Grove Crane YB4409-2 Parts Manual 2013
Brand: Grove
Model: Grove YB4409-2 Crane
Serial Number: 321110
Publication Date: 2013
Number of Pages: 355 Pages
Boom
Boom Group - 3 Section 3340
(For Reference Only)
Rope, Wire 9/16"
Boom Assembly - 1st Section
3340
Reel Installation - Anti Two Block Cable
Reel Assembly - Cable Modified
14 Gauge With 2 Way Connector
Boom Assembly - 2nd Section
3340
Boom Assembly - 3rd Section
3340
Crowd Assembly - 3340
Cylinder Assembly - Hydraulic
(Complete Assembly)
Chain Assembly - 3340
Anti-Two Block Assembly
3340
Pivoting Head Assembly - 3340
Socket & Wedge With Clip 5/8"
Socket Assembly - 5/8" Wedge
(Complete Assembly)
Weight Group - Down Haul
Without Limit Indicator System
1114010023 Bm Yb4409-2/Cd3339
Jib Group - 12ft Jib 3340
Sheave Assembly - Deflector
(Complete Assembly)
Switch Assembly W/ Wire Harness
Anti Double-Blocking
(3340b Jib With Stinger)
Drop Block Installation
Grp,Li,Lsi,3340b
Kit - Load Indicator W/9/16"Wr
Swing Mast And Attaching Parts
3339
Swivel Assembly - Hydraulic
7 Port
(Complete Assembly)
Hoist Assembly - Main
Type B Without Drum Rotation Indicator
(Complete Assembly)
3340b
Gear Assembly - Swing
3340b-3339
Motor Assembly - Hydraulic Swing
(Complete Assembly)
Gearbox Assembly -
Swing
(Complete Assembly)
Mounting Assembly - Boom
3340b-3339
(Complete Assembly)
Superstructure
Crab Steer Installation
3330f/3339
Valve Assembly - Solenoid 12 Volt
(Complete Assembly)
(Complete Assembly)
Hydraulics Group - 3339
Hydraulic Tank - Suction And Return
Line Parts Assembly - Brake
Caliper, Parking Brake
Axle Steering Assembly - Front
(Complete Assembly)
Pressure And Return Line Assembly
Pump And Return Lines Assembly
3330/3339
Valve Assembly
Outriggers - Independent
9 Ton Industrial
Valve Assembly - Anti Void/Relief
(Complete Assembly)
(Complete Assembly)
Lowerworks/Carrier
Frame Group
(Tier 3 Diesel Engine)
Valve Bank Installation
(Complete Assembly)
Outrigger Assembly - Independent
3330f / Fl - 3339
Valve Assembly - Control
(Independent Outriggers)
Cylinder Assembly - Outrigger
Hydraulic
(Complete Assembly)
Alarm Installation -
3330f
Engine Group - Cummins 3.3l
3339
Engine Assembly - Cummins Qsb 3.3-99
(Tier 3 Diesel)
Pump Assembly - Hydraulic
(Multiple Gear)
(Complete Assembly)
Cooling System - Tier 3 Diesel (3339)
Radiator/Charge Air Cooler/
Transmission Oil Cooler Assembly
(Complete Assembly)
Air Cleaner Installation
(Tier 3 Diesel)
3339
Charge Air Cool Group
Operator Compartment - Standard Cab
(Tier 3 Diesel Engine Option)
3339
Control Assembly -
Electronic Throttle
Valve - Brake Modulating
Harness Group - Frame (Tier 3 Diesel)
3330
Harness Assembly - Main Frame
(Complete Assembly)
Electrical Group - Engine Harness
(Tier 3 Diesel)
(All 4409's)
Harness Assembly - Engine Cummins Qsb3.3
(Tier 3)
(Complete Assembly)
Exhaust Group - Tier 3 Diesel
Transmission Group, Ref. Info.
Transmission, 2wheel Drive Complete
Axle Installation -
3340
Shaft - Drive
Axle Assembly - Drive/Steer
(Complete Assembly)
Axle Housing Group
Axle,Steer Housing & Cyl Group
Axle Ring & Pinion Assy. Group
Axle Differential Assy. Group
Axle Drive Shaft Assy. Group
Axle Wheel Hub Assy. Group
Axle Brake Assy. Group
Axle Assembly - Front
Brake Parts
3330 - 3340
Rear Axle Assembly
Cylinder Assembly - Steering
Hydraulic
(Complete Assembly)
Wheel And Tire Group
Wheel And Tire Assembly - Front
Wheel And Tire Assembly - Rear Alpha
Standard Cab Group
3330f / Fl - 3339
Fire Extinguisher Assembly
Orbitrol, Steering
Enclosed Cab Installation
Window Assembly - Slider Door
(Aluminum Frame)
(Complete Assembly)
Air Conditioner And Heating Group
Air Conditioning Unit
(Air And Heat)
3330/3339
(Complete Assembly)
A/C & Heater Assy. 12v. Blower
Mirror Assembly - 3330f/5540f
Electrical Group - Tier 3 Diesel
Swivel Hook Up
3339
Battery Components
3330f / Fl - 3339
Shaft, Drive
Guard Installation - Fan (Tier 3)
With Air Conditioner
Electrical Group -
Operator's Compartment T3 Diesel
2 Wheel/4 Wheel Steer
Harness Assembly - Dash 5560b
(Complete Assembly)
Tank Group - Diesel
Tank, Diesel 4409/4409-2/4411
Loose Ship Items
1114010024 Ls Yb4409-2/Cd3339
Specs/Schematics
Decal - Load Rating And Range Diagram
Yb4409-2
(English)
Wire Diagram,3330-3339 T3 Dsl
Miscellaneous Decals
Kit - Decals Universal
(English)
Decal Installation - 7755
Decal Installation - Yb4409-2
(Nomenclature)
Brand: Grove
Boom
Rope, Wire 9/16"
3340
3340
3340
(Complete Assembly)
3340
(Complete Assembly)
(Complete Assembly)
Grp,Li,Lsi,3340b
3339
7 Port
(Complete Assembly)
(Complete Assembly)
3340b
3340b-3339
(Complete Assembly)
Gearbox Assembly -
Swing
(Complete Assembly)
3340b-3339
(Complete Assembly)
Superstructure
3330f/3339
(Complete Assembly)
(Complete Assembly)
(Complete Assembly)
3330/3339
Valve Assembly
9 Ton Industrial
(Complete Assembly)
(Complete Assembly)
Lowerworks/Carrier
Frame Group
(Complete Assembly)
3330f / Fl - 3339
Hydraulic
(Complete Assembly)
3330f
3339
(Tier 3 Diesel)
(Multiple Gear)
(Complete Assembly)
(Complete Assembly)
(Tier 3 Diesel)
3339
3339
Control Assembly -
Electronic Throttle
3330
(Complete Assembly)
(Tier 3 Diesel)
(All 4409's)
(Tier 3)
(Complete Assembly)
Axle Installation -
3340
Shaft - Drive
(Complete Assembly)
Axle Housing Group
Brake Parts
3330 - 3340
Rear Axle Assembly
Hydraulic
(Complete Assembly)
Standard Cab Group
3330f / Fl - 3339
Orbitrol, Steering
(Aluminum Frame)
(Complete Assembly)
(Air And Heat)
3330/3339
(Complete Assembly)
Swivel Hook Up
3339
Battery Components
3330f / Fl - 3339
Shaft, Drive
Electrical Group -
(Complete Assembly)
Tank Group - Diesel
Loose Ship Items
Specs/Schematics
Yb4409-2
(English)
(English)
(Nomenclature)
