Grove Crane YB4409 Parts Manual 2010
Brand: Grove
Model: Grove YB4409 Crane
Serial Number: 321467
Publication Date: 2010
Number of Pages: 407 Pages
Boom
Boom Group - 4 Section
(Standard)
3330f/Fl
2nd Section, Boom
Cylinder Assembly - Telescope
(Complete Assembly)
1114010035 Boom Yb4409/Cd3330f
Hookblock Assembly -
8.5ton Working Load Limit
(1/2" Wire Rope)
(Complete Assembly)
Load Sense Indicator Installation
8.5 Ton
Work Light Installation - Boom
Anti Two Block Installation
Anti Two Block Group
Reel Assembly - Cable Anti Two Block
Hoist Group - Boom 3330f/Fl
Hoist Drive Assembly - 3330f/Fl
(Complete Assembly)
Swing Gear & Boom Mounting Assembly
Cylinder Assembly - Hydraulic
(Boom Hoist)
(Complete Assembly)
Motor Assembly - Hydraulic Swing
(Complete Assembly)
Gearbox Assembly -
Swing
(Complete Assembly)
Hookblock Tie-Down Installation
(All Industrial Cranes)
Mast/Counterweight Modified 21ft
With Man Ext
Swivel Installation And Connectors -
2 Pass
Superstructure
Axle Steering Assembly - Front
Valve Assembly - Solenoid 12 Volt
(Complete Assembly)
Pressure And Return Line Assembly
Pump And Return Lines Assembly
3330/3339
Valve Group - Standard Outrigger
3330f/Fl
Valve Assembly - Anti Void/Relief
(Complete Assembly)
Lowerworks/Carrier
Frame Group
(Tier 3 Diesel Engine)
Valve Bank Installation
(Complete Assembly)
Outrigger Assembly - Standard
Valve Assembly - Control
Outriggers - Standard
(Complete Assembly)
Cylinder Assembly - Outrigger
Hydraulic
(Complete Assembly)
Alarm Group - Outrigger Down
(Standard)
3330f
Engine Group - Cummins 3.3l
3339
Engine Assembly - Cummins Qsb 3.3-99
(Tier 3 Diesel)
Filter Assy. Fuel/Water Separ.
Element,Filter Fuel/Water Sep
Air Filter Assy.
Pump Assembly - Hydraulic
(Multiple Gear)
(Complete Assembly)
Exhaust Group - Tier 3 Diesel
Transmission Group, Ref. Info.
Transmission, 2wheel Drive Complete
Drive Transmission - Gear Change
Drive Transmission - Internal Components
Drive Transmission - Reversal Unit
Axle Installation -
3340
Axle Assembly - Drive/Steer
(Complete Assembly)
Axle Housing Group
Axle,Steer Housing & Cyl Group
Axle Ring & Pinion Assy. Group
Axle Differential Assy. Group
Axle Drive Shaft Assy. Group
Axle Wheel Hub Assy. Group
Axle Brake Assy. Group
Axle Assembly - Front
Brake Parts
3330 - 3340
Rear Axle Assembly
Cylinder Assembly - Steering
Hydraulic
(Complete Assembly)
Wheel And Tire Group - Bias
(For Reference Only)
(Front)
(Rear)
Hitch/Pintel Group - Front/Rear
3330f
Hook Assembly - Pintle
Forged 5 Ton
3330f
Forged 5 Ton
Light Guard Group - 3330/5500
Standard Cab Group
3330f / Fl - 3339
Fire Extinguisher Assembly
Orbitrol, Steering
Enclosed Cab Installation
Window Assembly - Slider Door
(Aluminum Frame)
(Complete Assembly)
Heat And Defroster Group
Heater Assembly
(Complete Assembly)
Light Assembly - Strobe
(Enclosed Cab)
Kit - Windshield Washer
Cd3330
Mirror Assembly - 3330f/5540f
Electrical Group - Tier 3 Diesel
Swivel / Control Valve Plumbing
3330 / 4409
Battery Components
3330f / Fl - 3339
Shaft, Drive
Electrical Group -
Operator’s Compartment T3 Diesel
2 Wheel/4 Wheel Steer
Harness Assembly - Dash 5560b
(Complete Assembly)
Tank Group - Diesel
Cooling System - Tier 3 Diesel (3339)
Radiator/Charge Air Cooler/
Transmission Oil Cooler Assembly
(Complete Assembly)
Air Cleaner Installation
(Tier 3 Diesel)
3339
Operator Compartment - Standard Cab
(Tier 3 Diesel Engine Option)
3339
Control Assembly -
Electronic Throttle
Valve - Brake Modulating
Harness Group - Frame (Tier 3 Diesel)
3330
Harness Assembly - Main Frame
(Complete Assembly)
Fan Guard - Installation
Without Air Conditioner
Yb4409
Charge Air Cool Group
Electrical Group - Engine Harness
(Tier 3 Diesel)
(All 4409’s)
Harness Assembly - Engine
(Complete Assembly)
Hydraulic Tank - Suction And Return
Line Parts Assembly - Brake
Caliper, Parking Brake
Loose Ship Items
1114010036 Lshp Yb4409/Cd3330f
Specs/Schematics
Wire Diagram,3330-3339 T3 Dsl
Hydraulic Schematic,3330/4409
1114010037 Spec Yb4409/Cd3330f
80003619 Decal Yb4409
Kit - Decals Universal
(English)
Decal Installation - 7755
Decal Installation - Yb4409
Decal - Load Rating And Range Diagram
Yb4409
(English)
Decal Installation - Yb4409/Yb4409xl
(English)
Kit - Decals Universal Carrydeck
(Dutch)
(Spanish)
(French)
Yb4409xl Nomenclature Kit
Yb4409
(English)
3 Section Boom
Yb4409xl
(Metric)
(English)
Brand: Grove
Boom
(Standard)
3330f/Fl
2nd Section, Boom
(Complete Assembly)
(1/2" Wire Rope)
(Complete Assembly)
8.5 Ton
(Complete Assembly)
(Boom Hoist)
(Complete Assembly)
(Complete Assembly)
Gearbox Assembly -
Swing
(Complete Assembly)
With Man Ext
2 Pass
Superstructure
(Complete Assembly)
3330/3339
3330f/Fl
(Complete Assembly)
Lowerworks/Carrier
Frame Group
(Complete Assembly)
(Complete Assembly)
Hydraulic
(Complete Assembly)
(Standard)
3330f
3339
(Tier 3 Diesel)
Air Filter Assy.
(Multiple Gear)
(Complete Assembly)
Axle Installation -
3340
(Complete Assembly)
Axle Housing Group
Brake Parts
3330 - 3340
Rear Axle Assembly
Hydraulic
(Complete Assembly)
(Front)
(Rear)
3330f
Forged 5 Ton
3330f
Forged 5 Ton
Standard Cab Group
3330f / Fl - 3339
Orbitrol, Steering
(Aluminum Frame)
(Complete Assembly)
Heater Assembly
(Complete Assembly)
(Enclosed Cab)
Cd3330
3330 / 4409
Battery Components
3330f / Fl - 3339
Shaft, Drive
Electrical Group -
(Complete Assembly)
Tank Group - Diesel
(Complete Assembly)
(Tier 3 Diesel)
3339
3339
Control Assembly -
Electronic Throttle
3330
(Complete Assembly)
Yb4409
(Tier 3 Diesel)
(All 4409’s)
(Complete Assembly)
Loose Ship Items
Specs/Schematics
(English)
Yb4409
(English)
(English)
(Dutch)
(Spanish)
(French)
Yb4409
(English)
3 Section Boom
Yb4409xl
(Metric)
(English)
