Grove Crane TMC540 Parts Manual 2020
Brand: Grove
Model: Grove TMC540 40t Basic Crane
Serial Number: 602609
Publication Date: 2020
Number of Pages: 587 Pages
Boom
Boom Assembly 102'
Tele Hydraulic Cylinder Assy
Sheave Assembly - 5/8" Rope
Cable Reel Lwg508 - Iflex 5
Roller Guide Assembly
Box Assembly - Junction
A2b Flag Assy
Connector Assembly
Dummy Plug, 2-Pin
Socket Assy 5/8"
Lmi Boom Kit
Weight And Chain Assembly
(Complete Assembly)
Boom Angle Indicator
Installation
Pointer Assembly
Hook Block Assembly - 40 Ton
3 Sheave
(Complete Assembly)
Cover Installation - Boom Hole
Alarm Installation-Lmi
Cable Assembly - Lmi Alarm
(Complete Assembly)
Superstructure
Motor Assembly - Swing Drive
(Complete Assembly)
Esi-Superstructure Cab
Panel Assembly - Overhead Console
(Complete Assembly)
Harness Assembly - Superstructure Cab
Overhead Panel
Panel Assy Fuse And Relay
Harness Assembly-Fuse & Relay Panel
Cable Assembly-Common Cab Power Panel
Harness Assembly-Superstructure Cab
Front Console Panel Assembly
-Rh
Harness Assembly-
Hoist Cover Installation-Main
Lmi Override Assy - 24v
Harness Assembly-Cranestar Tcu
Lock Installation - 360 Swing
Lock Assembly - Swing
(Complete Assembly)
Lock Installation - Pin
Cylinder Installation-Lower Pivot & Lift
Cylinder Assembly - Lift
(Complete Assembly)
Valve Assembly - Holding
(Complete Assembly)
Bolt Installation - Bearing
Lube Installation - Turntable Bearing
(Manual)
Pin Lock Cable Installation
Final Assembly
(Superstructure)
Binder Installation
Main And Future Auxiliary Hoist
Superstructure
Hoist Installation - Main
(C.E. Conformity)
Hoist Assembly - Hp15c/17g
With 3rd Wrap
(Complete Assembly)
Roller Assy. Idler Group
Powerplant & Tray Installation
Engine Installation - Cummins Qsb3.3
Engine Assembly-Cummins Qsb3.3
Pump Assembly - Gear
(Clock Wise)
(Complete Assembly)
Pump Assembly - Piston
With Torque Limiting
(Complete Assembly)
Alternator Installation
Modified
Kit - Air Conditioner Compressor
Adjusting Arm
Fuel Filter Assy. W/Wif Sensor
Element,Filter Fuel/Water Sep
Hydraulic Tank Installation
Hydraulic Reservior Assy
Filter Assy. Hyd. Return
Fuel Tank Installation
Radiator Installation
Radiator Assembly
Electrical System Installation -
Power Plant
Kit - Cable (Batteries)
Tm500e2
(Complete Assembly)
Panel Assembly-Battery Box
Kit - Relay Panel Cable
Tm500e2
(Complete Assembly)
Harness Assembly -
Relays
(Complete Assembly)
Harness Assembly - Engine
Tm500e2
(Complete Assembly)
Cover & Step Installation
Engine Cover Assembly
Cover Assembly - Battery
(Complete Assembly)
Air Intake Installation
Air Cleaner
Power Plant
Fuel Lines Installation
Mounting Kit - Oil Cooler
Mirror Installation - Hoist
Kit - Lmi S/S Iflex 5
Superstructure
Electrical System Installation-Ss
Diode (Modified)
Cover Installation - Valve
Counterweight Installation
Bottle Installation - Washer
(C.E. Conformity)
Supplemental - Superstructure
Harness Assembly - Supplemental
Superstructure
Mirror Installation
- Turntable
(C.E. Conformity)
Superstructure Cab
Control Seat Installation
Without Auxiliary Hoist
(Dual Axis)
Control Seat Assembly
(Dual Axis)
Switch Assembly - Proximity
(Normally Open)
(Complete Assembly)
Controller Assembly - 8-32 Volt
Right Hand Armrest
(Complete Assembly)
Left Hand Armrest
(Complete Assembly)
Harness Assembly - Seat
(Complete Assembly)
Heater And Air Condition Control
Panel Installation
Heater & Control Panel (24v)
Plastic Covers Install
Air Condition Installation-Ss
Kit - 24 Volt Air Conditioner
(Complete Assembly)
Kit - Cummins Air Conditioner Compressor
(24 Volt)
(Complete Assembly)
A/C Hose Kit
Lmi Cab Kit, Iflex2
Lmi Cab Kit Installation
Supplemental - Superstructure Cab
Harness Assembly -
Fuse & Relay Panel
Harness Assy, Outrigger Cab To Board
Cab Overhead
Front Sun Visor Installtion
First Aid Kit Installation
Cab Cover Installation-Rear
(C.E. Conformity)
Cab Installation-24v
Cranestar Installation - Superstructure
Tm500e-2/Tmc540
Tcu And Sat Antenna Kit
Carrier/Lowerworks
Outrigger Beam Installation
Outrigger Beam Assembly
Cylinder Assembly-4 1/2" Outrigger Jack
(Complete Assembly)
Outrigger Extend Cylinder
(Complete Assembly)
Cylinder Assembly Modified
Cylinder Assembly - 2 1/2" O/R Extension
(Complete Assembly)
Access Installaton
Fender,Ladder And Mudflap Installation
Service Ladder Assembly
Electrical System Installation - Frame
Harness Assembly - Carrier
Swivel Installation -
Electric And Hydraulic
Swivel Assembly -
Swivel Assembly - 2 Port Hydraulic
(Complete Assembly)
Slip Ring Assy 10 Cond W/Slew
Electrical Group - Operator Compartment
Panel Assembly - Left Hand Remote
Outrigger Control
(Complete Assembly)
Switch Assembly - Emergency Stop
(Modified)
(Complete Assembly)
Panel Assembly - Right Hand Remote
Outrigger Control
(Complete Assembly)
(Modified)
(Complete Assembly)
Valve Installation - Hydraulic
Outrigger
(Carrier)
Valve Assembly - Outrigger Control
4 Section
(Complete Assembly)
Hydraulic Lines Installation - Outrigger
Exhaust Installation
Rest Hook & Ball Installation
Float Assy, Outrigger
Sub-Frame Attachment Installation
Switch Assembly
Sling Box Installation
Cover Installation - Outrigger
Beam
Outrigger Controller Installation
Outrigger Controller Assembly-Right
Cable Assembly
Hookblock Tie-Down Installation
Decal Kit - Tmc540
Light Installation - Ce
Beacon Assembly - Rotation Yellow
(For Reference Only)
Foam Instl-Engine Compartment
Foam Installation-Valve Cover
Loose Ship Items
16mm Dia Hoisting Wire Rope -
Specs/Schematics
Hyd System Schem Tmc500e-2
Hyd Press Set Proc 102' Boom
Electrical Schematic Tm500e-2
Schematic-Main Cab Wiring
Spec - Rework For Scania Truck
Decal Installation - Tmc540
Standard
Decal Installation-Tmc540
Standard Cab
Standard - Carrier
Standard - Superstructure
Decal - Diesel
Standard - Boom
Nomenclature
Miscellaneous
Supplemental Decal Installation
Decal Installation - Front Bumper
Brand: Grove
Boom
Boom Assembly 102'
A2b Flag Assy
Connector Assembly
Dummy Plug, 2-Pin
Socket Assy 5/8"
Lmi Boom Kit
(Complete Assembly)
Installation
Pointer Assembly
3 Sheave
(Complete Assembly)
(Complete Assembly)
Superstructure
(Complete Assembly)
(Complete Assembly)
Overhead Panel
-Rh
Harness Assembly-
(Complete Assembly)
(Complete Assembly)
(Complete Assembly)
(Manual)
Final Assembly
(Superstructure)
Binder Installation
Superstructure
(C.E. Conformity)
With 3rd Wrap
(Complete Assembly)
(Clock Wise)
(Complete Assembly)
(Complete Assembly)
Modified
Adjusting Arm
Radiator Assembly
Power Plant
Tm500e2
(Complete Assembly)
Tm500e2
(Complete Assembly)
Harness Assembly -
Relays
(Complete Assembly)
Tm500e2
(Complete Assembly)
(Complete Assembly)
Air Cleaner
Power Plant
Superstructure
Diode (Modified)
(C.E. Conformity)
Superstructure
Mirror Installation
- Turntable
(C.E. Conformity)
Superstructure Cab
(Dual Axis)
(Dual Axis)
(Normally Open)
(Complete Assembly)
Right Hand Armrest
(Complete Assembly)
Left Hand Armrest
(Complete Assembly)
(Complete Assembly)
Panel Installation
(Complete Assembly)
(24 Volt)
(Complete Assembly)
A/C Hose Kit
Lmi Cab Kit, Iflex2
Harness Assembly -
Fuse & Relay Panel
Cab Overhead
(C.E. Conformity)
Tm500e-2/Tmc540
Carrier/Lowerworks
(Complete Assembly)
(Complete Assembly)
(Complete Assembly)
Access Installaton
Swivel Assembly -
(Complete Assembly)
Outrigger Control
(Complete Assembly)
(Modified)
(Complete Assembly)
Outrigger Control
(Complete Assembly)
(Modified)
(Complete Assembly)
Outrigger
(Carrier)
4 Section
(Complete Assembly)
Switch Assembly
Beam
Cable Assembly
Decal Kit - Tmc540
Loose Ship Items
Specs/Schematics
Standard
Standard Cab
Standard - Carrier
Decal - Diesel
Standard - Boom
Nomenclature
Miscellaneous
