Grove Crane YB4409-2 Parts Manual 2022
Brand: Grove
Model: Grove YB4409-2 Crane
Serial Number: 320768
Publication Date: 2022
Number of Pages: 361 Pages
Boom
Boom Group - 3 Section 3340
(For Reference Only)
Boom Assembly - 1st Section
3340
Reel Installation - Anti Two Block Cable
Reel Assembly - Cable Modified
14 Gauge With 2 Way Connector
Boom Assembly - 2nd Section
3340
Boom Assembly - 3rd Section
3340
Crowd Assembly - 3340
Cylinder Assembly - Hydraulic
(Complete Assembly)
Chain Assembly - 3340
Anti-Two Block Assembly
3340
Pivoting Head Assembly - 3340
Socket & Wedge With Clip 5/8"
Socket Assembly - 5/8" Wedge
(Complete Assembly)
Drop Block Installation
Load Sense Indicator Group
With Rated Capacity Limiter
3340b
Kit - Load Sense Indicator
With Rated Capacity Limiter 9/16" Wr
Guide Assembly - Cable
(Complete Assembly)
(Complete Assembly)
Swing Mast And Attaching Parts
3339
Swivel Assembly - Hydraulic
7 Port
(Complete Assembly)
Hoist Assembly - Main
Type B Without Drum Rotation Indicator
(Complete Assembly)
3340b
Gear Assembly - Swing
3340b-3339
Motor Assembly - Hydraulic Swing
(Complete Assembly)
Gearbox Assembly -
Swing
(Complete Assembly)
Mounting Assembly - Boom
3340b-3339
(Complete Assembly)
Superstructure
Crab Steer Installation
3330f/3339
Valve Assembly - Solenoid 12 Volt
(Complete Assembly)
(Complete Assembly)
Hydraulics Group - 3339
Hydraulic Tank - Suction And Return
Line Parts Assembly - Brake
Caliper, Parking Brake
Axle Steering Assembly - Front
(Complete Assembly)
Pressure And Return Line Assembly
Pump And Return Lines Assembly
3330/3339
Valve Assembly
Outriggers - Independent
9 Ton Industrial
Valve Assembly - Anti Void/Relief
(Complete Assembly)
(Complete Assembly)
Carrier/Lowerworks
Frame Kit Assembly
Valve Bank Installation
(Complete Assembly)
Outrigger Assembly - Independent
3330f / Fl - 3339
Valve Assembly - Control
(Independent Outriggers)
Cylinder Assembly - Outrigger
Hydraulic
(Complete Assembly)
Alarm Installation -
3330f
Engine Group - Cummins Tier 2
Pump Assembly - Hydraulic
(Multiple Gear)
(Complete Assembly)
Engine, Cummins 3.3 L Turbo Units With
S/N 190104-04 & After
Cleaner Assembly - Air
(Complete Assembly)
Harness Assembly - Carrydeck 3330f
Cummins Engine With Shutdowns
(Complete Assembly)
Radiator Installation - Diesel
3330/3340/3339
Radiator/Oil Cooler Assembly
(Complete Assembly)
Air Cleaner Installation - Diesel
3330/3340/3339
Filter Assembly - Air Cleaner
(Complete Assembly)
(Complete Assembly)
Exhaust Assembly - Diesel (Cummins)
3330f/3339
Operator Compartment Parts - Optional
(Diesel Engine Tier 2)
Valve - Brake Modulating
Harness Group - Mainframe (Diesel)
3330f/3339
Harness Assembly - Main Frame
3330f
(Complete Assembly)
Harness Assembly - Dash 5560b
3330f/5540f
(Complete Assembly)
Start Kit Group - Cold
Kit - Cold Start
Battery Assembly
(Complete Assembly)
Transmission Group, Ref. Info.
Transmission, 2wheel Drive Complete
Drive Transmission - Gear Change
Drive Transmission - Internal Components
Drive Transmission - Reversal Unit
Axle Installation -
3340
Shaft - Drive
Axle Assembly - Drive/Steer
(Complete Assembly)
Axle Housing Group
Axle,Steer Housing & Cyl Group
Axle Ring & Pinion Assy. Group
Axle Differential Assy. Group
Axle Drive Shaft Assy. Group
Axle Wheel Hub Assy. Group
Axle Brake Assy. Group
Axle Assembly - Front
Brake Parts
3330 - 3340
Rear Axle Assembly
Cylinder Assembly - Steering
Hydraulic
(Complete Assembly)
Grp,3340,Whl&Tire
Grp, Tire&Wheel, Frt, Carraro
Assy, Tire & Whl(Ref 80001632)
Grp, Tire&Wheel, Rear, Carraro
Assy, Tire&Wheel(Ref 80001634)
Hitch/Pintel Group - Front/Rear
3330f
Hook Assembly - Pintle
Forged 5 Ton
Standard Cab Group
3330f / Fl - 3339
Fire Extinguisher Assembly
Orbitrol, Steering
Enclosed Cab Installation
Window Assembly - Slider Door
(Aluminum Frame)
(Complete Assembly)
Seat Assembly - Standard
Heater/Defroster Group
(Tier 2 Diesel)
3330f
Heater Assembly
(Complete Assembly)
Heater/Defroster Parts - 3330f
Air Conditioner/Heating Group - Diesel
3330f/Fl
Fan Assembly - Defroster
5540f
(Complete Assembly)
Air Conditioning Unit
(Air And Heat)
3330f/Fl
(Complete Assembly)
A/C & Heater Assy. 12v. Blower
Mirror Assembly - 3330f/5540f
Electrical Group
Swivel Hook Up
3339
Battery And Cables Group
3330f/Fl-3339
Shaft, Drive
Carrier/Frame Cab
Kit, Dome Light
Light Assembly - Strobe
(Enclosed Cab)
Kit - Windshield Washer
Cd3330
Loose Ship Items
Weight Group - Down Haul
With Limit Indicator System
Brand: Grove
Boom
3340
3340
3340
(Complete Assembly)
3340
(Complete Assembly)
3340b
(Complete Assembly)
(Complete Assembly)
3339
7 Port
(Complete Assembly)
(Complete Assembly)
3340b
3340b-3339
(Complete Assembly)
Gearbox Assembly -
Swing
(Complete Assembly)
3340b-3339
(Complete Assembly)
Superstructure
3330f/3339
(Complete Assembly)
(Complete Assembly)
(Complete Assembly)
3330/3339
Valve Assembly
9 Ton Industrial
(Complete Assembly)
(Complete Assembly)
Carrier/Lowerworks
Frame Kit Assembly
(Complete Assembly)
3330f / Fl - 3339
Hydraulic
(Complete Assembly)
3330f
(Multiple Gear)
(Complete Assembly)
(Complete Assembly)
(Complete Assembly)
3330/3340/3339
(Complete Assembly)
3330/3340/3339
(Complete Assembly)
(Complete Assembly)
3330f/3339
3330f/3339
3330f
(Complete Assembly)
3330f/5540f
(Complete Assembly)
Kit - Cold Start
Battery Assembly
(Complete Assembly)
Axle Installation -
3340
Shaft - Drive
(Complete Assembly)
Axle Housing Group
Brake Parts
3330 - 3340
Rear Axle Assembly
Hydraulic
(Complete Assembly)
Grp,3340,Whl&Tire
3330f
Forged 5 Ton
Standard Cab Group
3330f / Fl - 3339
Orbitrol, Steering
(Aluminum Frame)
(Complete Assembly)
(Tier 2 Diesel)
3330f
Heater Assembly
(Complete Assembly)
3330f/Fl
5540f
(Complete Assembly)
(Air And Heat)
3330f/Fl
(Complete Assembly)
Electrical Group
Swivel Hook Up
3339
3330f/Fl-3339
Shaft, Drive
Carrier/Frame Cab
Kit, Dome Light
(Enclosed Cab)
Cd3330
Loose Ship Items
