Grove Crane YB4408-2 Parts Manual 2017
Brand: Grove
Model: Grove YB4408-2 Crane
Serial Number: 322440
Publication Date: 2017
Number of Pages: 497 Pages
Boom
Boom Assy (3 Section)
Boom Assy - Section 1 Of 3
Boom Assembly - Section 2 Of 3
Boom Assembly - Section 3 Of 3
Crowd Assembly-3 Section Boom
Cylinder Assy. - Hydraulic
Chain Assembly - 3340
Pivot Boom Head Installation
Electric Swivel Installation
And Connectors
Instl, 9t Wylie Boom
Harness W/ Resistor Assembly
Resistor Assembly
Guide Assembly - Roller
(Complete Assembly)
Instl, Yb5515 Work Lights
Yb5515 Work Light Harness
Plumbing And Roller Group - Hoist
3340b
Boom Installation -(3 Section)
Hookblock Tie-Down Installation
(All Industrial Cranes)
Superstructure
Assy, Ind9-T4 Mast
Hydraulic Swivel, Ind9
Lift Cylinder (9 & 10.5 Ton)
Piston Assy.
Head Assy.
Hoist W/Dl2 Sensor
Output Gear Set
Gear Set, Input
Roller Assembly - Cable Packer
Instl, 9t Wylie Mast
Wylie Kit, Mast
Valve Assy (Independent O/R)
Valve Assembly - Combination
(Complete Assembly)
Alarm Installation-Outrigger Independent
Harness - Outrigger Alarm Switches
Hydraulic Reservoir Install
Hydraulic Reservoir Assembly
Hydraulic Return Plumbing Installation
Carrier Valve Plumbing
Solenoid Valve
Swivel-Control Valve Plumbing
Electrical System Installation -
Battery & Relay Box
Electrical Box Assembly
Panel Assembly
Wiring Harness
Harness Assembly - Carrier
Ind 8.5ton
Engine Installation - Cummins Qsb3.3
(Tier 4)
Engine Assembly - Cummins Qsb3.3
(Tier 4)
Pump Assembly - 45cc
Transmission Group, Ref. Info.
Transmission, 2wheel Drive Complete
Drive Transmission - Gear Change
Drive Transmission - Internal Components
Drive Transmission - Reversal Unit
(Tier 4)
Harness Assembly - Engine
Ecm Cover Installation
Element,Filter Fuel/Water Sep
Crankcase Breather Assy. Group
Pump Assembly - Hydraulic
(Multiple Gear)
(Complete Assembly)
Instl, Radiator, Ind8.5t T4
Assy, Radiator, Ind8.5ton-4
Cooler, Rad And Cac
Fan Shroud Assembly
Surge Tank Assembly
Transmission Oil Cooler Installation
Transmission Oil Cooler Assembly
Oil Cooler - Transmission
Toc Valve & Hose Installation
Transmission Oil Cooler Control Valve
Exhaust Installation T4-Yb4409
Air Intake Install - Diesel T4
Air Cleaner
Block Heater Installation - Qsb3.3 120v
Fan Guard Installation W/O A/C
Tire & Wheel Install - Alpha
Wheel And Tire Group - Bias
(Front)
Hitch/Pintel Group - Front/Rear
3330f
Hook Assembly - Pintle
Forged 5 Ton
Guard Installation - Light
Cab Component Installation-T3
Control Assembly -
Electronic Throttle
Valve - Brake Modulating
Instl Dash 8.5/9ton T-4
Dash Assy
Wiring Harness - Dash
Panel, Dash
Door Install (No Heat Or A/C)
Door Assembly
Return To Center Steering
Module & Wiring Installation
Fire Extinguisher Assembly
Outrigger Monitoring System Installation
Proximity Switch
Proximity Switch Assembly - 30mm
Mirror Installation
Pump & Return Lines Installation
Switch Installation - Return To Center
Switch Assembly - Proximity
(Normally Open)
(Rework)
Blocking Valve Rework
Valve, Blocking
Instl, 9t Wylie Carr T4
I4300 Cab Kit
I4300 Display Controller
Carrier/Frame Cab
Cab - Install Shell&Top Glass
Cab Components Installation
Orbitrol, Steering
Turn Signal Switch Rework
Seat Installation - Standard
Light Installation - Strobe
Loose Ship Items
Downhaul Weight, 105 Lb
Hookblock Assembly -
10.5ton Working Load Limit
(9/16" Wire Rope)
(Complete Assembly)
Socket Assembly - 5/8" Wedge
Rope, Wire 9/16"
Specs/Schematics
Electric Schematic
Hydraulic Schematic
Pressure Setting Procedure
Schematic, 9t T4 Lubrications
Decal Installation - Ind 9ton
Decal Installation - Cab
Decal Install - Carrier/Super
Decal - Pivot Head
Decal - Outrigger Control
Panel, Dash
Decal - Angle Indicator Left
(English)
Decal - Angle Indicator Right
(English)
Decal-Shift Pattern
Panel - Yardboss Serial Number
