118
6,911
Grove Crane TMC540 Parts Manual 2009
Brand: Grove
Model: Grove TMC540 40t Basic Crane
Serial Number: 230851
Publication Date: 2009
Number of Pages: 699 Pages
Boom Group
Boom Assembly - 4 Section
102’
Cylinder Assembly - Telescope
(Complete Assembly)
Sheave Assembly - 5/8" Rope
Socket Assy 5/8"
Cable Reel Lwg508 - Iflex 5
Roller Guide Assembly
Box Assembly - Junction
Flag Assembly - A2b
Retainer
(Complete Assembly)
Connector Assembly
Dummy Plug, 2-Pin
Socket Assy 5/8"
Lmi Boom Instl Kit - Iflex 5
Nose Installation - Auxiliary
Weight And Chain Assembly
(Complete Assembly)
Kit - Lmi Auxilary Boom Nose
(Complete Assembly)
Load Moment Indicator Kit
Installation - Auxiliary Boom
Boom Angle Indicator
Installation
Pointer Assembly
Cover Installation - Boom Hole
Hook Block Assembly - 25 Ton
Control Valve Installation 102’ Boom
Valve Assembly - Directional Control
4 Section
(Complete Assembly)
Valve Assembly - Accessory
With Swing Directional Control Valve
(Manifold)
(Complete Assembly)
O/R Selector Manifold W/ Pb
Manifold Assembly - Warm-Up
(Complete Assembly)
Extension Installation - Boom
7.9 To 13.7 M (26 Ft To 45 Ft)
Extension Assembly - Boom
(Complete Assembly)
Mast Assembly
(Complete Assembly)
Carrier Installation - Jib
Extension
Extension Installation - Jib Boom
Extension Kit Installation -
Boom
Junction Box Assembly -
80mm X 75mm, Pg9 + 2-Pin
Cab Group
Cab Installation -
With Or Without C.E. Conformity 24v
Cab Assembly - 24v
(C.E. Conformity)
Cab Sub-Assembly - Standard 24v
(C.E. Conformity)
Glass Door Assembly
Window Assembly - Right Hand
(Complete Assembly)
Window Assembly - Rear
(Complete Assembly)
Kit - Skylight Wiper
(24 Volt)
(Complete Assembly)
Kit - Front Wiper
(24 Volt)
(Complete Assembly)
Fan Assembly - 24 Volt Cab
(Complete Assembly)
Heater/Air Condition Installation - Cab
Kit - Cab Heater And Air Conditioner
(24 Volt)
(Complete Assembly)
Pedal Installation
Pedal Assembly - Foot
(Complete Assembly)
Brackets Installation - Cab
Acoustics Installation (Sg)
Miscellaneous Installation - Cab
Extinguisher, Fire
Light Installation -
Lmi Warning 24v
Electrical System Installation
Superstructure Cab
Tms600e/Tm500e-2
Panel Assembly - Overhead Console
(Complete Assembly)
Harness Assembly - Superstructure Cab
Overhead Panel
Panel Assembly - Fuse And Relay
Harness Assembly - Fuse And Relay Panel
Seat Installation
With Auxiliary Hoist
Seat Assembly
Switch Assembly - Proximity
(Normally Open)
(Complete Assembly)
Controller Assembly - 8-32 Volt
Left Hand Armrest
(Complete Assembly)
Right Hand Armrest
(Complete Assembly)
Harness Assembly - Seat
(Complete Assembly)
Slimline Seat W/Slides
Panel Installation -
Heater / Air Conditioner
Panel Assembly - Heater/Air Condition
Control
(Complete Assembly)
Pedal Assembly - Electronic Telescope
(Complete Assembly)
Covers Installation - Plastic
Air Conditioning Installation
(Superstructure Cab)
(24 Volt)
Kit - 24 Volt Air Conditioner
(Carrier Cab)
(Complete Assembly)
Kit - Cummins Air Conditioner Compressor
(24 Volt)
(Complete Assembly)
Kit - Air Conditioner Hose
(24 Volt)
(Complete Assembly)
Panel Installation - Right Front Console
Tms500e
Panel Assembly - Front Control Display
(Complete Assembly)
Harness Assembly - Front Console Panel
(Right Hand)
(Complete Assembly)
Gauge, Tachometer/Hourmeter
(24 Volt)
Converter Installation - 24v To 12v
Binder Installation
Indicator Installation - 3rd Wrap
Lmi Cab Kit Installation
Light Installation - Lmi Warning
Control Module Installation - Tm500e-2
Kit, Lmi S/S Iflex 5
Lmi Superstructure Installation Kit -
Iflex 5
Cranestar Retro Kit Tm500e2/Tmc540
Cranestar Installation - Cab
Harness Assembly-Cranestar Tcu
Cranestar Installation - Superstructure
Tm500e-2/Tmc540
Cranestar Decal Installation-Tm500e-2
Cab Cover Installation - Rear
Control Valve Group - Upper
Final Assembly
(Superstructure)
Hyd Lines S/S Main&Aux Hoist
Hoist Group
16mm Dia Hoisting Wire Rope -
Hoist Installation - Main And
Auxiliary
(C.E. Conformity)
Hoist Assembly - Hp15c/17g
With 3rd Wrap
(Complete Assembly)
Mirror Installation - Hoist
Hoist Covers Installation
Main & Auxiliary
(C.E. Conformity)
Turntable Group
Motor Assembly - Swing Drive
(Complete Assembly)
Lock Installation - 360 Swing
Lock Assembly - Swing
(Complete Assembly)
Lock Installation - Pin
Cylinder Installation-Lower Pivot & Lift
Cylinder Assembly - Lift
(Complete Assembly)
Valve Assembly - Holding
(Complete Assembly)
Bolt Installation - Bearing
Lube Installation - Turntable Bearing
(Manual)
Cable Installation - Pin Lock
(Superstructure)
Tm500e2
Cover Installation - Valve
Bottle Installation - Washer
Mirror Installation
- Turntable
(C.E. Conformity)
Engine Group
Exhaust Installation
Outrigger Group
Electrical Group - Operator Compartment
Panel Assembly - Left Hand Remote
Outrigger Control
(Complete Assembly)
Switch Assembly - Emergency Stop
(Modified)
(Complete Assembly)
Panel Assembly - Right Hand Remote
Outrigger Control
(Complete Assembly)
(Modified)
(Complete Assembly)
Cover Installation - Outrigger
Beam
Outrigger Controller Installation
Outrigger Hand
Cable Assembly
Frame Group
Decal Installation - Tmc540
Standard
Standard - Carrier
Standard - Carrier
Standard - Superstructure
Standard - Boom
Outrigger Beam Installation
Outrigger Beam Assembly
Cylinder Assembly-4 1/2" Outrigger Jack
(Complete Assembly)
Outrigger Extend Cylinder
(Complete Assembly)
Cylinder Assembly Modified
Cylinder Assembly - 2 1/2" O/R Extension
(Complete Assembly)
Access Installaton
Nomenclature
Fender,Ladder & Mudflap Installation
Service Ladder Assembly
Miscellaneous
Swivel Installation -
Electric And Hydraulic
Swivel Assembly -
Swivel Assembly - 2 Port Hydraulic
(Complete Assembly)
Slip Ring Assy 10 Cond W/Slew
Rest Hook & Ball Installation
Sub-Frame Attachment Installation
Switch Assembly
Powerplant & Tray Installation
Engine Installation - Cummins Qsb3.3
Engine Assembly-Cummins Qsb3.3
Pump Assembly - Gear
(Clock Wise)
(Complete Assembly)
Pump Assembly - Piston
With Torque Limiting
(Complete Assembly)
Alternator Installation
Modified
Kit - Air Conditioner Compressor
Adjusting Arm
Filter Assy. Fuel/Water Separ.
Element,Filter Fuel/Water Sep
Hydraulic Tank Installation
Fuel Tank Installation
Radiator Installation
Radiator Assembly
Electrical System Installation -
Power Plant
Kit - Cable (Batteries)
Tm500e2
(Complete Assembly)
Panel Assembly - Battery Box
Kit - Relay Panel Cable
Tm500e2
(Complete Assembly)
Harness Assembly -
Relays
(Complete Assembly)
Harness Assembly - Engine
Tm500e2
(Complete Assembly)
Cover & Step Installation
Engine Cover Assembly
Cover Assembly - Battery
(Complete Assembly)
Air Intake Installation
Air Cleaner
Power Plant
Fuel Lines Installation
Mounting Kit - Oil Cooler
Tool Box Installation
Supplemental Decal Installation
Decal Installation - Front Bumper
Hookblock Tie-Down Installation
Decal Kit - Tmc540
Counterweight Installation
Cab Walkway Installation
Light Installation - Ce
Beacon Assembly - Rotation Yellow
(For Reference Only)
Beacon - Warning
Foam Instl-Engine Compartment
Electrical
Electrical System Installation - Frame
Harness Assembly - Carrier
Lmi Cab Kit, Iflex2
Supplemental - Superstructure Cab
Harness Assembly -
Fuse & Relay Panel
Harness Assy, Outrigger Cab To Board
Cab Overhead
Harness Assembly - Supplemental
Superstructure
Control Valve Group - Lower
Valve Installation - Hydraulic
Outrigger
(Carrier)
Valve Assembly - Outrigger Control
4 Section
(Complete Assembly)
Hydraulic Lines Installation - Outrigger
Schematic
Hyd System Schem Tmc500e-2
Hyd Press Set Proc 102’ Boom
Tmc500e-2 Car Plumb Route Spec
Electrical Schematic Tm500e-2
