assy. Group
Axle Brake Assy. Group
Shaft, Drive
Rear Axle Assembly-Steer Only
Cylinder Assembly - Steering
Hydraulic
(Complete Assembly)
Operator Compartment Electric
With Outrigger Monitor
Harness Assembly - Dash
Outrigger Monitoring System Supplemental
Ind 15ton
Harness Installation -
Harness - Outrigger Monitoring System
Supplemental Frame
Outrigger Monitoring System Installation
Proximity Switch
Proximity Switch Assembly - 30mm
Carrier/Frame Cab
Seat Installation - Standard
Dual Fuel (W/O Return To Center)
Harness Assembly - Dash 5560b
(Complete Assembly)
Steer Harness
Cab Component Installation - Dual Fuel
Valve - Brake Modulating
Cab - Install Shell&Top Glass
Loose Ship Items
Wire Rope,13mm,8x25,Galv,80'
1114010036 Lshp Yb4409/Cd3330f
Socket Assembly - 1/2" W.R.
Specs/Schematics
Wiring Diagram, 4409-3330 Df
Schematic,Hyd,3330/4409
1114010037 Spec Yb4409/Cd3330f
Pressure Setting Procedure
Miscellaneous Decals
Kit - Decals Universal
(English)
Decal Installation - 7755
Decal Installation - Yb4409
(Nomenclature)
Decal - Load Rating And Range Diagram
Yb4409
(English)
Brand: Grove
Boom
3330f
(Complete Assembly)
(1/2" Wire Rope)
(Complete Assembly)
8.5 Ton
(Complete Assembly)
2 Pass
Superstructure
Lowerworks/Carrier
Valve Bank Group
(Complete Assembly)
(Complete Assembly)
Hydraulic
(Complete Assembly)
(Standard)
3330f
(Multiple Gear)
(Complete Assembly)
(Dual Fuel)
Exhaust Group
Valve Assembly
Steering Mode
(Complete Assembly)
(Front)
3330f
Forged 5 Ton
3330f
Forged 5 Ton
Orbitrol, Steering
Door Assembly
Mirror Installation
(Boom Hoist)
(Complete Assembly)
Gearbox Assembly -
Swing
(Complete Assembly)
(Complete Assembly)
3330f/Fl-3339
(Complete Assembly)
(Dual Fuel)
3330/3339
(Complete Assembly)
Yb4409
Pump & Return Lines
Standard Outriggers
3330f/Fl
(Complete Assembly)
Axles Installation
Front Axle Assembly
(Complete Assembly)
Axle Housing Group
Shaft, Drive
Hydraulic
(Complete Assembly)
Ind 15ton
Supplemental Frame
Proximity Switch
Carrier/Frame Cab
(Complete Assembly)
Steer Harness
Loose Ship Items
Specs/Schematics
(English)
(Nomenclature)
Yb4409
(English)
